Question about GE Profile JGP636 Gas Cooktop
No spark to ignite gas on cooktop
No clicking at all. unit is pluged in
  • rchan2 Sep 10, 2009
    this unit has electronic ignitor. it does not have a gas pilot light
  • 22 Answers
Shut off the stove. Then lift up the range top and you will see pilot lights. Remove the cover on the pilot lights. They could be blown out, but usually they are just dirty. Take a pin and poke it through the hole, then carefully scrub the tubes with a brush that go from the range to the pilot light. When your done with that....use a long match and light the pilot light, make sure no gas is on when you do this. No flames will come out, but it doesn't hurt to be extra careful.
This just happened to me so good timing!
Hope this helps
Posted on Sep 10, 2009
I have a 30 in jgp336 gas cooktop that fails to ignite when it clicks what is wrong, it worked a few days ago and suddenly stopped working
usually the spark module is not put back together properly.
1 make sure the spark unit is clean
2 make sure the gas jet is pointing towards the sparker
3 make sure there is no aluminum foil or other metal near the sparker pulling the spark away from the gas
Jul 06, 2014 | GE 30 in. JGP336 Gas Cooktop
The igniter spark for all gas rings remains on permanently without pressing down the gas flow knobs. I can see nothing prompted this - I just came into the kitchen one morning to hear the igniter clicking...
This could be a problem with your spark module. its an electronic box either behind or under the cooktop. it sends the spark to the spark tip, which then ignites he gas. So in my opinion i would say it is your spark module.
Feb 02, 2011 | Smeg 23 in. SER34AX1 Gas Cooktop
Profile JGP636 Gas Cooktop: my ignition for the gas cooktop is not clicking...
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 17, 2010 | GE Profile JGP636 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Igniter clicking when all four knobs in off position after water spill
It is possible that once the unit dries out the clicking will stop. If it doesn't, you will need to call someone to have the problem addressed. You will need a spark module and or an ignition switch(s).
Oct 28, 2008 | GE 30 in. JGP336 Gas Cooktop
My GE gas cooktop not working. Model#JGP336BEV1B8
Are the other 2 burners lighting with the spark? If so the other 2 are either shorting before the burners or the sparkers are faulty.
To service, the cooktop needs to be completely removed from the bench and disconnected from the gas as the access is from the bottom.
I could step you through it while watching, but to do it this way is not a good idea. It's probably worth ringing a serviceman.
Dec 26, 2007 | GE 30 in. JGP336 Gas Cooktop
1 burner wont stop clicking on miele cooktop km 344
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
May 06, 2007 | Miele 36 in. KM342 Gas Cooktop
GE Profile JGP636 Gas Cooktop Logo
284 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
