Question about Brother MFC-8860DN Printer
Dust on the drum??
Printer stops and the paper gets stuck half way through and the message says "dust on the drum". I open it up and clean it and close it and it prints the copy and then stops and repeats.
    President:
  • 2,306 Answers
No, don't buy a drum, that message means you take it out, run the little blue tab near the front, back and forth about 20 times to clean the corona. You can blow with a can of air into the opening, re-install and you should be fine.
Posted on Sep 10, 2009
    President:
  • 1,653 Answers
There are many factors that determine the actual drum life, such as temperature, humidity, type of paper, type of toner used, the number of pages per print job, etc. Under ideal conditions, the average drum life is estimated at approximately 25,000 pages. The actual number of pages that your drum unit will print may be significantly less than this estimate. Because of no control over the many factors that determine the actual drum life there is no guarantee a minimum number of pages that will be printed by your drum. For best performance, use only genuine Brother supplies. The printer should be used only in a clean, DUST FREE environment with adequate ventilation.
The answer is that unless you can clean it without damaging it, which is very difficult, you relly need to buy another DR 3100 drum.
How do I fix repeated paper jams?
Had the same problem with a HL-2140N. My solution was, after unnecessarily taking the whole printer apart inspecting the paper path and assemble it again afterwards, to check if the manual feed would still work. As this worked without a problem, I fuzzily guessed that something had to be wrong before that point.
In my printer, only the separation pad, and the roller right next to it came into question (both mounted at the front of the paper tray). I cleaned the separation pad (ultra fine paper dust gathered over the years) with cleansing alcohol, and took apart the roller assembly next to it (same kind of dust).
Especially the latter was super dirty. I took the roller out to clean the cleansing pad below it with an old toothbrush (Meridol Soft), reassembled, de-greased the roller with some cleaning alcohol, put everything back in place, and my printer works again the way I would expect it too.
Jul 15, 2014 | Brother HL-2150N Laser Printer
Just copy file..always jam..messagge"papper jam
Causes for paper jams in Printers are given below:
* Dust or debris
* Rotating drum problem
* Toner or fuser complaint
Dust or debris
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum.
Toner complaint may also cause paper jams. It can be solved only by replacing it. When you switch on the loop back plug in, two flash lights appear; then it indicates paper jam. The oil spillage in toner can cause this problem. If the toner cartridge is not functioning properly, the same problem would be the result. The diodes or transistors in the fuser unit of the printer may get damaged and this can lead to fuser complaints. To solve this problem, you should replace it.
Feb 22, 2011 | Office Equipment & Supplies
When i print my printer slow paper jam please tell me about to clear it
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.Hope this helps you.
Thanks
Michel
Jan 31, 2011 | Brother MFC-290C Printer
How could i fix paper jam on Brother HL-2140 Laser Printer?
Jan 12, 2011 | Brother HL 2140 Laser Printer
Why does my printer have a paper jam all the damn time?
Dec 23, 2010 | Brother DCP-330C All-In-One InkJet Printer
Brother DCP 330 Paper squizes and jam
Dec 22, 2010 | Brother DCP-330C All-In-One InkJet Printer
Paper jam - sounds like gear problem
Dec 17, 2010 | Brother MFC-845CW multi-function...
I can't get my brother printer to print photos Keeps saying paper jam even though no paper jam
Sep 23, 2010 | Brother MFC-685cw InkJet Printer
Brother says "Dust on Drum" wont print, and when does the page has two black lines down the middle
Yes some of dust have your printer drum unite.Open drum and clean it then solve your problem.
Nov 12, 2009 | Brother MFC-7820N Printer
Brother MFC-8860DN Printer Logo
205 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
