Question about Sony Playstation 3 (PS3) Console
My Playstation 3 often freezes up after a short period of use. After that, it refuses to turn back on again, and its light flashes back to red from green whenever I attempt to turn it on. Either that happens, or it seems to turn on, but no picture is displayed, despite all cables being connected properly.
    Scholar:
  • 128 Answers
You have got a YLOD, Yellow Light of Death. The best and cheapest solutions would be to fixthis problem yourself.It would be much cheaper and faster then sending it to Sony for repair,or anyother shop who would charge anywhere between $50 - 100.
I fixed YLOD myself using the repair guide purchased from
here, cost me only $8
came with a video guide and pictorial and step by step guide. very helpful! You can get it using Paypal.
Posted on Sep 15, 2009
  • 148 Answers
Did you try to force the pS3 reset mode? press the power button for 08 seconds and wait the system restart...release and wait it reboot...if the problem persists...try to change and install a new sata hdd and restore the ps3 system...see if your ps3 hdd is really ok...test it...Or could be the Ps3 Motherboard hardware problem...called YLOD...does your Ps3 light flashes yellow??
Good Luck!!!
Posted on Sep 10, 2009
Ps3 60gb freezing
Try this use your vacuum to suck out any dust that is in machine from front and back. Use compressed air (duster used on electronics) and spray the cd area and back area again, vacuum out. If this doesn\'t help then Call Sony PlayStation for replacement of machine.
Jun 25, 2013 | Atari Tales of Graces f - PlayStation 3
Hi my playstation keeps freezing and everytime i follow the instructions on the playstation it freezes again. it now wont start correctly. Could you help me please ?
Hello
your PS3 is freezing simply because your console is affected by heat, so you have to cool it down. If the freezing continues even after cooling down, you can follow the steps below:
To stop the PS3 from Freezing, you could begin by putting off your console and wait for 20 minutes. After that, put it back on. Check if there's any loose cables. If there is, put them back in.
If the problem still persist, try the below steps,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 09, 2010 | Sony Playstation 3 (PS3) Console
PS3 freezing when playing blue rays
PS3 freezes means some hardware errors occurred and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only such freezing problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Jul 19, 2010 | Sony Playstation 3 (PS3) Console
Possible overheating
The PS3 has an automatic feature to shut down the system once it acquires overheating. The fans installed vary on how much heat is being generated by the system to cool it down. If the screen freezes occassionally try to set the resolution to a lower setting, say downscale from 1080p to 720p as it will make the system's work a little bit lighter and generate lesser heat. Hope it works.
Apr 30, 2010 | Sony PlayStation® 3 (80GB) Console
My ps3 keeps freezing games and movies ive done
turn off you playstation....then turn it back on to where the red light comes on (standby) then hold the power button til it beeps 3 times....it should turn on and back off durin this time....then repeat that process again and a screen should pop up and it asks you if you would like to restore playstation or rebuild database....try the rebuild database.... (it will delete everything saved on your playstation and it could take hour to rebuild it) if that doesnt work then yoyu have a faulty blue ray lens
Dec 27, 2009 | Sony Playstation 3 (PS3) Console
The system come up fine and allows you to get on line and play but after about 15 min the video freezes and the only way to get started again is to restart the system. After the restart it last a shorter...
Do you have adequate ventilation? Is the PS3 vertical or horizontal? My first thought it that it might be overheating. Try setting the console down horizontally with about 6 inches of clearance on all sides to insure enough airflow.
Oct 12, 2009 | Sony Playstation 3 (PS3) Console
My ps3 will a game or movie for only a short period of time before freezing. After staying that way for a while it sends a message reading (invalid disc).
the first thing I would check would be a build up of heat and make sure the fan is working. then check the discs.
good luck
Jul 30, 2009 | Sony PlayStation® 3 (80GB) Console
PS3 freezes when booted up
This sounds like your hard drive might be bad. Try pulling the hard drive out of your PS3 then turn it on and see if it will turn on. If the system turns on then i would say your hard drive definitely needs to be replaced.
May 17, 2009 | Sony PlayStation 3 40GB System
Sony Playstation 3 (PS3) Console Logo
127 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
