Question about Dometic Rooftop RV Air Conditioner
My RC air conditioner (Duotherm) kicks the circuit breaker every time I turn it on. It used to kick the circuit breaker every so often, but lately it kicks it immediately if I try to turn on the AC.
  • 34 Answers
Try replaceing the start or run capacitor to the compressor. If no help you can install a start assist capacitor, it helps to start a tight compressor.
Posted on Sep 11, 2009
Testimonial: "Thanks for ossible solution, but my husband and I know nothing about RV air conditioners so it would be helpful to know where this capacitor is locate"
Air Compressor sometimes reaches 50psi and kicks circuit breaker. The motor beld vibrates before kicking breaker off.
Hi Bobby:
Sounds like the load on the circuit exceeds the capacity of the breaker. This happens because as the pressure builds, the resistance of the compressor increases. When it reaches 50 psi (in your circumstance) the circuit starts to draw more amps than the breaker is rated for. so it trips.
Solution?
- Find a circuit with a higher rating, or
- Decrease the diameter of the drive pulley. This will give a better mechanical advantage and possibly solve the problem.
Hope this helps
Sep 07, 2015 | Heating & Cooling
Our airconditioning just shuts off and when we turn the on power is just kicks off. Is there a re-set button?
There should be a main circuit breaker in your switch board. Turn the ac of leave for a min . that will reset it . You might have other problems also
Jan 29, 2012 | Mitsubishi MSZ-A12NA Air Conditioner
Tripping the circuit breaker for a Fridgidair FS3BA-036KA. Once its on it works. When it kicks off no problems when it kicks in again it trips the curcit breaker again
I would suggest that you quit doing that . It's probibly to late now But it appears you have a short either on the fan side or the compressor side. I hope its not the compressor as you make matter worse if you keep resting it . call a tech
Jul 17, 2011 | Frigidaire Heating & Cooling
My a/c will run and cool great but keeps kicking the 20 amp circuit breaker even when no other appliance is running.
A 20 amp circuit breaker should be sufficient enough to do the job unless the breaker itself is too old, or if the connection screws on the breaker are not tight enough.
Jul 25, 2009 | Dometic Rooftop RV Air Conditioner
DuoTherm compressor starts but will not continue to run
check condenser fan if running. it will make compressor comes on and off if broken
May 31, 2009 | Dometic Rooftop RV Air Conditioner
Ac Problems
You must have too many things running on that circuit. Check your connection to the power box.Loose connection on the receptacle can cause the breaker to trip or too many things running on the same circuit. If the breaker is old it might need to be replaced.
May 10, 2009 | Dometic Rooftop RV Air Conditioner
Duotherm 1350 Btu's air conditioner breaker problems
Are you using a long lightweight extension cord? This unit alone draws almost 1000 watts. On a 20 amp circuit this doesn't leave a lot of room for other appliances and lights. If this is a brand new unit and the extension cord is the right size the air conditioner should still be under warranty.
Jul 03, 2008 | Dometic GEN3107206 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
214 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
