Question about Whirlpool AWG329 Front Load Washer/Dryer
Whirlpool washer/dryer Awg338 trips the mains?
My machine works fine on a normal wash cycle, but as soon as I depress the 1/2 Load / Dry button, the machine trips the main board fuse for that circuit?
I have looked everywhere for a solution but can find no other refernece to this problem.
Any help would be great thanks.
  • shane252 Dec 16, 2007
    I appreciate your help, but think it could now be a thermal fuse, which I am present trying to source.
    if not I am going to get a new one in 2008.
    Merry Xmas & Happy new year by the way.
  • awg338bust Mar 04, 2008
    got a AWG338 that just started tripping the mains when the dryer is switched on, did you find a solution ? or did you junk it.
Can't help you with your problem, but I also have a AWG338, that is coming to the end of its life. If you are after a second hand one for spares email me
Posted on Dec 14, 2007
Hotpoint WD440 Washer Dryer machine is tripping the electricity, anyone know what could cause this?
check that your skin pipe is not blocked....happend to me with different make washer.....kept tripping when it came to pipes were clogged with hard oil/grease soon as a clean the pipe it was fine
Mar 12, 2013 | Hotpoint Aquarius WD640 Front Load...
Whirlpool AWZ410 Washer/Dryer Washes But Will Not Dry!
I have the same problem. The half load / drying button is pushed in; the drying time set; I've reduced the load to almost nothing, but it won't dry. I've tried numerous cycles. The clothes spin, but are still damp at the end.
How would I go about checking my lid switch or fixing my clutch, if that's the problem?
Sep 04, 2009 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool AWG338 - Missing temperature control knob call me and i can ship one out
Jun 24, 2009 | Whirlpool AWG329 Front Load Washer/Dryer
Water not filling on washer
the inlet filter is probably clogged restricted and/or inhibited flow of water into your machine.
These things happen, and cleaning out the filter is a good first step to finding the problem.
May 11, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Wash machine sometimes gets stuck on rinse cycle & dryer not dry
Sounds like the drain hose for the washer is too far down in the stand pipe at the wall causing a siphon effect, try raising drain hose a little. The dryer sounds like the vent line from back of dryer too wall is pinched causing an air flow obstruction. Hope this helps.
Mar 19, 2009 | Whirlpool Washing Machines
Turn washer dryer on ok, then close door then curcuit trips
check the wiring and make sure nothing metal is on the motor because your dryer has a short in it somewhere
Dec 23, 2008 | Hotpoint Ariston Aquarius WD420 Front Load...
How do you get the dryer to work on the combo
You need to have the half load / dry button depressed PLUS have indicated the number of minutes you want it to run for...
Nov 14, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Oct 28, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Whirlpool AWG329 Front Load Washer/Dryer Logo
214 people viewed this question
Dan Webster
Dan Webster
Sal De
