Question about Canon DR-7080C Flatbed Scanner
I am interesting that how to reach 36ipm for duplex ADF scanning.. 1, Is it 3 pass ADF scanning by the only one Image Sensor ? 2, Or is it 2 pass ADF scanning by the only one Image Sensor ? If it's 2 pass. Does it mean the paper order will become upside down ? 3, Or what kind of Tech. to let it reach 36 ipm for Duplex ADF scanning?
  • 4 more comments
  • OPSun Sep 10, 2009
    Dear Sir,
    Dear Sir,
    Thanks in advance..But It's not what I ask..(Sorry for my poor English..)
    Actually, I didn't have this scanner, but I have a couple question for the paper feed process during ADF scanning.
    I want to know..
    When the user set 200x200dpi & Duplex ADF scanning..
    How many time that paper will pass through the Image Sensor?
    A) One time? ( But I guess it's impossible due to this scanner just have one Image Sensor.. How can it just scan one pass to get the both of front & back side image.
    B) Two time? ( 1st pass to get the front side . the 2nd pass to get the back side )...But in case ,after the Paper eject, the Paper will become upside down. ( the Paper order will be reversed)
    C) Three time? ( 1st pass to get the front side. the 2nd pass to get the back side. the 3rd pass to turn the paper back to keep the original front side still face to upside.
    Your prompt feedback will be very appreciated.
    Thanks,
    OP Sun
  • OPSun Sep 11, 2009
    Dear Sir,
    Thanks for your detail information...
    But it's still NOT what I need.. Regarding the meaning of IPM for Duplex, I already knew..
    But now, I need that someone expert had the experiences about using the Canon DR-7080C to do the duplex ADF scanning.. and explain to me about how the scanner flip the paper to scan the duplex side to get the both side image by one Image Sensor...
    As what you mention.. It should mean it's 2 pass ADF for Duplex scanning...But I want to double confirm..Did you really see the Canon DR-7080C's duplex scanning as same as what you mention?
    BTW, your mention should still have something wrong..
    "reversing the page with page 2 facing the sensor. When page 2 is scanned, the paper moves towards to output eject tray. After the paper is ejected, page 2 will be on the up facing side and page 1 will be on the bottom,"
    Actually, the Page 2 should be bottom face, and page 1 will be up due to the Image Sensor is on bottom as flatbed side.
    and could you share what's Xerox product name to let me know?
    Thanks in advance.
    Maybe I try to explain what I understand to confirm with you?
    #1, This scanner is U-Type ( U-Turn ) ADF Scanner . and it will run 2 pass for duplex ADF Scanning.
    #2, This scanner only have one Image Sensor on Flatbed side ( Sensor face up ).
    #3, When the Paper put on Input tray and the 1st paper(Paper_1) is on upside.. th last paper(Paper_N) is on downside. Page_1A is the front side of 1st Paper is facing up.. Page_1B is the back side of 1st Paper is facing down.
    #4, When scanning Page_1A, the paper feed in and U-turn the upside of Paper_1 to face down for Flatbed Image Sensor to get the image.
    #5, When scanning Page_1B ,the paper will be flip by some reversed system to let Page_1B to face down for Flatbed Image Sensor to get the image.
    #6, after the duplex scanning, the Paper_1 will be ejected directly to output tray..
    #7, the Paper_1 will become the 1st paper from downside and Page_1B will face down and Page_1A will face up.
    #8, After all scanning finished, take the stack of paper. we will face to Page_2 of Paper_1 first. So the Page Order will become 1B, 1A, 2B, 2A, 3B, 3A, & Paper Order still 1, 2, 3,... But the original paper stack is Page Order is 1A, 1B, 2A, 2B, 3A, 3B & Paper Order is 1, 2, 3,
    Am I right ? or Pls. correct me if which item is wrong..
    Thanks a lot.
    Sergeant:
    Champion:
  • 208 Answers
Actually, the page order is determined by the path of the paper feed. You can arrange it either way. The performance is about the same. If you have a straight paper path except the 2nd pass page flipping, you output order will be the same as input, but upsidedown. If either the input or output is flipped to stack the input or output on top or bottom of the paper bath, then the page order will be collated upside down, meaning page order will be 2, 1, 4, 3, 6, 5 and so on. But if you flip both input and output, then you will have the same page order as the input, but upside down.
