Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Fridge runs good for 3 to 4 hours.then turns on but does not cool. i unpug for about an hour and then cools good for another 3 to 4 hours
  • 93 Answers
Are you sure the compressor is turning back on. I would bet that you have a tecumseh compressor in your fridge and when they get hot they don't restart till they cool. The bearings in them go bad. We replace those with Embraco compressors. You unplug it and let it cool down and that is why it restarts.
Posted on Sep 12, 2009
Samsung cooltech needs reset to keep cooling
HI.JAMES. shot in the dark.it might work for a quick cheap fix.ok 1-get a 24 hour ac plug in timer.plug fridge into it.set timer to run for 4 hours and off for 10 minutes.it might work.let me know if it does.better then PCBs and sensors etc.good luck.ali
Jun 19, 2012 | Refrigerators
Maytag msd2641kew fridge side is not cooling its warm . freezer is still cold notice some of the ice look like it was starting to melt a litte. turned freezer up acouple of hours ago stuff is staying...
Sounds like a defrost problem, is there ice on the back wall of the freezer? If so the defrost system has failed. The most common repair is a Part# 67004757 defrost thermostat and adaptive defrost board Part# 67004704. Even with the parts in your hand, you will need to de-ice the freezer to replace the thermostat in the freezer section, then unplug unit to replace the adaptive defrost board located in the controls of the refrigerator section. Normally it can take about an hour to complete.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 13, 2011 | Maytag MSD2756G Side by Side Refrigerator
Fridge works for about 3 weeks then freezer freezes up and fridge stops working i unplug it for 24 hours and it works for another 3 weeks same story??? what do i dooo? it is a ge side by side newer...
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts check if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Apr 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My Westinghouse freestyle fridge freezer is running but is not cooling the fridge at all.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
Mar 19, 2011 | Refrigerators
Refrigerator stopped cooling, then froze up, now defrosted and won't run,
Top of Form
Mar 02, 2011 | Refrigerators
My Panasonic refrigerator NR-B420T is not cooling, however the freezer part still cooling.
Top of Form
Since there is cooling on the freezer the fault can be the defrost timer. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Jan 05, 2011 | Panasonic Microwave Ovens
The fridge is not cooling!! The motor and fan are both making noises as though they are working and the freezer is working perfectly. I have turned the thermostat up to the maximum but still no cool air.
If there is no cooling on the fridge but the freezer is cooling then the compressor and gas pressure seems good. So to check the set for blocks in the ducts we must shut off the fridge.Keep it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
The fan making noise can be due to frost build up .If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
Do not set thermostat up to max but keep it to normal .So try this test from the outside and make your observations so that we come to the solution.
Oct 09, 2010 | Refrigerators
It runs all the time
Switch the fridge off for some time till the frost clears off. make sure the compressor has cooled off before you start the fridge once again.Switch on and checck if there is any ICE formation in about 1-2 hours. If so your compressor, gas and performance is good.
Now we need to check to see if the thermostat is cutting off. Having kept the thermostat in normal mode , the compressor must cut off in less than 3-4 hours. If not the thermostat is faulty. Also if you look on if the fridge does not shut offf in baout 8-9 hours of running then your thermostat, timer can be suspects.
However if there is no cooling reached in the first place then it is possible that the compressor or the gas pressure is down.
Check for leak if the fridge is old before you waste money on filling and losing .
Sep 01, 2010 | Refrigerators
Bosch logixx fridge/freezer
please contact authorized service center for repair
Mar 28, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
245 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
