Question about Hotpoint 24 in. HDA3400G Built-in Dishwasher
Hotpoint HDA3400 Very Loud
My Hotpoint dishwasher is only 2 years old and from the begining has been very loud in the beginning cycles. Any help would be appreciated.
5 Suggested Answers
bigg t
  • 640 Answers
SOURCE: HOTPOINT HDA3400 WILL NOT HEAT CYCLE
do you have a multimeter to check voltages?if so put the unit into the heat dry mode and see if you get voltage{im assuming its 110 volts}.if you have the voltage there then the heating element is bad.if theres no voltage then the timer is bad.how old is your unit?
Posted on Aug 14, 2007
SOURCE: Hotpoint Superplus 7822 dishwasher
At the beginning of the cycle the dishwasher is attempting to pump out any residue water in the waste pipe and sump. It could be that the motor is sticking but you would probably also suffer from it not draining properly.
It may just be noisy pump. I have a similar model and it is also quite noisy but nothing extraordinary.
When the dishwasher is pumping out at the end of the washing cycle it may be quieter when there is water in the pump/pipes but then gets noisy as it 'pumps air'.
Posted on Jul 25, 2008
honeymokey
  • 3113 Answers
SOURCE: Maytag dishwasher.Loud humming noise, wash cyle,at beginning
Is the water filling up and then draining out? Mine did this and a part was broken inside the unit. The part was five dollars and called a lifter. I fixed it myself.
Posted on Apr 08, 2009
  • 351 Answers
SOURCE: dishwasher makes very loud noise
maybe something in pump or bad pump baring
Posted on Sep 30, 2010
My trton t90z makes a loud noise 15 secs after its turned off. Its the thermal switch. Should I get it replaced. Its 2 days old.
What makes u think its the thermal switch? normally the noise at beginning or end of cycle is caused by the compressor with bad springs, groumets, or not sure how to explain this but the freon sits in a round bowl like orifice and when its low there is usually a loud noise at end of and beginning of cycle. other words when goes off and comes on? ( this is usually due to moving the fridge on it side and not waiting long enough for oil to settle before turning on?
Apr 02, 2015 | Refrigerators
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    Drum makes loud noise as rotates clockwise
    put few clothes in it drum to switch on its ball in there
    Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
    Jan 29, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
    Maytag dishwasher mdb9600awb - loud pump
    This has happened a few times to me as well.(VERY VERY LOUD NOISE AT THE BOTTOM)I have the same model It did stop.I did a little reading and came to the conclusion that it was the built in food disposer chopping blades were chopping up something like a cherry pit or peach pit and once an end of a wooden spoon that dropped down.If you look at your USE and care Guide on page 12 under trouble shooting "Dishwasher seems noisy"..I went through the same thing taking things apart.Its got to be it. Mine is 2 1/2 years as well. Hope this helps. ronkeachie@rogers.com
    Sep 24, 2007 | Maytag MDB9600A Jetclean II Built-in...
    Dishwasher loud in beginning cycle and drains early
    sounds like you have 2 problems however generally speaking (most makes) of dishwashers go into drain mode when there is a fault elsewhere, however is this set up properly, is the waste pipe end high enough to allow the water to actually fill up (only about 30cms of water aprox)so it doesn't flow straight though to the waste. the noise could just be an empty pump, it runs dry after a while, and makes a screeching noise eventually? check installation pictures to see if its set up right, you may have also a leak somewhere check all other connections and pipes
    Sep 21, 2007 | Maytag MDB7100AWB Dishwasher
    Aug 14, 2007 | Hotpoint 24 in. HDA3400G Built-in...
    Hotpoint 24 in. HDA3400G Built-in Dishwasher Logo
    60 people viewed this question
    Top Hotpoint Dishwashers Experts
    AcmeUK
    Level 1 Expert
    Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