I have a big Xerox that can optically process around 30 letter size ppm duplexed. It has only one stationary optical sensor, but many big motors. The paper is fed through the system sideways to increase speed.
36ipm is not that fast. That's only 4ppm. Did you mean 36ppm? If you really meant 36ipm, just about any conventional design will get you that speed. If you want 36ppm, you only need an 8m pixel sensor to do 300dpi on letter size paper, assuming you go with a stationary sensor with a flash.
I hope this will help.
Posted on Sep 11, 2009
  • 2 more comments
  • Ancestor_22 Sep 11, 2009
    I am sorry if I misunderstood you. Let me try my best to help with your questions. First, the Canon scanner has the input tray on top, and let's say page 1 in on the up facing side and page 2 is on the bottom side of the paper. When the scan starts, the paper is feed to the platen glass with page facing downward towards the sensor. When page 1 is scanned, the paper will move back towards to input tray but fed under the feed guide looping right back into the platen glass, thus reversing the page with page 2 facing the sensor. When page 2 is scanned, the paper moves towards to output eject tray. After the paper is ejected, page 2 will be on the up facing side and page 1 will be on the bottom, therefore, preserving the collating order, except the whole stack will be upside down. What's important is that the collating order is still page 1, 2, 3, 4, 5, and so on. If the output tray were to be ejected to the side instead of looping to the top, the page order would be 2, 1, 4, 3, 6, 5 and so on.
    I hope this help.
    I just verify the paper path with the manual. It is pretty much like what I thought it was. After page 2 is scanned, the paper is fed towards the eject tray on top of the platen and under the input tray. The page is flipped because the paper goes around the roller turning the page 180 degree before it is ejected to the tray. So page 2 should be facing upward. I am fairly sure about that.
    The Xerox I have is currently in another city. It looks a lot like this one: http://www.support.xerox.com/docu/xerox1..., but mine is an older model. It is huge. The peak speed is right around 100ppm. It has a stabler, a sorter, and a built in hard drive to store the scanned jobs. It is so heavy that it took 6 strong men to move it. I am not looking forward to move this beast anytime soon.
    If the eject tray was on the side of the glass platen, then what you said would be true. But based on the DR 7080C manual, the eject tray is above the glass platen, so the page is flip in as the paper moves from the glass patten around the feed roller 180 degrees before it is ejected into the tray. Are we talking about this scanner?
  • Ancestor_22 Sep 18, 2009
    Sorry for not able to reply sooner. There is a bug with this site. Threads get locked from time to time. I was unable to reply when this thread was locked. Anyway, the scanner does not eject the finished pager directly, the eject rollers turns the paper upside down before ejecting to the eject tray, which is right on top of the glass platen. So the output order starting from the very bottom is 1-A, 1-B, 2-A, 2-B.
  • Canon Master
  • 19,396 Answers
Hi, the question is a bit confused, I will try to answer.
If you want to scan 36ipm you need to set resolution at 200x200 dpi.
Let me know if you have any further question.
Thanks,
Here Canon support page.
Posted on Sep 10, 2009
  • Ginko
    Ginko Sep 10, 2009
    Hi, I did not receive your last question.
    Guru:
  • 1,326 Answers
If you have a duplex option it it will flip the images back the coreect orientation after scanning. IPM will vary as duplexing takes longer being that the unit needs to flip each page but each page would count as 2 scans. Most machines are rated at their max IPM while doing single sided scanning (not double sided) unless your manual states so. Notmally double sided scanning is 1/2 the actual rated IPM due the ADF having to spin the papers. Hope this answers your question..
