Question about IBM 6400 Model 010 Matrix Printer
IBM 6400 stuck on message "Testing Hardware Please Wait"
I replaced the CMX board and I'm still getting this same message. Any ideas? Thanks, Scott
  • scarpente623 Sep 10, 2009
    >Have you tried resetting the memory yet?>If you are using an Ethernet connection, disconnect your 10/100 card and turn it on.
    >If this doesn’t work you can also try resetting your defaults.
    >If none of this works, it might be that you CMX has lost some of its boot configurations and needs to >be reflashed or possibly fixed. Depends.
    >If you are uncertain about these instructions, you absolutely should not attempt it.
    Thanks for your reply.
    We started getting the "Testing Hardware Please Wait" message. I replaced the CMX board and we continue to get the same message.
    I've reset the memory.
    I've also disconnected the 10/100 card, turned the 6400 on (we are using ethernet), got the Testing Hardware... message, turned the 6400 off, reconnected the 10/100 card, turned the 6400 back on, and still get the Testing Hardware... message.
    How would I reset the defaults or reflash the new CMX board?
  • 555 Answers
Sorry to hear that you are having problems with your printer Scott.
If none of this works, it might be that you CMX has lost some of its boot configurations and needs to be reflashed or possibly fixed. Depends.
Good luck.
Posted on Sep 10, 2009
  • Jose Pino Sep 10, 2009
    To reset an IBM 6400 firmware, Hold cancel & stop while powering on the printer to enter the maintenance menu.
    You can wipe the firmware or re-flash from there. You need to have a copy of the
    microcode firmware to reload.
TOF doesn't cycle platen
Usually due to a broken platen belt if the motor moves.
Platen belt can be bought though here.
MRP provides IT Parts Product Supplies and Services
If the motor does not move you most likely have a failing main logic board (called a CMX)
Talk to your supplier about the firmware on the CMX before ordering or it will not work when you get it.
Dec 15, 2015 | IBM 6400 Model 015 Matrix Printer
082 Power Supply 8.5V fail
Can be Power supply or CMX PCB. If CMX the printer will need to be re-flashed after replacing, there is no reasonable way to figure out which is the problem without replacing them.
CMX
Power Supply
Jan 16, 2014 | IBM 6400 Matrix Printer
What does hb control mode on a IBM 6400 printer mean?
usually u get those on mod 14's and up and it could be a few things (i would try in this order from lowest to highest priced) coil temp needs to be set, hammer bank cables, shuttle and or cmx bd need to be replaced. Rory 708-597-4222
Jun 24, 2011 | IBM 6400 Matrix Printer
My IBM 6400 comes up with the error 086 Controller 15V
Controller voltage failure : either a defective CMX card or Power supply
Jack
Aug 09, 2010 | IBM 6400 Matrix Printer
IBM 6400 Stuck At Testing Hardware
Hello Edward,
Have you tried reseating your memory yet? If so try disconnecting your 10/100 card and turn it on. If this doesn’t work you can also try resetting your defaults.
If you have any questions please contact me, we offer free technical support and carry new and used IBM Printers and Parts.
Thanks,
Rory Cardenas
Midrange Repair and Parts
3821 W.127th Place
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 13, 2009 | IBM 6400 Model 010 Matrix Printer
IBM 6400-I24
1. Cycle power. If the message appears,
press Stop.
2. Power off the printer. Remove the shuttle
cover. At the shuttle frame assembly,
disconnect the hammer bank logic and
power cables. Power on the printer. If
“HB NOT INSTALLD” appears on the
LCD, replace the shuttle frame assembly.
If “HB NOT INSTALLD” does not appear
on the LCD, replace the CMX controller
board.
I have both parts in stock refurbished with a 30/day warranty. I can take your as an exchange for the good one at a reasonable price. Please let me know I can be reached at 708-597-4222 X240 or email rcardenas@mrp.to.
My name is Rory Cardenas.
Thanks
Rory Cardenas
Account Executive
Midrange Repair & Parts
708-597-4222 x: 240
Jun 25, 2009 | IBM 6400-I24 Printer
are you running twinax or etherent on this unit?
Jun 09, 2009 | IBM 6400 Model 010 Matrix Printer
Controller voltage Problem in IBM 6400 Printer
When you power on the printer, do you hear the fans kick in? If you checked the Maint. Man. skip steps 1 & 2, almost 80% of the time its CMX brd, not knowing your 6400 model? Part# for CMX 40mhz 157450-901, older models have 155802-901 CMX 25mhz V5.5...
Oh yeah if u don't hear fans kick in when you first power up, 80% jumps to 95% chance CMX bad.
I hope you have a current configuration print out! it will save headaches and a lot less down time...
Jan 24, 2009 | IBM 6400 Matrix Printer
Need Program files to Flash IBM 6400 Printers
If you haven' tlooked into any of the print management utilities here is a link.
I am not familiar with this printer .. but maybe this is what you need.
Sometimes we just try .. because we really want to help and hope that maybe we "stumbled" on something.
Dec 09, 2008 | IBM 6400 Matrix Printer
Wont print on line
You may need to have some driver installed on your PC, that can be downloaded from some IBM printer web site, such as this one:
http://www.infoprintsolutionscompany.com/internet/wwsites.nsf/vwWebPublished/supportdownloads_ww
IBM does not manufacture printers any more, they outsourced that to other places like Lexmark & ProPrinter, so we have to figure out which outsource place is relevant & what name they have for whatever corresponds to 6400 driver.
Sep 27, 2008 | IBM 6400 Matrix Printer
IBM 6400 Model 010 Matrix Printer Logo
1,105 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
