Question about HP Compaq Presario V2000 Notebook
I want to wipe it clean. i've tried the f8 f12 and f11 keys when it frist turns on.....help
  • 61 Answers
Run the restore CD that came with the laptop. It will automatically format the hard drive during the reimaging process.
Posted on Sep 10, 2009
Help with d2d recovery for gateway Lt 20 notebook
Try tapping the Del key. Also try F11, if neither of those work, then try these combos below:
Fn+F2
Fn+F8
Fn+F10
Fn+F11
Fn+F12
Shift+F2
Shift+F8
Shift+F10
Shift+F11
Shift+F12
Remember to hit these key combos before Vista loads, only when you sure the keys were pressed, cross it off the list on move on. When you do determine the correct key combo, please post back here, it will help others with the same question.
Oct 30, 2014 | Computers & Internet
When i press f8 or f11 there is no factory image restore
Are you even getting the pre-Windows Menu? Sometimes you have to try all the F keys (F1 through F12) one at a time while booting, until you find it. It is normally F2 or F8 or F11 or F12. Once you find it, select the restore option. Be warned that this will delete any documents and files you have stored. You might try the "recover to a previous date" option 1st. If the restore or the recover does not work (corrupted or missing) you will have to get the recover CD's from Dell.
Aug 07, 2014 | Dell Inspiron Computers & Internet
How do you factory resotore a Dell Opitiplex 755 computer?
If the hard drive was replaced or reformatted, the factory restore was erased. If so the only way is to load OS from CD .
Jan 30, 2013 | Dell Optiplex 755 Minitower Desktop...
I have a dell inspirion 531 and cannot get it to start...tried f8 & f11 ad nothing works...what r my options to set back to factory
if you've tried f8 and f11 (although i think you should be pressing f12) then there is only one logical step and that is to reinstall. you can download a version of whatever windows OS it came with and use the sticker on the machine for the serial key. you can then go to support.dell.com to download the correct drivers for your hardware.
May 08, 2012 | Dell Inspiron 531s Desktop Computer
My Fn + key is not working on my lenovo y450 laptop.pls advise.
it migt be turn off. try to press Fn + F1 + F2 + F3 + F4 + F5 + F6 + F7 + F8 + F9 + F10 + F11 + F12 to turn OFF or to turn ON. or you may go to BIOS to turn it on from there.
Sep 11, 2011 | Lenovo IdeaPad Y450 Notebook
My brothers stupid friend tried to fix his computer (Dell 6400 inspiron) had vista on it and instead of using the revcovery manager i believe he wiped the OS and reinstalled an unlicensed version of XP...
I believe that when you turn it on, you have to hold down the CTRL and either F10 or F11 (I've heard of both working) and that should get you into the recovery partition.
Aug 14, 2011 | Dell Inspiron 6400 Notebook
Tried F6 and F11 to reboot my compaq mini notebook, it's not working. When I turn on the notebook it shows F9 change boot device order and F10 BIOS setup options then it goes to a black screen with...
Hi
it may be worth trying the F12 key at startup it may work for you
good luck
or try the F8 key on start-up and try the back to last known good configuration
Jun 12, 2011 | Compaq Mini 110c-1001NR Notebook
I need to know what the keys f1-f12 keys usage.
The uses for the function (f1-f12) keys varies based on which program you have open at the time. Different programs use them for different things.
However, your computer also has some default uses for these keys when combined with pressing the fn (function) key.
fn + f1 locks computer
fn + f2 changes our power use profile
fn + f3 puts the computer to sleep
fn + f4 puts the computer into hibernation mode
fn + f5 changes the display/output mode
fn + f6 decreases the screen brightness
fn + f7 increases the screen brightness
fn + f8 enables/disables wireless connections
fn + f9 enables/disables the touch pad
fn + f10 turns the cursor overlay on/off
fn + f11 turns the numeric overlay on/off
fn + f12 turns scroll lock on/off
May 05, 2011 | Toshiba Satellite Pro L300 Notebook
Wi fi button
Look carefully on your "Function" keys example, F1, F2, F3 to F12 that are located above your keyboard. On each function keys, there is an icon. One of those is wi-fi. Find which function key has the wi-fi icon then find key to activate those functions. It is called "Fn" key (located in the bottom of your keyboard near "Ctrl" or "Alt"). Now press and hold "Fn" + "F#" then release. This should turn on your wi-fi. On mine, I have wi-fi on "F8" so I would press "Fn" + "F8".
Jan 12, 2010 | Computers & Internet
Keyboard F1 to F12
F1 - F12 Function Key Usage
Printer Friendly Version
F1:Help. Click F1 Key can load the help file of the program.
F2:Rename. Select a folder or file, click F2 to rename it.
F3:Search. On desktop, click F3 to load the search form.
F4:In Internet Explorer, click F4 will list the URL Address field.
F5:Refresh. Use it to refresh the web page in Internet Explorer.
F6:In Internet Explorer, click F6 will jump to address bar.
F7:It can be used to insert ^C in command prompt.
F8:When windows startup, it can load the startup menu.
F9:In Windows Media Player, it can increase the volumn.
F10:In Windows Media Player, it can decrease the volumn.
F11:In Internet Explorer, click F11 will switch to Full Screen mode.
F12:In MS-Word, it will show out the "Save-As" dialog.
Take this link u will get all the Function Keys description
http://www.computerhope.com/issues/ch000306.htm
Aug 31, 2008 | Computers & Internet
HP Compaq Presario V2000 Notebook Logo
119 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