  • James Brooks
    James Brooks Sep 11, 2009
    Sure, that helps. Most machines only have one scanner. Its hard to scan top/bottom at same time as light would bleed through to the paper and cause shadows. I worked on Xerox copiers for 9 years and even our $100k machines had only one scanner and reversed the pages. the difference is the high end machines will scan side one then 2 and put pages back in original orientaton as they normally have a higher IPM but the smaller home office machine save time/wear by only turning one time then ejecting upside down. If you scan multiple pages they will still come out in order no matter which it does, the only difference is they will come out first page on the bottom and you will have to re orientate them, they will still be in order but upside down. You will not get 36ipm on smaller non commercial copiers when duplexing, its not possible. The machines that do this at 36+ipm are about the size of a washing machine. hope this helps
What is the sp mode richo aficeowhat is the sp mode richo aficeo
he following error messages will appear on Gestetner, Lanier, Ricoh and Savin products control panel. There are no codes listed in service for operator/user problems. SC-101 Exposure lamp, lamp stabilizer board, dirty white plate, dirty optics, SBU board, CCD SC-103 Power problem SC-104 Exposure lamp problem, main relay optics board, electrical noises or communication error SC-105 Zero cross, main relay, optics board, FUSE 804 on DCPS or AC drive board on FT series SC-120-123 Scan home problem, sensor, scan motor, (EX-IPU board or fuse FU103 Aficio 400, 401, 500) SC-121 Scan home or fuse FU4 Scan home or fuse FU106 Aficio 550/650 SC-124 Scan motor encoder or scan motor SC-125 Scanning to slow speed SC-126 Scanning too fast speed SC-127 Scan motor or optics board SC-128 Scan start speed wrong; motor, board, drive section SC-129 Scan speed problem; motor or PSU SC-130 SBU error SC-140 / 141 Lens vertical home sensor SC-142 / 143 Lens horizontal home sensor SC-144 /145 3rd scan home sensor problem SC-190 EX-IPU board Aficio 400, 401, 500 Optics thermistor FT 7950, 7960, 7970 series SC-192 Automatic SBU adjust error, SBU, BICU, exposure lamp regulator, exposure lamp, dirty white plate SC-193 APS sensor FT 7950, 7960, 7970 series SC-194 IPU white level detect (too low) same as 192 SC-300-303 Charge corona SC-302 Laser (polygon) motor problem SC-302 Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650 SC-303 Charge corona wire cleaner, disconnected or time out for printer SC-304 Charge roller problem, ID sensor problem SC-305 Time out error for memory or EX-IPU board or fuse FU103 on Aficio 400, 401, 500 SC-310-314 Potential sensor SC-320 Laser motor problem SC-321 Laser write problem, BCU board, EX-IPU board SC-322 Laser 1 synch. Problem SC-323 Laser drive problem SC-324 Laser drive excess current draw problem SC-326 Laser 2 synchronization error SC-327 Laser 1 home position error SC-328 Laser 2 home position error SC-329 Laser beam pitch error SC-330 Laser diode no initial setting SC-331 Laser diode home error SC-332 Laser diode present position error SC-335-338 Laser motor polygon problem SC-340 TD sensor output error SC-341 Developer motor lockup TD sensor adjust error Aficio 551, 551P, 700, 700P SC-342 TD sensor adjust error SC-345 Toner collect motor lockup Developer bias loss Aficio 551, 551P, 700, 700P SC-346 Toner recycle motor disconnected SC-350-1: thru 5 ID sensor error SC-351 Vsg problem, bad drum, ID sensor SC-352 TD (toner density) sensor problem or bad toner mix SC-353 Vsp problem; image density sensor, drum, HVT, developer bias, needs cleaning SC-354 Vsp problem; image density sensor, drum, HVT, developer bias, needs cleaning SC-355 Toner density sensor or under toned SC-356 Toner density sensor or over toned SC-358 Image density sensor, drum, toner spray SC-360 Hard disk drive error 1 SC-361 Hard disk drive error 2 Incomplete drum potential calibration, check imaging formation assembly FT 7950, 7960, 7970 SC-362 Image compression error Hard disk drive error Aficio 551, 551P, 700, 700P SC-363 Data transmission error SC-364 Data transmission time out error Vd out of specs, drum, drum potential sensor, charge corona FT 7950, 7960, 