Question about Refrigerators
Jenn air jcd229key restricted
Guys, I need advice and any help will be appreciated.
I have Jenn Air model JCD229Key. I think it has restricted/plugged
system. I have troubleshooted it so far that I know 100% that
compressor, thermostat and fans are working fine. I need your help to
figure out where is the system plugged. When i fire it up it, compressor
starts buzzing and working normally. There are two pipes that lead from
the compressor to evaporator (one is thicker and another one is thin
like toothpick) These two pipes start freezing(frosting) immediately but
the thicker pipe starts to defrost, and first two evaporator
lines/circles (look like coil)- they are frosted/frozen too. So you can
wipe off the frost with finger but hey freeze immediately - but nothing
above that gets frozen. THANKS
  • 410 Answers
The system carries oil around naturally but sometimes it will pool up in the evaporator area causing a restriction at the restrictor/capillary tube. the fix is to recover refrigerant flush the restrictor tube with nitrogen replace the drier evacuate the system and recharge with recomended amount of refrigerant.
Posted on Dec 11, 2007
Jenn air microwave model jmv820aas shut down completely, what do i do?
I'm guessing you might mean JMV8208AAS?
If so, then the service manual is at our site here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can order Jenn Air parts here.
Your problem will be either the line fuse, or one of the thermal cutouts / TCOs in the unit.
In case it needs circuit board repair, see this link.
Nov 27, 2012 | Jenn-Air JMV8208AAS Microwave Oven
I have a Jenn air model 730-0163 natural gas grille I need to convert to propane. can this be done and what parts and where do you purchase the?
As I told a questioner, yesterday. Yes, I believe a kit is available. If you purchased this Jenn Air grill from Lowe's, it was manufactured by Nexgrill Industries. Not Jenn Air. In any event, Lowe's no longer sells the Jenn-Air line of grills. My very best advice is to contact Nexgrill Customer Service @ 800-913-8999. In addition to the burner orifice parts you'll have to have, you will also need a grill tank Hose/Regulator Assembly.
Hope this helps and Happy Grilling!
Mar 18, 2011 | Grilling
I have a jinnair model JA460N Gas Grill that currently runs on natural gas, I need to convert to propane. Is this possible and if so is there a conversion kit available?
Mar 16, 2011 | Jenn-Air Grilling
I need the wall template for a jenn air micro wave oven model no.jmv8208ds
That is part number W10188240 and you can order it here.
You can download the installation instructions free here.
The owner's manual is here.
Dec 18, 2010 | Jenn-Air Microwave Ovens
WHAT IS THE TRICK TO CHANGING THE UNDERNEATH LIGHTBULB IN MY JENN AIR MICROWAVE?
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Dec 06, 2009 | Jenn-Air Microwave Ovens
I Have to replace (Model M167W) it with some thing the same size. S/N 10674784KS
Whirlpool / Jenn-Air customer service is here and they should be able to advise you on a "drop-in replacement".
Aug 30, 2009 | Jenn-Air Microwave Ovens
My father's old Jenn-Aire microwave, Model # M170, has a rusted bottom and we need to replace it. Is there a model that is of the same dimensions so that we can replace the unit inside the cabinet above...
You can contact Jenn-Air customer service and they should be able to tell you if there is a "drop-in" replacement for your model.
Aug 19, 2009 | Jenn-Air Microwave Ovens
JMV8186AAB microwave oven
You can download Jenn-Air/Whirlpool owner's manuals and installation instructions here.
Dec 15, 2008 | Jenn-Air JMV8186AA Microwave Oven
Freezer/Fridge work SOMETIMES
Sounds like you have a bad relay on the compressor or a bad compressor. If the compressor is a Tecumpseh brand then it is most likely the problem.
Oct 04, 2007 | Jenn-Air JCD2290HES Side by Side...
Refrigerators Logo
126 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
