Question about Dryers
Dryer stays hot after shut off overnight - Dryers
  • yadayada
    yadayada May 11, 2010
    gas or electric?
  • 53 Answers
If it is an electric dryer, pull the heating element off and make sure it is not grounding out somewhere. It may be hard to see so check it carefully.
Posted on Sep 10, 2009
Our 4 cycle whirlpool dryer runs for 5 -10 minutes gets hot and shuts off.
check to see if the dryer vent is clogged up - When a dryer gets to hot it will shut off to prevent catching fire!!! If the vent is clogged it forces the heat from the dryer to stay in and that causes the dryer to over heat!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
Jun 25, 2011 | Dryers
When i turn on the dryer it only stays hot for 10-15 minutes then it cools down, whats the problem
sounds like thermostat but there is a safety feature that shut down the heat if it gets too hot, becasuse of a blocked venting within the dryer
Feb 26, 2011 | Kenmore 72822Gas Dryer
Ive rinsed the bottom filter as advised and dryer still shuts off
also wash the door filter,it may need to be serviced
May 15, 2010 | Asko T701 Electric Dryer
The dryer will not stay on the hot setting for very long, it will shut itself off after about 5 mins. it will stay on for the other 2 heat setting but not the hot setting. please help
You need to check your high limit switch with it located on the vent pipe on the back of the system. The limit switch is saying that your Dryer is getting to hot when it may be or may not be. Most of the time it is not getting to hot. Just when it notices heat it will shut itself off. The other thing that i recommend is that you clean your lint trap and vent pipe all the way to outside.
Jan 02, 2010 | Asko T720 Electric Commercial Dryer
Dryer shuts off after about 5-10 minutes of running. The top of the dryer is hot.
Howdy: There is a thermostat inside the unit in the back. If this has lint clinging to it, it will shut off unit. Also the firing ignitor has two soleniods
that stick and turns off unit too early. But with the top of dryer hot I would say the heat always stays on and the thermostat shuts off ignitor. The firing should be a pulse type heat, not a constant heat. Good luck - Doug
Dec 08, 2009 | Kenmore Dryers
Dryer doesn't stay hot, starts out getting hot, then the heat shuts off
gas coils part 12001349.are bad,most of the time when the coils are failing they work until they heat up,they are located on the top of gas valve
Dec 02, 2009 | Kenmore 73932 Gas Dryer
Clothes dryer is overheating and then shuts off
Your vent pipe is probably clogged with lint. Clean out, and blow out, if possible, If the vent is clogged, the air cannot properly escape and all that heat stays in the dryer, which probably sets off some kind of themal protection switch, preventing the dryer from running until it cools down.
Oct 10, 2009 | Kenmore 73932 Gas Dryer
Dryer not staying on.
High limit trips due to over heat. Clean vent and line and filter.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 06, 2009 | GE DBSR453EBWW Electric Dryer
Won't stay lit
You ignitor is working and sensor is working because it will fire up. so those pesky coils are intermittant because they get hot and quit cool off and work some more . replace them
cc8e664.jpgHere is a little ditty I wrote some time ago about this subject
INTERMITTANT COILS
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 07, 2009 | Maytag MDG6000 Dryer
Maytag gas dryer wont stay hot
Check the exhaust to see if it is clogged. If not, you may need a pair of gas valve coils (not very hard.)
Replace the coils if you see the ignitor glow and shut off, without the gas valve opening up.
Mar 09, 2008 | Kenmore 63942 Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