7970 Hard disk drive error Aficio 551, 551P, 700, 700P SC-365 Image storage error VI out of specs, drum, drum potential sensor, charge corona, dirty optics FT 7950, 7960, 7970 SC-366 CRC error Aficio 550/650Vr out of specs, drum, drum ground FT 7950, 7960, 7970 Hard disk bad sector maximum Aficio 551, 551P, 700, 700P SC-367 Hard disk bad sector maximum Aficio 551, 551P, 700, 700P SC-370-01 thru 07 Drum potential sensor error Aficio 550/650 SC-370-374 IMAC error Aficio 551, 551P, 700, 700P SC-376, 380, 382, 384, 386, 388 Data transmission problem Aficio 551, 551P, 700, 700P SC-390 CRC error Aficio 551, 551P, 700, 700P SC-390-1 Toner density sensor error SC-390-2 Toner density sensor error SC-391 Developer bias problem or FU103 on Aficio 550/650 Image storage address error Aficio 551, 551P, 700, 700P SC-392 Toner density sensor SC-395 Developer bias problem SC-400, 401 Transfer roller error Aficio 551, 551P, 700, 700P SC-401 Transfer roller positive error problem SC-401-1 Transfer roller/belt short SC-401-2 Transfer roller/belt open or fuses FU104, FU115, FU116 Aficio 550/650 SC-402 Transfer roller negative error problem or open SC-403 Transfer belt position error, electromagnetic clutch release or fuse FU5 SC-405 Transfer belt position error, electromagnetic clutch release or fuse FU5 SC-405 Scanner problem; BCU, EX-IPU board or SCU on Aficio 400, 401, 500 SC-411 Separator bias SC-430 Quenching lamp error SC-440 Main motor locked or drum motor locked SC-441 Developer motor locked SC-490 Exhaust fan problem or ozone fan problem SC-491 Laser cooling fan locked SC-492 Cooling fan problem SC-493 Bridge fan problem Exhaust fan locked Aficio 551, 551P, 700, 700P SC-494 Fuser fan locked SC-495 Toner recycling unit problem SC-496 Toner collector bottle problem SC-497 Toner recycling motor problem SC-500 Main motor locked Bypass motor locked FT 7950, 7960, 7970 SC-501-1 & 2 1st Tray lift problem SC-502-1 & 2 2nd tray lift motor problem SC-503-1 & 2 3rd tray lift motor problem SC-504-1 & 2 4th tray lift problem SC-505 LCT tray SC-506 Optional tray motor locked SC-507 LCT motor locked SC-508 Tandem rear fence motor SC-509 Tandem side fence motor SC-510-1 & 2 LCT lift problem Paper feed motor problem Aficio 551, 551P, 700, 700P SC-511 Tandem side fence motor error LCT motor error Aficio 551, 551P, 700, 700P SC-515 Tandem rear fence motor Aficio 551, 551P, 700, 700P SC-516 Tandem side fence motor Aficio 551, 551P, 700, 700P SC-520 Duplex or fuser drive problem FT 7950, 7960, 7970 SC-521 Duplex side fence drive problem SC-522 & 523 Duplex jogger home position FT 7950, 7960, 7970 SC-524 Duplex end fence drive problem SC-530 Bypass motor locked or fuse FU106 on Aficio 551, 551P, 700, 700P SC-531 Fusing duplex motor locked SC-541 Fuser thermistor open SC-542 Fuser temperature too low or fuse FU107 on Aficio 551, 551P, 700, 700P SC-543 Fuser temperature to high SC-544 Fuser temperature too low SC-545 Fuser temperature to high SC-546 Fuser ready temperature unstable SC-547 Zero cross problem Fuser lamp stays on, AC drive board, optics board FT 7950, 7960, 7970 SC-548 Fuser unit not installed SC-590 Toner collector motor problem Cooling fan Aficio 220/270 series SC-591 1 bin tray motor SC-600 Communication problem between SCU and operation SC-601 Communication problem between BICU and scanner Communication problem between BCU and EX-IPU board Aficio 400, 401, 500 Communication problem between SBU and SBICU Aficio 550/650 Communication problem between MCU and BICU Aficio 551, 551P, 700, 700P SC-602 Communication problem between BICU hard disk drive board Communication problem between BCU and fuser control unit on Aficio 400, 401, 500 Communication problem between Hard disk drive board and SBICU Aficio 550/650 Communication problem between BICU and hard disk drive board Aficio 551, 551P, 700, 700P SC-602-2, 2, -3 Communication problem between BICU and ADF SC-604 Communication problem between BCU and high voltage board SC-605 Communication problem between SCU and BCU SC-610 Communication problem between IOB and duplex unit SC-610, 611, 612 Communication problem between BICU and ADF SC-620 Communication problem between BICU and ADF SC-621 Communication problem between BICU and finisher SC-623 Communication