Question about i-mate Jama 101 Smartphone
Mobile window was not starting
When i will put battery blue screen and red light only shown it will not connected to window
2 Suggested Answers
Buland Khan
  • 297 Answers
SOURCE: when i will put battery blue screen and red light
reinstall sa software older version is damaged
Posted on Nov 14, 2009
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
I jhave a Jazzy Select GT power chair, I put the charger on it when the light shown red and green, when it powers up when charged the both lights will turn green, but now it will do nothing with start
Hi Gloria,
The first thing you need to do is measure the voltage at the charging socket of the Joystick (outside 2 pins). This will determine a lot of things, so I can guide you further.
Nov 21, 2014 | UPG 12V 35AH Jazzy Select GT Power Chair...
T mobile touch pro 2 doesn't power on.
Take the battery completely out of it and let it sit for about 5 minutes. Then install the battery and see if it will turn on normally.
Don
Apr 06, 2012 | HTC Touch Dual Slider Smartphone
Flickering bulbs
You posted under EJ500 Intermatic battery-operated timer.
If you have different timer, add a comment.
I have tested EJ500 timer.
A) If this is new single-pole installation and lights click on-off when timer turned on, then you connected red wire where blue wire should be connected.
Manual says for single pole switch:
Timer-black-wire to Hot; Timer-blue-wire to Load (lights)
Here's how to wire timer correctly:
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-blue-wire. Choose either one for now.
3) Put wire nut on red wire.
4) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-blue and timer-black wires.
B) If you are replacing 3-way switch, view wiring diagrams shown on link below, and then add a comment saying exact color of wires. To wire this timer for 3-way can require additional wire between switches. This is because EJ500 blue wire must always go to Load (light, fan, motor)
http://waterheatertimer.org/ST01C-program.html#EJ500-wire
C) If this is older timer that stopped working, check your bulbs. Then check timer battery. Manual says if timer stops working and bulbs are good, and battery good, then reset timer and reprogram. How to reset timer. Press reset button while holding down Next/ON-OFF button.
EJ500 manual has long list of programming instructions: Add a comment if you forgot parts of programming.
EJ500 manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej500c%20-%20english.ashx
Nov 28, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
How to reset bluedio av890
Switch it off.
Press the on off switch for little long duration, till the Light glows steady/permanent (without blinking).
At this stage it can be connected to a device enabled with Blue tooth in "switched on" condition using the passcode "0000" (four times zero)
MUTHUPETCHI V (muthupetchi008@gmail.com)
Apr 15, 2010 | GE ON-SHLDR BLUTOOTH HDSET Wireless...
The battery of the mobile phone is not charging at all even though the charging sign is shown on the mobile screen
The you will need to see an expert or a technician to fix it up for you. This could be a battery fault, try purchasing a new battery.
Best regards
Feb 15, 2010 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
How do i sync supertooth light to a new mobile phone
Turn the blueant off by holding the green button until it powers down. Put your phone in discover mode (refer to your phone's manual) then power the blueant back up but hold down the green button until the light starts flashing red and blue. Now you should be able to see it on the phone. I just discovered my Samsung I910 wouldn't pair unless I used the windows on screen keyboard instead of the Samsung on screen keyboard.
Jun 11, 2009 | Blueant Supertooth Light Bluetooth Speaker...
W850i red light prob
not to worry this is a fixable problem..............take te phone to a mobile shop and have them reflash the firmware n custom pack back into the phone and this will correct the problem....the erom needs to be loaded back on the phone.
Nov 19, 2008 | Sony Ericsson K850i Mobile Phone
How do I turn bluetooth on and connect a Mobile phone to a Acer Aspire 5710G
Windows Mobility Center includes Acer-specific settings like Bluetooth Add
Device (if applicable), sharing folders overview/sharing service on or off, and a
shortcut to the Acer user guide, drivers and utilities.
To launch Windows Mobility Center:
Start Windows Mobility Center from the Control panel
Start Windows Mobility Center from the Accessories program group in the
Start menu
You should be able to turn on blutooth from there.
Please let me know if this helps.
Mar 17, 2008 | Computers & Internet
i-mate Jama 101 Smartphone Logo
Top i-mate Cell Phones Experts
270rexton
270rexton
Jax Planet
Jax Planet
Are you an i-mate Cell Phone Expert? Answer questions, earn points and help others
