Question about Maytag Neptune MAH5500B Front Load Washer
Door seal is mouldy? Clothes are smelling. can we get a new seal?
  • 8,197 Answers
Yes You can buy a new seal at this web site repairclinic.com or you can call them at 1800 269 2609.
Good Luck and please Rate
Posted on Sep 10, 2009
  • 313 Answers
You can get a new seal (Door boot seal kit ) and some cleaner for your washing machine at the site below
This should get you going again. Let me know..
    President:
  • 2,976 Answers
The door boot costs about $55 plus shipping. You can clean it with chlorine bleach to kill the spores. The problem will return if you keep the door shut when not in use. Leave the door open, so eberything dries thoroughly. Mold & mildew spores will not grow when it's dry.
http://www.partstore.com/Model/Maytag/Maytag/MAH5500BWQ.aspx
Posted on Sep 11, 2009
Mouldy smell when opening the door
Run a boil wash 95' with a box of Arm and Hammer baking soda and a 4 towels. No soap. That will get rid of the smell and sanitize it with the heat.
In future, after washing, dry the water in the ridge at the bottom of the door seal and leave the machine open for a couple of hours to dry the inside of the machine.
Mar 22, 2016 | Washing Machines
Musty mouldy smell from my OKO_Lavamat 6450 front load washer
Pour liquid bleach into the detergent dispenser and run the machine empty on its hottest cycle. When it's done, wipe it dry and leave the door open. Do this about once a month, or as often as you deem necessary. Also remove the door seals and clean away behind them.
Sep 23, 2011 | Washing Machines
The rubber section of my Hotpoint WF640P has gone mouldy
The problem is basically caused by doing too many low temp washes.
The scum you refer to is actually bacteria that is bulding up on the door seal.
To avoid this problem reoccuring, the best thing to do is to have the door seal replaced, and periodically do a high temp wash with powder in, but without clothes..
This is called a maintenance wash, and is recommended by most manufactures
Also, after each wash, clean and dry the door seal, this will help prolong it's life.
Hope this helps answer your question.
Please rate my solution.
thanks.
Dec 23, 2009 | Washing Machines
Mouldy smell coming from the machine
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Nov 02, 2009 | Frigidaire GLTF2940ES Front Load Washer
Machine smells mouldy- washing stinks!
Find out where your filter is; it is at the end of the thick hose coming down from the bottom of your tub; open up and clean out. Another possibility is there could be something stuck in your drum, feel if you could locate it. Next clean out the hoses in machine. After all this flush out with a hot wash, without clothes. People shd ask the service man where the filter is. If he knows that is.......................It gives you the biggest problem if you dont check.
Mar 19, 2009 | Whirlpool Washing Machines
Zanuassi jet system frony loader has a bad smell
hi this is joyce
They sell a product called affresh it cost about $10.00 you put in the machine and run a cycle and this should take care of the smell. if this does not do it then run pure bleach in despenser and run cycle no clothes in washer. this will kill the mold. also never close the door completly on the machine because this holds moisture inside the machine, so leave a crack in door so the machine will dry out some. this should take care of the problem.
thanks
joyce
Feb 05, 2009 | Zanussi ZWF1430W Front Load Washer
Mouldy Door Seal
Use tilex to remove the mold. Then see what happens. If the mold comes back right away it may be a problem with the rubber gasket not seating as it should. Let me know. And please rate my solution. thanks.
Feb 02, 2009 | Zanussi ZWF1430W Front Load Washer
Mildew smelling towels and no separate rinse cycle
the problem is your door seal if you close the door after a wash then what happens is the water goes mouldy on the inside of the door seal what you need to do is replace the door seal you will never get rid of the smell without replacing it never close the door after a wash always leave it open to make sure its your seal the easy way is to look at the inner part of the seal and it will be mouldy only thing you can do
Oct 30, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
357 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
