Question about Dryers
DG512 igniter lights for 10 seconds and then the igniter goes out while the dryer continues to rotate. Gas does not come on.
  • 53 Answers
Check your venting. Make sure you have good air flow. If the vent is clear you either have a coil on the gas valve bad (they come in a set of 2) replace both, or a timer issue. The gas valve is located in the front of the unit usually under an access door.
Posted on Sep 10, 2009
White knight gas tumble dryer lights then cuts out
Flame sensor next to the burner is eather bad or there is a bad connection at the flame sensor (that's why the kick works)
Jan 05, 2014 | Dryers
My Maytag Model MDG3500BWW gas dryer will ignite and burn properly for about 30 seconds, then the igniter will glow bright orange, then shut off without igniting the gas. It will continue this cycle of...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][
Aug 07, 2011 | Maytag MDG3500BWQ Dryer
The burner ignites then goes out in about 10 seconds then it will re-ignite in about 3-4 minuites burn for about 10 seconds then goes out. I have replaced the coils and igniter. the thermal fuses tests...
heatman101
Apr 26, 2011 | Whirlpool LGR3624JQ Gas Dryer
I have a gas dryer and the trouble is it will ignite and stay for about 10 seconds then go out. The dryer will continue to run and about 15 minutes will ignite again stay for 10 seconds and go out. This...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 01, 2011 | Kenmore Dryers
Burner not stayinyg lit
since burner is igniting, it probably is OK. next check is limit switch. this switch shuts the gas off if it senses excessive heat (blocked vent ... usually caused by lint) limit switches themselves MAY go bad ... bu rarely PS check to make sure the vent is blowing exhaust to outside of house (i've seen birdnests in the exhaust port cause your problem)
Apr 27, 2009 | Dryers
No heat on gas dryer maytag dg512 series 07
If you could look through door panel on back of dryer while its trying to ignite you should see a glowing igniter to ignite gas. If you see the glow then I believe your gas solenoids are bad, The part number for one is 305604
Go to my web page and enter part and model numbers in the search features. I will help you find the problem, Thanks Sea Breeze
seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Apr 14, 2009 | Dryers
Gas ignites but goes out after 15 or 20 seconds
Hello gdurawa
Welcome to Fixya
My name is Huum,
You said, upon starting my Kenmore gas dryer the igniter glows and the gas ignites, but the gas goes out after 15 or 20 seconds - clothes don't dry.
This means either the igniter is bad and not getting hot enough to make the gas continue to release completely and stay open, so it shut off.
or you have a bad gas module.
Or a bad gas valve without enough pressure.
Needs to be diagnosed hands on at your location .
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 22, 2009 | Kenmore 63942 Dryer
KENMORE gas dryer
Hi .No The Solenoids Are Turning The Gas On . I would Check The Venting . Remove The Venting Clean All Venting. Thanks The Appliance Doc
Oct 03, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
54 people viewed this question
Top Dryers Experts
