Question about Cameras
Cracked Camera Well long story short i dropped my camera and my lcd screen is cracked and there is like black stuff around the crack. The camera turns on and takes pictures but i can't see the picture in the screen , but on the computer i can. HELP!!! my camera was in my purse i didn't drop it but when i wwent to get the camera out the screen was cracked i do have a warrenty on it that i paid for can this be taken care of under the warrenty?
    Sergeant:
  • 161 Answers
This depends on your warranty, if it covers cracks and the product being dropped I'm sure they will give you a new one to replace it, or find parts to repair it.
Posted on Sep 10, 2009
Olympus 850 sw digital camera 2 yrs old! Used all day perfectly fine turned back on screen blank, still takes photos, Still flashes, still beeps when press buttons just lcd screen is black likes its off?...
Hi
Either the LCD screen is cracked or defective in some other manner. It's possible the LCD works but just the backlight is out as well. Either way, the camera needs to be opened and the LCD checked out.
The Olympus "Tough" and "SW" cameras are FAR FROM being either "Tough" or "S"hock and "W"aterproof. I have seen dozens and dozens of them with cracked glass over the LCD and destroyed by water damage. Sounds like something got inside your camera or it was badly dropped.
Hope this helps.
Thomas Drayton
Owner, Darntoothysam.com
Affordable Digital Camera Repair
Sep 07, 2011 | Olympus ? 850 SW Digital Camera
Digital camera screen broken
A cracked screen will cost you, but maybe not as much as you think. Instead of replacing the whole , you can spend about $300 and replace the screen yourself. All you need is a small screwdriver.
1)Turn off the power to your screen and unplug all cables connected to it.
2)Remove the battery, if one is installed.
3)Locate the covered screws around the cracked screen. Remove the rubber/plastic covers, then unscrew the screws.
4)Gently remove the plastic frame around the cracked screen and set it aside.
5)Disconnect any power cords or cables going into the LCD screen.
6)Remove the cracked screen and slide the new screen into place. Replace any tape or plastic fasteners that hold it in place.
7)Reconnect all internal cords to the screen.
8)Screw in the frame and replace all the screw covers.
9)Reconnect the power supply and all external cables to the LCD screen and switch it on.
Aug 31, 2009 | Sony Cyber-Shot DSC-P150 Digital Camera
Dropped my camera, screen black
Sounds like you need new LCD display, Yours may be cracked from the drop, Would probably cost about, $120.00.
Feb 25, 2009 | Sony Cyber-shot DSC-W120/B Digital Camera
Samsung A506
Sounds like its broken. the black ink stuff could mean the screen is cracked and it has bled internally. I had the same problem (screen bleeding). the not-turning-on part could be because ur not using full batteries, the batteries are not in the right way, or the screen crack is shorting something inside and not allowing the device to come on. get it replaced. when you turn it on press the menu/ok button is there any noise, tune. this happens to me to show its entered the menu section. if you are getting this sound, then its turning on but the screen is cracked. if not then you have a dead camera or change the battery positions or use new batteries.
Sep 20, 2008 | Samsung Digimax A503 Digital Camera
A brokem screen
LCD is broken and needs to be replaced.
Jun 15, 2008 | Sony Cybershot DSC-T200 Digital Camera
Screen and not resonding to buttons.HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Black and whiten in a cracked form indicates damage. Sounds like a drop/cracked lcd.
May 14, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Cracked Camera
No easy fix. Pressure or impact is the usual cause of a cracked LCD. Try not to get the black stuff on anything....it's pretty toxic! The screen needs to be replaced (assuming there's no other, internal damage). They are usually in the range of $75 US.
Feb 19, 2008 | Nikon COOLPIX S200 Digital Camera
Screen black
If screen is black on both the playback and camera modes then LCD unit is probably cracked more likely it needs replacement.
Dec 02, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
LCD display cracked
You can replace the lcd screen although you do need to be careful. You camera has a flash capacitor that contains 300 volts and if you short it out you can easily fry the camera circuitry. You can check on ebay for an lcd or call fuji usa. I will warn you though their parts department isn't the most helpful.
Nov 13, 2007 | Fuji FinePix A303 Digital Camera
Cameras Logo
143 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
