Question about Fellowes Office Equipment & Supplies
Why does shredder full light stays on after emptying.
    Novelist:
  • 157 Answers
There is a photo cell or switch that detects when it is full, this may be covered by a scrap of paper or paper dust. Make sure the shredder is unplugged and use a flashlight to look for the photo cell and use a small thin brush to clean it, If you clean it and it still indicates that it's full the photo cell or switch may have gone bad and will need replacing.
Posted on Sep 10, 2009
SAFESENSE ISN'T WORKING ON C-480C FELLOWES
Use a cotton bud dipped in alcohol and clean sensors
Run shredder once a day in reverse for 15 seconds to clear cutters
Empty wastebasket when bin full indicator light is illuminated using b0
If this does not solve the problem goto
www.fellowes.com for an extensive on-line support section
Feb 27, 2014 | Fellowes Manufacturing Powershred C-480C...
We have a Fellows Pwoershred 2200SC that keeps showing the full bin light even when it's empty. Tried cleaning the eye near the feed area with canned air as per recommendation by a shredder maintence...
There are also sensors under the shredder head to indicate when the bin is full. You either have a defective sensors or a dirty one (clean with air).
Aug 29, 2011 | Fellowes 2200SC Shredder
Rexel RSS1627/RSX1227 Red light always on when
I have an Acco Rexel RSX 1227 shredder. Can you use any oil to oil the shredder or must it be a special oil
Aug 22, 2011 | Office Equipment & Supplies
OfficeMax (0M96431) Shredder\r\n ATTENTION LIGHT STAYS ON SOLID -... Answer Failed: retry attention light stays on solid - won't take paper in or go into reverse - have emptied bin, cleaned... (More)...
Have the unit serviced by a office machine technician. This sounds like there may be a problem in the gear drive, which you will not be able to access or repair.
Aug 14, 2010 | OfficeMax Office Equipment & Supplies
SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Nov 11, 2009 | Fellowes DM15C Shredder
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
Basket full light on
without seeing the product, there are 2 (two) things to check.
First, unplug the shredder and go underneath where the bin full flap is. Sometimes paper debris gets stuck between the flap and switch. Check to ensure the switch is not out of adjustment. you'll have to remove the top cover to perform this. Otherwise, your PC Board is defective.
Mar 02, 2009 | Fellowes 2200 Cross-Cut Shredder
Hsm125.2
Because your shredder shred almost to dust level. you may have paper back up inside the machine. you will not be able to see it unless you remove the head and open the cover. Or your main board could be bad. You have one main board that controls your shredder.
At this time, the machine maybe reading as full because the paper backup inside the machine.
you have few screws that holds the base and the top cover.
Good luck.
email me if you have problem
This is known problem with Hsm125...
Jul 21, 2008 | HSM 125.2hs Shredder
Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Apr 25, 2008 | Office Depot Ativa DQ60M Shredder
629 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
