Question about Kitchen Ranges
Oven repeatedly shuts off and "PF" appears on digital screen- Kenmore gas range. We have never used the self- cleaning option for the oven.
    President:
  • 704 Answers
The code being displayed denotes "PF" for Power Failure. It could be that you have a loose connection at either the range connection in back or at the outlet where the range is plugged in. You could even have a loose wire on the breaker in your electric panel.
First, shut off the breaker to your range and then you can pull it out from the cabinet and remove the access panel on the rear of the range. Check the nuts that hold the cord terminals onto the power tabs in the range. They should be tight and clean, without corrosion or any broken strands.
Now, with the power still off at the breaker panel, check the range outlet at the floor or wall. Remove the cover screw and look at the connections to make sure they are tight and secure as well.
Sometimes Aluminum service wires are used and the connections can become "glazed" which can cause a high resistance connection. The wire should have been abraded with a wire brush and an oxide inhibitor added to prevent aluminum oxides from forming on the wire strands and the electric terminals. If yours is Aluminum, you might wish to add an oxide inhibitor to these connection points to make a better electrical connection.
After that, reinstall the cover and plug the range back in, put the range back into place and go to the electric breaker panel and carefully check the wires going to the breaker to make sure they are secure and tight. You'll need to remove the panel cover to get at the breaker screw connections, so care is needed when doing this.
Once you've done these steps, you can put everything back together and turn the power back on and see if it resolves your issue.
Hope you find this Very Helpful and best regards!
Posted on Sep 10, 2009
The oven does not work. The self clean does not too
kenmore self cleaning range c970-595084 everything works except the oven will not heat up,on self clean door locks but thats all, top elements work, lights work, digital display works, but no power going to oven elements when i used a tester to check voltage. Can anyone tell me what to do? Is there a fuse for the oven only?
ANY HELP IS APPRECIATED.
TY Fr; Clyde
Mar 15, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Self Cleaning wont start. Error Code E-1 F-5 repeatedly comes up
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 26, 2010 | Kenmore 92022 / 92024 / 92025 / 92029...
Hello - I am trying to use the clean oven option - the digital screen is displaying a F- 9 with a continuous beep. What should I do?
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 22, 2010 | Amana ARGS7650SS Gas Kitchen Range
I need directions for self leaning directions
heatman101
Sep 08, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
How do you turn off the self cleaning feature on kenmore gas stove 790.75660?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Sep 06, 2010 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
I hit the select clean button on my kenmore gas self cleaning range by accident and now i cant cook on it
heatman101
Sep 05, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My Kenmore oven won't work there is a PF 5AB error
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2010 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
Oven wont unlock has a pf code? cant open the door!
PF refers to Power Failure.Press Cancel and Check, if that clears the error. If the problem persists, it might be a Faulty Control Board.
Now,
Before that, as you never mentioned Did you try to use Self-Cleaning? If yes follow the below procedure :-
1. Unplug the Circuit Breaker for 5 minutes.Turn On the breaker and then try to open the door.
2. Again go for self clean option but for few minutes, say 15 minutes.Cancel the self self after this and allow the Oven to Cool. After some time, then try to open the door.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 11, 2009 | Kenmore Kitchen Ranges
Gas range shut off with PF on screen what does
The PF means there was a power failure, you should be able to clear this code by pressing the cancel button
Jun 04, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
How do you use the self cleaning option for Kenmore dual fuel ove
Simply press the "Clean" button and set a time (Hi or 4hrs is best) it will the lock the door and burn everything inside. If you have silver colored shelfs remove them fist. After its done and has cooled wipe out the ash that has collected in the bottom of the oven.
Dec 27, 2008 | Kenmore 75503 Stainless Steel Dual Fuel...
Kitchen Ranges Logo
248 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
