Question about Apex Digital (AL-A300ATX) 300-Watt Power Supply
I have a apex DT250 and all of a sudden my tv screen is blank,apex does turn off and on,menu screen doesn't even come on..
  • 19 Answers
The DT250 has one or more bad 470uf 25v capacitors. You should replace all four. Look at some of these youtube videos for how do do the replacement.
http://www.youtube.com/watch?v=on_2CP52cW4
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1
Order 4 new 470uf 25v capacitors from digikey.com P/N P10274-ND
Use first class mail as your shipping method. Will be under 10 dollars total.
Posted on Oct 08, 2010
I wish I had a solution. I have had 2 of them do the same thing.
Posted on Mar 25, 2010
PF2020 RESET CHILD LOCK
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
Oct 31, 2012 | Apex Digital PF2020 20" TV
Need remote code for apex dt250
Hello
It is very difficult to get a remote control which have codes for Apex. There is one model that have the codes for Apex tv. It is "COMCAST ON DEMAND CUSTOM-3 UNIVERSAL REMOTE CONTROL"
The setup codes for Apex Tv with this remote are:
0748, 0765, 0767
All prceedings and other dvices' code list will be there with this remote, when you buy it. No other way other than buying this model remote control. OK.
Sep 18, 2011 | Apex Digital LD4088 LCD TV
Lock the channel.than how to unlock
Hello
T unlock your Apex TV do the following. Apex TVs use a four digit code to control the V-Vhip. For most models it is 6688. Other sets may not have one, or may have a default lock code 1225 instead of an override code.
To use the override code:-
Press menu key to get into Menu.
Go down to the 'System' menu, and hit the right arrow on the remote control.
Once in the system menu go for "parential Guide" It will ask you the code.
Enter the override code listed above. From here you can turn ON and OFF different rating settings and to set a new code.
No matter what the V-Chip code is set to; the override code will work. If you have a blank screen, showing a red Key on the bottom left side of the screen, simply press the [Function or F] button togetherwith mute button at the same time. This will unlock the screen and allow you to view the channel as you desire. OK.
Apr 08, 2011 | Apex Digital PF2020 20" TV
Child lock is on how do i turn it off????????????
Hello
There is a way to unlock your Apex TV. This method will work in most of Apex models. Try this.
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
OK.
Feb 12, 2011 | Apex Digital AT2702 27" TV
I have an apex tv that has a lock(key symbol) on the lower left corner of the screen. The tv seems to be locked how can I unlock it? I using a phillips universal remote.
Hello
Just try the following to unlock your Apex TV.
OK.
Dec 27, 2010 | Apex Digital AT2702 27" TV
Apex dt250, capacitor blown. I would like to know
Aug 11, 2010 | Televison & Video
I have an Apex Digital TV Converter box # DT250A. Today, all of a sudden my TV screen went greenish and then the picture on my TV went out ( static looking screen ). The light that's on my Converter Box...
The DT250 likely has one or more bad 470uf 25v capacitors. You should replace all four. Look at some of these youtube videos for how do do the replacement.
Jul 05, 2010 | Apex Digital Televison & Video
Apex DT250 wont turn from standby (red light) to On (green light)
Sep 24, 2009 | Apex Digital HT-150 System
Child lock on and do not know how to disengage
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the function or F button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
Apr 09, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Television problem
According to Apex, you can disable the parental lock using the following information.
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Oct 28, 2007 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Apex Digital (AL-A300ATX) 300-Watt Power Supply Logo
1,077 people viewed this question
Top Apex Digital Computers & Internet Experts
David Payne
David Payne
Are you an Apex Digital Computer and Internet Expert? Answer questions, earn points and help others
