SOURCE: Frig not cooling
I had a same problem as what you described. I purchased mu Samsung RS2545SH side-by-side refridgerator from Costco 2 years ago. I contacted Sumsung, who then sent out a local/independently operated repair shop to come and perform the repair. After three trips by the repair shop and more than $400 in repair cost, the same problem persisted, and I'm stuck with a non-functional fridge for more than 2 weeks. Repeated calls to Samsung service line simply added more aggrevation and no results. The repair shop declared the fridge non-repairable, and my attempts to ask Samsung for a refund only get me a standard response: The executive review committee is reviewing your case!
Finally I simply had it, and hauled the fridge back to Costco, and thank goodness, the folks there were so kind and took back the broken fridge after 2 yrs from the purchase date. Thank you, Costco!
I do not recommend anyone to purchase a Samsung refridgerator. They may look nice on the outside, and maybe even a bit cheaper price. But you may very well be stuck with a non-working fridge in a year or two, and a warranty bureaucracy that will bog you down. And Samsung did not seem to care about standing behind their broken product. This will be the last Samsung product I will ever purchase.
SOURCE: Sub-Zero temperture fluctuation
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
SOURCE: Freezer is cold but the frig side is not???
Hi Gotzd,
If you open the fresh food side (not the freezer), and look to the upper left side you will see a plastic shroud or cover. Behind that cover is a printed circuit board (p.c. board) and a damper motor. That motor brings cold air from the freezer to the fresh food side. The whole damper assembly may need to be replaced. That also includes the cold controls for both sides of the "fridge".
Home Depot Parts and Accessories has the part available. 800.378.5830.
Call, give them your model number, and the description, they will locate the part number for you.
This MAY be the solution for you, it was for me. Hope this helps, better yet, Hope you've fixed already.
Steve D.,
Owner Handy Home Repair
SOURCE: freezer not freezing frig not cold
the compressor with a picture of an Indian, its a techumseh. Is the compressor running? If not, could be stuck in defrost mode. Since you have looked at the compressor, there is two lines that go to it. If there is an oil cooler, then 4. Follow the line, smaller of the two that goes to the condensor, rad. With the fridge running, use your hand to feel how hot it is, if you find it hot enough that you can't leave you hand on that line, then its an inneficient compressor.
SOURCE: Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
