I was using ActiveSync with my Siemens SX56PDA with Windows XP but when I up-graded to Vista on a re-furbished computer, it could not sync my PDA.
  • 13,433 Answers
You need to install windows mobile device center to your vista. get it from here
http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx
Posted on Sep 10, 2009
Active sync
Depending on your OS, you'll need Windows Mobile Device Center 32-bit or 64-bit. ActiveSync is for Windows XP machines;
Microsoft Windows Mobile Device Center 6 1 for Windows Vista 32 bit
Windows Mobile Device Center 6 1 Driver for Windows Vista 64 bit
Thanks
Jay
Sep 29, 2013 | Symbol MC70
How i can sync my Ipaq h3955 with my pc win xp
In order to sync your iPAQ with Windows XP or earlier, you will need to download and install Windows Microsoft ActiveSync 4.5 from:http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/activesync-download.mspx.
Notes:
You can use ActiveSync 4.5 only with phones that run Windows Mobile 2003 or later versions. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 phones. (To see which Windows Mobile operating system you’re using, if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync information to any of these phones, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
You must use Microsoft Outlook 2002, Outlook 2003, or Office Outlook 2007 to sync your e-mail, contacts, tasks, and notes from your computer.
Download and install ActiveSync:
1. Click the download link on this page, and then click Continue.
2. Select whether you want to register for the Windows Mobile newsletter, and then click Continue.
3. Click Download files below, and then click Download (next to the Setup.msi file).
4. In the File Download dialog box, click Run.
5. Follow the instructions in the Installation Wizard to install ActiveSync.
Note: You must use a USB cable to connect your phone to your computer the first time you use ActiveSync to synchronize information.
Jan 10, 2010 | Compaq iPAQ H3955 Pocket PC
Cannot connect to pc
Which version of Microsoft Windows are you using? How are you trying to connect your PDA to computer.
In order to connect it, you need to download Microsoft ActiveSync in case using Windows XP from:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/activesync-download.mspx
and in case of windows VISTA, download Windows Mobile Device Center from:
Jan 05, 2010 | HTC P6300 Pocket PC
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
HP Ipaq h1940 won't sync with Vista
Hi. While holding power button, and pressing reset will do a hard reset to your PDA (reset the device to its factory default settings). So if your PDA is working well, don't do it. As for the syncronization with your Vista PC; Winodws XP uses the ActiveSync software for syncronization, and for Windows Vista, Microsoft developed a brand new syncronization software called "Windows Mobile Device Center". It can be downloaded here: (http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center-download.mspx). When you download/install this software to your PC, you should be able to connect your PDA to your PC without any problem, and definitely without changing any OS in your PDA or PC. Hope this helps.
Jun 01, 2009 | HP iPAQ H1940 Pocket PC
PDA clock and appointments change at sync by one hour
I am running vista and havent had this problem, as a matter of fact if you have vista you no longer need activesync. Vista comes with a built in software application to sync you PDA, there si no logical solution i can think of that would cause this problem other than your computer may need to be updated, and also vista will update all the drivers for the dell x30 as well, just make sure it is able to do all updates, not just microsoft ones.
hope this works for you!
Mar 11, 2009 | Dell Axim X30 Pocket PC
No cd for Dell axim 30
This isnt too bad, if you are using windows vista, the CD is obsolete, use the syncing technology in mobile device center to access the storage card/drive inside the pda form your computer and you can do it that way. Windows XP: you can go to the microsoft website and get Activesync which will allow you to transfer files as well. If you are using a mac, I am sorry.
Mar 08, 2009 | Dell Axim X30 Pocket PC
Microsoft Money etc. Sync Problem with iPAQ hx2495b
IT WAS COZ OF UR WINDOWS SO U SHOUL CHANGE UR WINDOS BECOZ UR DRIVER NOT SUPPORT IN UR VISTA WINDOWS SO CHANGE IT
Dec 02, 2008 | Dell Axim X51v Pocket PC
I have an HP iPAQ rx1950 PDA and it my new Windows Vista computer will not recognize it using the USB cable. Is there a way to set it up as a part of my wireless network? If so, what are the steps for...
With Vista, there has been a change from Activesync to Windows Mobile Device Center (WMDC) which does the same thing that activesync does.
You need to download and install WMDC and then you should be able to sync.
http://www.microsoft.com/windowsmobile/devicecenter.mspx
Mar 29, 2008 | RIM BlackBerry Pearl 8100
Acer n300 wont sync
you also have a connection manager on the PDA Itself ( Active sync ) Try syncing from the PDA as Well As The Computer Active Sync Program.
Also make sure if you have a firewall, you allow the PDA into it as a trusted Device.
Mike @ Compurepair.
1 more thing, try on/off the PDA whilst in sync mode.
Hope This Helps.
Feb 21, 2008 | Acer N300 Pocket PC
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
