Question about Canon PIXMA MX850 Multifunction Printer
Error code 6A00 and flashing orange light (12 flashes). Fairly sure this is the waste ink "counter". I can get to the service code using the restart and power buttons, but not sure what to do next to reset the waste ink counter.
  • 1 more comment
  • wotto Sep 11, 2009
    I've now had the printer in pieces and cleaned everything in site. Re-assembled. Same error - 6A00. I've had a long look at www.fixyourprinter.com and all their forums and am sure I need to reset the waste ink counter - once I get to the service code area on the printer, does anyone know what combination of keys is necessary to reset the waste ink counter? This is a Canon MX850, multi-functional device, not an i850 bubble jet printer.
    Thanks
  • wotto Sep 13, 2009
    Hi Ginko,
    None of the procedures got me into the Service Menu!
  • wotto Sep 15, 2009
    I have cleaned the printer internally and partially dismantled. There is no mechanical jam and no paper debris blocking anything.
    I've looked at lots of articles on fixyourprinter.com and I would really like to try to reset the waste ink counter. Do you know how to access the Service Mode for this printer? It is an MX850
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Open the cover, move the cartridges to the centre, and then press the pad of absorbent paper towel onto the waste ink pads. You can locate the waste ink pads to the right of the cartridges. This will absorb a lot of ink in the pads and that will remove the warning after you reset the printer waste ink tank counter. You can reset your Canon Printer by following this procedure—
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button 4 times for waste ink counter reset.
5) Turn off the printer.( it must be turn off) then turn it on again.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 15, 2009
  • 298 Answers
Check out the following. It's a mechanical jam.
http://www.fixyourownprinter.com/forums/inkjet/37440
Posted on Sep 13, 2009
  • Canon Master
  • 19,396 Answers
6A00 is a problem in the purge area. 6a00 is often displayed after a mechanical problem. Standard solution is taking apart the printer and loking inside, behind the printheads for broken parts, paper or foreign objects.
To start unplug printer power cord , plug back and see if the error is still there.
You can try manually moving the print heads following instructions here: Solution Canon Pixma
If that does not fix the problem, then the printer must be disassembled.
Here a discussion on 6A00: Canon PIXMA MP800 Error 6A00 - fixyourownprinter.com
Posted on Sep 10, 2009
  • Ginko
    Ginko Sep 11, 2009
    Hi
    Try the procedure below, it works on most MP/MX series:
    1. Service menu: Menu -> Scan -> Copy -> Scan (one at a time in sequence)
    2. Select "TEST MODE"
    3. Select "[8] ETC.."
    4. Select "[4] EEPROM CLEAR"
    5. Select "[1] INK COUNT"
    6. Press the [OK] button.
    7. Press the [Stop/Reset] button (returns you to the TEST MOD sub-menu))
    8. press the [ON/OFF] button (which resets the printer)
    Here alternative procedure:
    Reset
    Waste Ink
    1) Enter SERVICE MODE.
    By pressing Menu, Copy, Scan,
    Copy, Copy
    2) Select TEST MODE.
    3) Select [8] PRINTER TEST in TEST MODE.
    4) Select 3. [EEPROM CLEAR].
    5) Select 0. [INK COUNT].
    6) Press the [Set] key.
    7) Press the [Stop/Reset] key (returning
    to the state of 3)), and then press the [ON/OFF]
    key.
    Here complete procedure for MP/MX:
    Press MENU-SCAN-COPY-SCAN
    Cycle through options to #7 PRINTER, Press OK
    Cycle through options to #5 (Ink Abs Cap) Press OK
    It should say “SUCTION” on the screen. Enter “0′ (Zero). Now either press OK
    Turn printer off and then back on.
    Other Way:
    MP750 / MP780 reset instructions..
    These instructions Will allow you to reset the ink waste counter on your Canon MP
    2. Select “TEST MODE”
    3. Select “[8] ETC..”
    4. Select “[4] EEPROM CLEAR”
    5. Select “[1] INK COUNT”
    This instead is procedure for IP
    1. Start with printer OFF
    2. Hold down RESUME and then hold down POWER
    3. Release RESUME
    4. press RESUME twice, then release POWER
    5. let green light blink until printhead has finished moving.
    6. Select functions below with RESUME, execute with POWER
    0 presses - green light - Test Print (exit service for i960)
    1 press - orange light - EEPROM info print
    2 presses - green light - EEPROM initialise
    3 presses - orange light - reset waste ink counter.
My printer is coming up with the error code 3 which is flashing. can you help please
Clear error codes
First make sure that there isn't anything keeping the carriage from moving freely.
Then follow the instructions below:
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Codes:-
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Jul 22, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
MP830 has a 6A00 code
The 6A00 is a Canon generic code for paper path jam and seems to be a very common problem with these printers. Click Here to read some resolutions to this issue that may or may not work for you.
Nov 23, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon MP 160 flashing 2E
Found this on our site:
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this method
service mode. (Waiting formenu selection)
button pressing
LED Function Remarks
procedures below.
procedures below.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error code 6A00
6A00 error on a Canon IP4200 is an AP Postion Error. This means one of three things. A problem with the sheet feeder, Logic board or the Purge Unit. Sadly these part are either working or not working and are difficult to repair. You could try resetting the EEPROM on the unit by entering service mode. A service manual will show you how to do that:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
If that helps please rate my solution
Nov 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Error Code 6A00
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving-staying in the center. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Apr 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Had paper jam. removed paper, now getting 11 flashes, but cannot clear error as per manual instructions. getting service error 6A00.
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it(purge unit). The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
Apr 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
CANON MP830 PRINTER ERROR CODE 6A00
6A00 is a purge unit fault, if you have have a years canon warrenty i would call them and get a engineer out to investergate the fault, If not strip machine and and see if the purge unit is moving back and forward. it could be that the carriage unit is stuck on the purge and the carriage unit cant move.
Hope this helps
Mar 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Pixma IP4000 12 flashing lights error 6A00
IP4000 12 flashing lights error 6A00 problem, and notify you when a new solution is offered.
Dec 02, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA MX850 Multifunction Printer Logo
70 people viewed this question
old marine
old marine
