Question about Nintendo Wii Console
My grandson's Wii power adapter has just blown up but fortunately did not go on fire. Has anyone else experienced this problem?
  • 148 Answers
Could be a factory defective power supply...see if the wii power supply is made in china...alternative power adapters don´t have the quality of the original ones...does your eletrical home instalation is good ? Cause bad home eletrical terminals can cause overcharge or even a overvolt in a sensible power supply.
Good Luck!!!
Posted on Sep 10, 2009
I'm playing a game called animal crossing: City Folk on the wii and in order for me to get a friend code i need the internet and I don't know where I put the ethernet cord at on the Wii. Can you...
You will need a device called a Wii LAN adapter, which will connect to the back of the Wii console, and then connect to your Ethernet cable. Since the Wii is not packaged with this device, you must purchase it from Nintendo's site, or at retail from a store that has the Wii's LAN adapter in stock. Fortunately, Nintendo's Wii LAN adapter is not expensive at retail, and most compatible with the console.
Nintendo's Customer Service (http://www.nintendo.com/consumer/systems/wii/en_na/onlineWiredTS.jsp) is very helpful to answering questions regarding the Wii's Internet connection in great detail once you have a Wii LAN adapter.
Jul 19, 2011 | Video Game Consoles & Games
I have no power to my wii what could be wrong
    Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
    Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
    The AC adapter must remain unplugged at both ends for a full 2 minutes.
    Unplug anything connected to the USB ports and the Nintendo GameCube Controller ports.
    While you're waiting, check the AC Adapter for the following:
    Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter.
    Check the AC Adapter for physical damage.
    After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
    If resetting the AC Adapter did not fix your power issues:
    Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices.
    Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage.
    Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
    Check the vents on the back and side of the Wii for dust build up. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
    Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in.
    Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector).
    Once plugged in, check the power light on the Power button to see if the system is receiving power.
    If the power is still continually shutting off regularly, contact Wii support.
Apr 08, 2011 | Nintendo Wii Console
Where is the fuse in the wii and how do you go about replacing it?
Hi. This could be a problem with the blown fuse in you power adapter.
Fuse for the power brick
open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws. check the 3A fuse in that box; if it looks blown, then replace it.
Sep 07, 2010 | Nintendo Wii Console
My wii will not turn on
Hi,Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
First:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
Second:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
Third:
- it might be cheaper to replace the AC adapter with another one
Fourth:
- get the unit repaired
Thanks and good luck
Jun 03, 2010 | Nintendo Wii Console
My wii was working a few days ago then I tried to turn it on today and it will not come on. I tried plugging it in to different outlets but it still will not come on. No lights will come on either.
hello,
One of two common possible problems. Either 1) Your AC adapter needs to be reset or 2) Your AC Adapter is bad.
Try to find someone with a Wii.. not that hard everyone has one. See if they will let you use the power cord.
test the cord and if that doesn't you know its inside the Wii.
Then, their are fuses inside the console one of them my have blown.You need a special screw driver.
Hope this will help..
May 31, 2010 | Nintendo Wii Console
My Wii console won't turn on.
First:
- THEN, buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Second:
Third:
Fourth:
Hope that helps!
Aug 09, 2009 | Nintendo Wii Console
My wii won't power up. I am not sure what is wrong, but it won't turn on.
I just posted this somewhere else where this was asked, but I'll post it here too so it helps other people.
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
Aug 05, 2009 | Nintendo Wii Console
When lighting hit and the wii go out what do i do to make it come on
Try the following steps in this order:
FIRST:
SECOND:
THIRD:
FOURTH:
MUST DO:
- buy a good SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Hope that helps!
Aug 01, 2009 | Nintendo Wii Console
Problems with Nintendo Wii 480p component cable
Try hooking it up with whatever cable it came with. We have this same t.v. and also have our Wii hooked up to it and have no problems whatsoever.
Feb 05, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Wii Poer voltage Damage
The problem is that the voltage in NZ is different (higher) than that of the USA, and the power adapter (gray box that plugs into the wall) has blown. Replace the power adapter and use a voltage converter that lowers the power to 115 (or 110/120) volts, and you should be good to go. ;)
Jan 28, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
156 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