problem between BICU and paper tray unit SC-624 Communication problem between BICU and LCT SC-625/626 GA5 data transfer error; EX-IPU or software Communication problem between BICU and finisher Aficio 551, 551P, 700, 700P Communication problem between BICU and LCT Aficio 1035, 1045 SC-627 Communication problem between BICU and LCT Aficio 1035, 1045 SC-630 Communication problem between line adapter and CSS center (Japan) SC-635-636 Communication problem between BICU and paper feed board Aficio 551, 551P, 700, 700P SC-640 BICU data transfer sum check error SC-641 BICU control data transfer problem SC-650, 653 Key card (Japan) SC-670Engine or BICU error SC-672 Op panel to controller problem SC-690 BICU problem (12C) SC-691 Communication problem between BICU and fax controller BICU problem (12C) Aficio 1035, 1045 SC-692 Communication problem between BICU and print controller board BICU problem (12C) Aficio 1035, 1045 SC-694 Communication problem between BICU and scanner board SC-696 Communication problem between IOB and finisher SC-700 ADF P/U problem SC-701 ADF P/U problem SC-702 ADF feed in motor SC-703 ADF transfer motor SC-704 ADF feed out motor SC-705 ADF bottom plate motor SC-720 Finisher transport drive motor problem SC-721 Finisher tray shift or shift motor problem SC-722 Finisher jogger motor SC-723 Finisher stack feed motor problem SC-724 Finisher stapler hammer motor SC-725 Finisher stack feed out motor SC-726 Finisher shift/lift motor SC-727 Finisher stapler rotation motor SC-729 Finisher punch motor SC-730 Finisher stapler position motor SC-731 Finisher exit guide motor Finisher exit open/close motor problem Aficio 1035, 1045 SC-732 Finisher up tray shift motor problem SC-733 Finisher stack feed out motor Finisher lower tray shift motor problem Aficio 1035, 1045 SC-734 Finisher lift motor Finisher lower tray shift motor problem Aficio 1035, 1045 SC-735 Finisher exit guide motor Finisher pre-stack motor Aficio 551, 551P, 700, 700P SC-736 Finisher exit guide plate motor SC-737 Finisher waste stapler full SC-738 Finisher shift tray lift motor SC-740 1000 sheet finisher error 01: Shutter error 02: Exit error 03: Upper exit plate error 04: Jogger motor 05: Stapler motor 06: Stapler hammer motor 07: Tray lift motor 08: Shift tray height sensor 09: Back up RAM 0A: Communication error SC-741 1000 sheet finisher error in saddle stitch area o 01: Position plate motor o 02: Folder roller motor o 03: Shutter guide motor o 04: Booklet jogger motor o 05: Stapler motor o 06: Folder plate motor o 07: Connector o 08: Switch SC-750 Interchange connection problem SC-751 Bridge connection SC-752 Finisher connection SC-760 ADF gate problem SC-770 Shift tray motor SC-800 Control board bad SC-804 Control board bad SC-819 Software application error SC-820 Control board or software SC-821 Control board SC-822 Bad HD SC-823 Bad control board or NIC SC-824 NVRAM or battery bad SC-826 NVRAM bad SC-827 Memory problem SC-828 Bad control board or firmware SC-829 RAM DIMM or control board bad SC-835 Control board or connector SC-836, 837 Font ROM bad SC-838 Clock generator problem SC-850 NIB or control board bad SC-851 IEEE 1384 interface board or control board bad SC-860, 861 Hard drive problem, connection or cable SC-862, 863 Returned, Bad sector in hard drive SC-864 Abnormal HD data transfer SC-865 Hard drive error SC-900 Electrical copy counter problem reached 10 million or NVRAM problem SC-900-01 Mechanical counter SC-901 Mechanical counter or fuse FU4 SC-921 MSU hardware error Copier feature expander hardware error Aficio 220/270 SC-940 Main switch problem or main board SC-951 Gate signal error SC-953 Scanner image setting error (Software) SC-954 Printer image setting error SC-955 Memory setting error SC-956 Scanner parameter error SC-957, 958 Scan error SC-959 Printer setting ID error SC-960 Printer return ID error SC-961 Printer ready ID error SC-962 Memory setting ID error SC-963 Memory finishing error SC-964 Printer ready error SC-970 Scan error SC-980 Program loading error or hard drive access error SC-981 Hard drive response error SC-982 Hard drive construction error SC-984 Hard drive response error Control board, BICU or connection bad Aficio 1035, 1045 SC-985 Control board, BICU or