Question about Lexmark X3480 All-In-One Printer
Message says lid is open when it is closed
On my Lexmark X3480 all in one printer,Message says lid is open when it is closed. Sometimes it will work and outher times I cant even shut it down.
  • 776 Answers
Please try out the blow mentioned 2 options. I am sure the problem will be sorted out:
  1. When you lift the cover up along the back end of the gray plastic bottom cover, you'll see a square opening close to the right side hinge.
    There should be a little white plastic piece sticking out of there. If not, it fell into the guts of the printer. You have to remove the gray plastic and find the white lever and replace it onto a micro-switch along the back where the square opening is/was.
    You'll see a PCB (printed circuit board) there and the micro-switch will be located on that...
Hope this helps
2. Remove the screws on the front of the cover when it is open. Once removed At the back of the unit 2/3 rd from the left there is a small switch if this is pushed in ( and held by whatever means sellotape etc it will opperate normally (to change cartridge you may have to re do)
Posted on Sep 10, 2009
Printer will not print or shut down
reset memory; unplug; plug back in while HOLDING DOWN STOP KEY. This resets/clears memory
tape down the little black plastic lever (usually on left side) so it can't pop back up which causes it to invoke error message "cover open" and "cover closed" who needs a machine to tell a cover is open?
Mar 31, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark X3480 reset codes
I believe this may help. The Lexmark printer/scanners are touchy and need to be "restarted" sometimes since their internal "brain" gets scrambled. Sounds like this is what has happened to you.
Turn the printer off - if it won't - just unplug the darn thing! Then, reboot your computer - and just before you re-boot, plug the printer in.
Hopefully this will reset it.
Lexmark printer/scanner load software and other things during the boot-up process that you are not even aware of. I know this is not desirable, but that is what they do and they sometimes require a complete shut-down and re-boot to reset.
Hope that helps. If it doesn't - you may have a corrupt driver. Go to the Lexmark site and re-download the driver and re-start from scratch. Hopefully it will work out. Best of luck
Dec 08, 2008 | Lexmark X3480 All-In-One Printer
Lexmark x3480 scanner on vista not working
I THINK THE ONLY PRINTER WORK ON VIST BECAUSE THEY DO NOT DEVELOPE THE VISTA DRIVERS FOR OTHER OPTIONS
Nov 25, 2008 | Lexmark X3480 All-In-One Printer
"cover open" messagge when cover is closed
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located
Sep 16, 2008 | Lexmark X3480 All-In-One Printer
Cover open message
Jul 20, 2008 | Lexmark X3480 All-In-One Printer
Lexmark 3480 cover open
Hi I have 30+ printers and each differs but sorry I do not have your printer. But generally you will find a corresponding female recess somewhere around where the lid closes on the main frame of the printer.
Hope it helps
Tinteiros (Ebay)
Jun 02, 2008 | Lexmark X3480 All-In-One Printer
Cover open error
There is a latch that preses a small switch when you close the cover (look for this) to indicate that it it close if it is broken you can tweek it using a toothpick or anything that may press the switch temporarily this may alow it to work as long as the switch stays down.
May 28, 2008 | Lexmark X3480 All-In-One Printer
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
Lexmark X3480 All-In-One Printer Logo
124 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
