Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
I have a lacie 250g usb file for start up will not open. showing only 9.96mb of space. is there a way to reformat the whole disk.I think the start up has been wiped.
  • 3,153 Answers
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Quick checks of the drive itself can be done by removing it from its enclosure and connecting it directly
to a comuter that has the correct interface. If you can read and use the drive then you know it is not that.
If you cannot use the drive in any way and esp. if you hear clicking or pinging then the drive is almost certainly dead or dying.
Posted on Sep 10, 2009
Testimonial: "got me into the right space deleted partinging start up and reformeted. thank you."
I bought my lacie 1TB hard drive and when i pluged it in to use it all it did was try format its self and now when i plug it in to my lap top it just says available space 9.99mb.where has all the rest...
Connect the LACIE.
Click Start
Right-click My Computer
Click Manage
Expand the Storage branch of the tree
Click Disk Management (local)
Does it show a bar-graph for the LACIE?
What do you see?
Nov 12, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I used my Lacie 160GB Mobile Disk from morning to evening on my Dell Latitude D610 Laptop, until evening when my younger brother came home from work, he demands to copy some movies from my Lacie 160GB...
This happened because your brother's computer is infected with a virus or otherwise corrupted. Take the drive and both computers to a local tech to further diagnose the problem and that tech can probably recover your files. I think your brother should pay for the repairs - his computer has some malware that may have overwritten your files. This is why you should do two things - first, always have two kinds of backups - copy vital files to a usb memory stick, and second, don't lend anyone any device you plug into your computer - that is how viruses are spread.
Apr 06, 2017 | LaCie 160GB Mobile Disk USB2.0 160 GB Hard...
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
I have a Lacie 320gb external harddrive which was connected to an eMac and is now connected to an Acer laptop. I've reformatted it as NTFS and it shows up in disk management as healthy but does not appear...
you need to give it a drive letter
A more reliable way to do this is via the computer management console
Start / Control Panel / Administrative Tools / Computer management / Disk Management.
Your drive should show up in here.
if it says Healthy and just above that gives the file system eg. NTFS or FAT32 etc it should be fine but may just need a drive letter.
If it does dot say any of those then right click on it and use the format option. Select how you want to format it (NTFS for XP is preffered)
and then tell it to do a FULL format. and also give it a drive letter !
It may take a while but I find it more reliable overall.
If it didn't have a drive letter then right click and use the Change Drive Letter and Paths option, then add a drive letter and use the one it offers.
I like to re-boot just to be sure windows sees it properly
Aug 28, 2009 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
Mylacie drive is no longer connected to my computer. When it is turned on, there is a clicking noise and the LED light is alternating between red and yellow. What do you think the problem is?
when a disk makes a clicking noise, in most cases (99%) that means that the disk has crashed. i'm sorry to inform you that the data you had on the disk is lost, unless you are prepared to pay lots of money to a company that takes the disk apart to retrieve data manually.
Jun 24, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
File transfer size limitation for LACIE HD
hi
can i suggest that you use winrar to divide the file size of your file that you want to transfer to your lacie. this might work.
download winrar @ majorgeeks.com
but if you LACIE still says that it does not have any disk space left...i would suggest that you reformat the HD instead. but make that a last resort...
hope this helps
Jan 21, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Drive mysteriously went from 250GB to 55MB!?
Hi, It would seem that the LaCie(300770) 250 GB Hard Drive would need partitioning and not only formatting to be able to recover the missing space. This is better explained by Microsoft Support . Alternately, you can right click on "My Computer, click on Manage, click on Disk Management, right click on the Lacie drive and delete its current partition. Ok or Apply, Windows may ask you to reboot. Do the Disk Management again. If the Lacie's original/erroneous partition has been successfully deleted, it will now show as "Unknown Partition". To create your new partition, right click on the unallocated space (black stripe on top), click on "New Partition" on the menu. To format, simply right click on the Lacie and click on Format. As a matter of choice, I prefer to use Partition Magic and/or Seatools for Windows. If using any of the above method and the Lacie will not partition/format or errors keep on appearing, it may be that the Lacie is no longer usable as a whole. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Sep 27, 2007 | LaCie (300770) 250 GB Hard Drive
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
220 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
