Flat Panel Televisions
Problem for Panasonic Flat Panel Televisions
Generic problem for all Panasonic Flat Panel Tel...
I was watching tv when the screen sud...
By pteri2142 on Sep 10, 2009
I was watching tv when the screen suddenly went blank. I tried to power off and back on. The power button blinks a red light and nothing happens
Solution #1
posted on Sep 10, 2009
Not Rated)
maxquattro
Rank: Master
Rating: 83%, 3 votes
The TV has sound, but no picture.
The lamp is the most common part that causes this symptom. If you have purchased a new lamp already, click on the “Signs of Lamp Failure” link below to check your lamp or contact who you purchased your lamp from for a warranty claim. Look at the indicator lights on the front of the TV and use our chart by clicking the link below to find out what error the TV is displaying to help you. If you have not purchased a new lamp, the lamp is the most common and cheapest repair for this symptom. A defective circuit board can also cause this symptom in which you should contact a certified/trained TV technician.
If your lamp shows any of the signs listed below, there is a high probability your lamp is defective.
Find DLP lamps by model number
Common Signs Of Lamp Failure
- Cloud or haze near the center of the lens.
- The burner (the stem in the center of the lamp) is broken
- The burner has a white bump on it (usually near the bottom)
If the lamp does not have any of the characteristics described above, you check by brand below for LED flashing light codes to keep troubleshooting.
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
Is the Apex ld4088 a realiable set?
Answer
trying to find ot who makes vivo plasmas
Answer
I have tried all of the codes on Directv menu & Emerson Just bought my 32 inch Emerson today
Answer
I need the remote control codes for a Apex brand TV
Answer
26 inch color lcd TV 4 years old sony....is now only showing a black and white picture....not sure... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic Flat Panel...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
Panasonic
(316) 283-8873
Panasonic
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
