Question about Panasonic Video Cameras
I can't remember exactly when I bought the camera...I think '04...Its a panasonic 24xoptical zoom...800xdigital zoom....anyway the camera works fine except when i try to view on the flip out screen...the screen has nothing.....is there a lightbulb or something that needs to be replaced...whats the deal?
  • 62 Answers
If You can see an image on the screen in normal mode, the backlight is fine. The problem is on the contact group when You flip the screen. Needs to be repaired in a service center, and it's low-cost operation. Do not try to make it yourself. Sincerely. Alfredo.
Posted on Sep 10, 2009
Panasonic LUMIX 14-42mm GX VARIO PZ lens on GF-1 Body
When using different lenses, a few things should be kept in mind.For some you need an adapter and not every lens ail work as the lenses made for this camera. Sometimes focus or other things needs to be set manually. So even when you can connect a lens to the camera you don't have any guaranty it will work fully automatic and correct. Please read the manual tag came with your camera, about the differences between the four thirds cameras and lenses.
Dec 03, 2013 | Panasonic Lumix DMC-GF1 Digital Camera...
Zoom lever stopped working on Panasonic lumix DMC-FZ8
Does it say anything about the lever under zoom levers in your owner's manual?
Nov 07, 2012 | Panasonic Lumix DMC-FZ8 Digital Camera
Optical zoom and flash not working on Panasonic DMC-FZ7
None of what you describe sounds good. Any chance you can get your money back?
Dec 08, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Auto zooming on power up, intermittent problem
Possibly a intermittent connection in the control buttons or the ZIF (Zero Insertion Force) connector from the controls to the main PCB.
Take it in for servicing, they will do a trial by substitution (swap out control) and lubricate the connector.
There isn't really anything you can do to fix with this sort of problem.
Cheers.
Sep 28, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
System error: zoom message with Panasonic Lumix FS15 camera
I had the same problem, i switched the camera on in capture mode and zoomed in and applied a little pressure to the lens which made a slight click but retracted and has worked fine since. I may of just been lucky but the camera is fully functional again, could be worth a try.
Jul 20, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Lens
You have a 55mm filter size on your camera, and the accessory lens requires a 62mm camera connection. I think you are looking through a 55mm tunnel into a 62mm lens (over-simplified I know). The black ring is the result, and I don't think you can fix that. Is the telephoto a Panasonic accessory, or a third party item. I think I already know the answer to that. I'd take it back and see what Panasonic recommends - you'd be happier. However, Panasonic has Leica glass (Leitz lenses) so it won't be cheap.
May 19, 2008 | Panasonic Cameras
Panasonic dmc-fx9 screen0220p00
Only Panasonic will have repair/replacement facilities
If the camera is more then a year old or not a current model
A new replacement may be a better bet than trying for costly repairs.
E-mail customer support at Panasonic
Nov 20, 2007 | Panasonic Lumix DMC-FX9 Digital Camera
Some of the buttons don't work
You may want to check with a guy in South Carolina that has a lot of used parts, etc for the TZ1. I think his email is gerald.ray@aa-ark.com
Aug 27, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Zoom malfunctioning
This sounds like there is debris lodged in the zoom gears. Been to the beach lately? The gears in the zoom mechanism are very small, and even a tiny spec of sand or other debris can jam them up. Alternatively the sensor inside the lens that feeds back the position of the lens to the control circuit may be failing - so the camera thinks the lens has retracted all the way and stops. If the stoppage of the zoom action is abrupt then it is probably debris, if it is a smooth stoppage like the camera is stopping on purpose it is probably a position sensor. Either way the camera will require repair. David Millier Advance Camera Repair
Feb 20, 2007 | Olympus SP-350 Digital Camera
Video Cameras Logo
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
