Question about Hotpoint Dryers
Hi Can any advise how i add a new belt to a hotpoint 9324 dryer ? Is it from the from or rear & if possible the configeration how the belt goes around the pulleys at the bottom. Thanks Graeme
  • gdb01 Sep 11, 2009
    Hi Controlfrk,
    Sussed it now thnx.
  • Controlfrk
    Controlfrk May 11, 2010
    Model number important but hotpoints usually change from the front.
To replace belt or heater element you must remove the front panel complete with door.
Screws are different sizes in different places so note where they belong as you remove them.
1. Remove 2 screws at rear top which go through the brackets holding the top panel, slide back the top panel a little and lift it off.
2. Pull off the rotary timer knob and remove 2 screws beneath.
3. This is the tricky bit! Remove the the plastic panel which covers the switches etc.. This panel has 5 plastic fingers which secure it to the metal plate behind, locate the ends of the fingers where they pass through the metal plate. Using a metal rod or punch and a hammer, tap the ends of the fingers to push them back through the holes easing each in turn a little at a time to avoid distorting the plastic unduly.
4. Open the door and remove the 4 screws then remove 3 screws at the top and 3 screws at the bottom of the front panel. Lift and ease forward the front panel, unhook the door catch release wire, pull off the electrical connectors and put the front panel aside.
5. Lay the machine on its back and remove 1 screw holding the element housing to the top plate and pull off the electrical connectors.
6. Fit the belt around the drum, through the idler pulleys and over the motor spindle.
7. Put it all back together.
Posted on Sep 11, 2009
Hotpoint ultima TCD970 dryer squeaking
hi check rear bearing is not worn push at rear of top of drum inside if you can feel it lift replace bearing or it could be belt wheel check bearing 1st
Mar 02, 2014 | Hotpoint Dryers
Picture of how the dryer belt for a hotpoint electric dyer goes in
Hi cherylannroo....
Here is a picture of how to route your belt.
Please take time to rate me
Sep 26, 2011 | Hotpoint Dryers
My condo has a Hotpoint dryer. It is about 3 years old and last fall it no longer dried. I took the dryer hose off from the wall and the dryer works fine, heats the condo. The dryer vent goes into the...
Hi.
With most Hotpoint/GE dryers the blower motor is not spin by a belt. The problem is unlikely the blower motor. The problem is lint in the air ducts and in the blower housing. The lint results in overheating and the high limit switch cuts off the power to the heater (burner or element depending on the model).
As a result the dryer does not heat up.
Access the heating group and remove lint from the air ducts. Also clean the lint filter.
Hotpoint appliances are built by GE. Below service manuals for different GE-manufactured dryers:
Technical Service Guide
Service manual
ELECTRIC & GAS DRYER SERVICE MANUAL(Kenmore)
Jun 14, 2011 | Hotpoint Dryers
Hi i've got a hotpoint condenser dryer it's
the belt may be off/broken, motor bad, or idler assemblage.
Here is a website with the routing of the belt the Hotpoint is( General Electric (GE) - Large Capacity Models 1970-1990):
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to replace the belt:
http://www.ehow.com/how_6100255_replace-hotpoint-dryer-belt.html
May 08, 2011 | Hotpoint Dryers
Can't work out how to fit new belt to my tumble dryer it's a hotpoint aqurius dryer duluxe TL22.
You need to remove the rear panel the top console panel,,and then remove the whole cabinet to gain access to the drum and belt.
Then you need to release the front panel at the top to enable you to fit the belt.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
Busted belt want to replace with new need a picture of what a properply instaled belt looks like so I can do it myself
With out knowing the make and model of dryer, it is not possible to tell you exactly how the belt will fit, as there are many configerations as to which way the belt could go round various pulleys.
The only jhing in common to them all, is that the belt obviously goes round the drum.
Really need more info
Hope this helps
Dec 16, 2009 | Dryers
Hotpoint bearing lubricant?
No lubricant is req'd..The rear drum bearing is already impregnated with lubricant.
Dec 13, 2008 | Hotpoint NWXR473EV Dryer
New dryer belt configeration
loop belt around drum gather belt at bottom feed left to right through bracket opening pull up and fit belt around motor shaft flat side of belt will be on bottom side of pulley doward pressure of pulley will put tension on belt
Jun 18, 2008 | Whirlpool LER5636P Electric Dryer
Changing belt
ok hi pretty lady
ok back to dryer, belt go's around drum and tension pully at bottom then to the electric motor
Jan 20, 2008 | Dryers
Dryers Logo
85 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
