Question about Cycling
Bicycle type: bodyguard ergocycle 955 The buckle on the tension belt broke this is an old bike but I LOVE IT! Any suggestion ore help as to where i can get a belt and a buckle from is greatly appreciated.
I have the same issue. I love this bike and want to fix it. Did you get any help on where to find a new tension belt and buckel
Posted on Jun 05, 2010
  • aaabbb900 Oct 03, 2010
    In well asoorted stores where they sell rucksacks, they sell extra buckles. I am sure you can use one of those.
The waste buckle on my ergo baby carrier broke. I don't know how to go about getting it replaced.
Replacement buckle for your model can be found on amazon. Click here and take a look: Amazon com Ergo Baby Carrier buckle. I hope this was helpful. Cheers
Oct 09, 2012 | Ergo Baby Carrier
I want to replace my Pacific Bicycle derailleur parts.The parts that are on there are td-one and the bicycle is a mountain bike. the model number is R4446WMUT.Later on I would like to replace possibly the...
Are you in love with TD-One parts or would an upgrade to almost anything Shimano be a possibility? Look on eBay. A Pacific Bicycle or any bike sold by a department store isn't really what one would consider an upgrade-worthy project. A new bike better might be cheaper considering labor costs. Replacement of parts for failure might be worthwhile.
Sep 16, 2011 | Mountain Td-one Bicycle Front Derailleur...
I need 3 parts for the Bodyguard 955 ErgoCycle. I need a friction strap, 1230 mm; a fixing hook for friction strap; and a lock spring. I can't find a picture of one part called a Flywheel cpl, white...
If you can't find it with a Google search for "Bodyguard 955 ErgoCycle parts" then coming here is not going to do you any better. Note below that "wvlyon" was looking for similar parts in 2010 without luck.
Jun 27, 2017 | Cycling
I have a 1994 mercedes SL320 Conv. the seat belt light on dash will not go out. any suggestions
faulty seat belt buckle or wiring, first check wiring for seat belt buckle if wiring and connectors are OK require new belt buckle, is this information helped you?
Oct 26, 2010 | Mercedes-Benz SL65 Cars & Trucks
Diagram for the tension belt on a Body Guard 955 ErgoCycle
i also need help with this, if anyone can help us solve it it would be much appreciated
Sep 08, 2009 | Cycling
Treadbelt not alligned
Hi, Most all treadmills use the same type of belt tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Mar 04, 2009 | RTO Bodyguard T200 Treadmill
Seat belt release
you nee to replace the seat buckle and possible the tensioner/ the seat belt buckle is easy to replace its a torx screw 32 bit take it out and replace /disconnect the battery when removeing/ to check seat belt tensioner pull out see if it goes back like a yoyo and if it does then you may not need the tensioner/ Please rate my response Thank you
Jan 31, 2009 | 2004 Nissan Titan
Bicycle Rear Wheel Problem
Tighten the two pinion gear bolts that are holding the rear wheel, if the wheel is wobbling, then that is the problem.
If this does not fix the problem, you will probably better buy a new wheel, or replace the whole pinion gear and axis assembly, better to replace the wheel.
Oct 29, 2008 | Victory VegasLow 26 Men's Dual-Suspension...
Cycling Logo
1,608 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
