Question about Refrigerators
Fridge doesn't work
We unplugged our ge mini fridge, then replugged it back in, and the motor didn't turn on. our fridge hasn't worked since, what do we do?
    President:
  • 1,447 Answers
Check ac fuse or connector
Posted on Sep 10, 2009
Last night, the freezer door on my older GE Profile fridge got left slightly open. This morning, it was making a loud noise and some of the food inside was starting to thaw. I turned it off for awhile...
The door being left open would have caused frost to form around the evaporator fan motor and that would be the source of your noise.
If the lights are still working then it is probable in defrost, wait about 30-45 min and see if it turns back on. If not then you might have a different problem.
What is the model number for your fridge? The model number is normally in the fridge on the right hand side.
Mar 13, 2013 | Refrigerators
Buzzing sound in fridge
I had something similar in my White-Westinghouse fridge a few years ago. The bearings in the fan motor that circulates cold air went out. Unplug the fridge and remove the grille assembly at the back of the freezer. The fan will be behind it. Try spinning the blades with your finger. If they turn hard or if you feel excessive resistance, the motor is bad. Also, check to make sure insulation hasn't gotten into or is rubbing the blades. It's an easy fix if it's not under warranty. Usually two screws/bolts hold the motor in place, and a two-wire electrical connector. Don't forget to turn the fridge back on after checking it.
Oct 02, 2012 | Frigidaire Refrigerators
Display on GE Convection JSP968 keeps saying LOC ON when I try to turn it on?
the self cleaning lever (that locks the door) is moved to the clean position. try moving it to clean then back to the off position and that should fix it.
Dec 11, 2011 | GE JSP57 Electric Kitchen Range
I have a 32" LCD
Tries tv and cable box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The cable box to reboot and upgraded it software.Than go in to the tv Menu go to Audio Setting go down and do a resetting back to the tv factory setting.By doing these steps u have a great chances to get ur tv audio sound back.Not have the same problems after this than the tv Tuner signal board it is shorted in the audio ICS modjulation sections.Tries websites like Shopjimmy,com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 16, 2011 | Televison & Video
GE REFRIG. MODEL#TFX30PRYAA. side by side both
It sounds like your defrost control timer is working, but your defrost heater is most likely burnt out. It is a part number WR51X443
and is located behind the back wall inside the freezer. Turning the refrig off for 24 hours helped melt some of the accumulated frost, but not all. You will have to take that back cover off inside the freezer and melt all the frost with a hair blower, replace the defrost heater and reassemble.
Jul 01, 2009 | Refrigerators
I have a whirlpool fridge model #ed25oxww00 it works good for about 3-4 weeks then it starts to get warm.if i unplug it for a day and plug back in it good again. can you point me in the right direction to...
check the connection the the compressor and get your self some deoxit from radioshack its spray stuff works wonders and may fix your problem i got a mini fridge that way and fixed it the kid that had it didn;t have the time to work on it so it went on craigslist to me and now i use it all the time
Jun 28, 2009 | Whirlpool Refrigerators
Ge artic refrigeratior freezer stainless steel
Unplug / Replug the fridge. If doesn't work might be the mother board in back.
Jul 13, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
412 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
