Question about Gb Electrical 1 30 Amp Ground Fault Circuit Breaker
I HAVE JUST BROUGHT A DODGE CORONET CAR 1958 AND CAN NOT FIND THE FUSE BOX OR THE FLASHER UNIT. CAN YOU HELP ? LARRY
    Sergeant:
  • 384 Answers
Larry that car is not new.
When that car was made it was only about a month after they invented the wheel.
Does it have the screw in fuses? If yes, use a coin between the contact.
Flashers didn't appear until the 60's as streakers.
Lot of luck with that piece of **** it was junk in the 50's.
Posted on Sep 10, 2009
Need a diagram for how to find the flasher in a 1999 dodge stratus..it's not in the fuse boxes
Simple method without mystery:
  1. Turn blinker flashers on;
  2. Listen for clicking;
  3. Find source of clicking. It is the flasher. :)
NOTE: Emergency flashers and blinkers usually use a separate flasher unit, but one is close to the other. If your blinkers do not work but your emergency flashers do, find the emergency flasher unit by finding the source of clicking, then locate the blinker flasher nearby. They will ALWAYS be underneath the dashboard on the driver side.
May 11, 2015 | 1999 Dodge Stratus
TURN SIGNAL FLASHER LOCATION FOR 1999 RAM 2500 HOW DO YOU REPLACE THE TURN SIGNAL FLASHER WITH THE HEAVY DUTY FLASHER #552 SO I CAN TOW A TRAILER
Hello Patty - Check the back side of the interior fuse box, should be between the steering column and the fuse box. You should be able to hear it "click" when in use. Most 2500 Rams had a flasher unit that was trailer ready. You may not need this upgrade. I hope this helps.
Oct 07, 2011 | 1999 Dodge Ram
My signal lights work at times at then nothing so I bought a flasher one auto store clerk told me no flasher on these trucks the other store sold me a flasher . I cant seem to find a flasher in the...
there is a flasher in this.you don`t say what year and model of truck this is so if you turn on the hazard flashers and find its location, the turn signal flasher looks like the hazards but is a different one.the signal flasher will usually be in the same area so this should help you find it,it will be under the dash somewhere or on the fuse box either front or rear of the fuse box.
Aug 09, 2011 | Dodge Ram 1500 Cars & Trucks
Turn signals will not work tried everything what could be my problem?
Start from the fuse box, check the fuse of the turn signals, now check the cluster switch to give the output as desired to the flasher unit as it selects left or right.
Now a voltage of the flasher switch will confirm if the switch is good or the flasher unit is faulty.
Feb 04, 2011 | 2000 Dodge Durango
I have a Dodge Coronet Car 1958 and have no idea where the FUSE BOX is located. also the turn Signals Unit has stopped flashing at the Off side Rear Indicater and I can not find the UNIT for that. Can...
Dodge fuse blocks are usually upside down at the base of the dashboard on the driver side, very near the flasher that would drive the rear turn signals, there are two, one drives the turn signal and one drives the Emergency flasher. With any flasher working, you can feel which one it is, you can find it by the sound it makes.
Sep 11, 2009 | Car Audio & Video
2000 Dodge Ram - No hazard flashers
Possibly blew out the hazard flasher unit. Check the flasher unit (usually there are 2, one for directionals and one for flashers).
Jul 07, 2009 | 2008 Dodge Ram Pickup 1500
I cant find the flasher unit location for my 97 dodge intrepid.
Check down under dash by left side of brake pedal area.
Apr 30, 2009 | 1997 Dodge Intrepid
Turn signals and hazard don't work
Next best guess is the flasher unit has failed, this could be your little blue box, pick up a replacement at any auto parts store and replace it.
Apr 15, 2009 | 2005 Dodge Caravan
Dodge Coronet
What year? I do have a '71 manual which covers the Charger, Coronet, Dart etc. but since I still own 2 '71 Dodges, will keep need to keep it. You might check out allpar.com their forums.
Jul 09, 2008 | 1983 Dodge 400
Gb Electrical 1 30 Amp Ground Fault Circuit Breaker Logo
77 people viewed this question
Top Gb Electrical Electrical Supplies Experts
Steve
ken skalski
Are you a Gb Electrical Electrical Supply Expert? Answer questions, earn points and help others