connection bad Aficio 1035, 1045 SC-986 Software problem SC-990 Communication problem between BICU and input output board or software performance error SC-991 Software problem SC-996 FCU board or firmware problem SC-997, 998 Software or missing RAM or missing DIMM SC-999 Program version error or fuser FU6 Program download problem, BICU, IC, NVRAM bad, power loss, board installed wrong Aficio 1035, 1045 Printer Controller Error Codes 2001 Power on error 2002 FGATE error 0201 On board SDRAM error 0301 SDRAM error 0Fxx Controller -BICU error 1101 Data transmission error 1102 Data loop back 11xx Centronics cable error 1401 Controller NVRAM error 1402 NVRAM check sum error 1403 NVRAM white error 1404 NVRAM read error 1501 RTC error 1601 Font ROM error 1602 Data in font ROM is damage 1Bxx Options bus A error RICOH 3813 Copier U1 Right side open U2 No key counter U4 Sorter not latched or closed U6 Developer unit not in place E11 Exposure lamp problem E12 Exposure lamp problem E13 Zero cross, main board or power supply E-14 Zero cross, main board or power supply E-21 Scan home problem E-22 Scan home problem E-28
May 17, 2014 | Sharp AR-5316 Advanced Digital Imager...
How do I fix paper jam for AV122C
Sounds like the machine is picking up a signal from the paper exit sensor. The flag is not moving freely, or not moving at all. Look down in the paper hopper, ( where the paper is loaded), you might be able to see the sensor. The flag is spring loaded. Sometimes the flag falls off. The flag is black and shaped like a (T).
May 11, 2014 | Avision AV122 Color Duplex 18ppm/36ipm CCD...
Blank copies from copier
You don't say what model your fax is.
In general. If when copying you get a Full BLACK page printed then the scanner lamp is not lit. As no light is reflected into the image scanner, it interprets this as BLACK information so therefore only black is printed. Look into the ADF while the document is being scanned and I bet you will see no green light at all. A new Contact image sensor should cure it.
Jan 13, 2014 | Canon Duplex Automatic Document Feeder
Backside Optical alarm (G) when using Duplex option
Hi Rasha,
ADF backside scanning optical alarm (upper optical unit ADF) is E3 alarm. When there is an irregularity in the amount of light (ADF back), "E" and "3" will be displayed alternately on the function number display panel of the scanner.
Please check the followings:
1.Does the same symptom occur after turning OFF and ON the scanner?
2. Is the lower glass (white sheet guide) of the reading section dirty? Open the ADF, and clean the sheet guide (white part) and the glass.
3. Is the upper Optical unit ADF dirty? Are the cables damaged? Are the connectors connected properly?
4.E3: Is the upper lamp ON? Are the cables damaged? Are the connectors connected properly? Disconnect the SCSI cable and turn the scanner ON. Open the ADF and press ADF cover open sensor as shown below to see if the ADF lamps light which has to be replaced.
I would recommend to contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jun 12, 2013 | Fujitsu fi-4750C Flatbed Scanner
Scanner leaving black streaks
There are two possible fixes.
Download the latest firmware update by CLICKING HERE
The following is provided by courtesy of Lexmark:
Problem Vertical lines; Auto document feeder scan anomaly; ADF scanning problem; Scan issue; Scanner issue; Visible line; Streaks show on page; solid line down the page; Top to bottom line; Smudge runs down the page; Opaque line; Broken line; Bar all the way down the page Solution Overview
This article provides the self-diagnostic steps necessary to evaluate top-to-bottom streaks that appear when copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
  • -Vertical lines only when using the Autodocument Feeder (ADF).
  • -Observed with any type of scan job (e-mail, ftp, solutions, fax).
  • -However, normal expected output when the page is scanned from the scanner flatbed.
ADF scan behavior
Think of it this way:
  • -The page is pulled from the ADF.
  • -The moving page slides across an ADF-designated portion of glass.
  • -The image sensor, which is located under the glass, reads and interprets the moving page's contents.
  • -Contamination on this ADF glass is seen by the image sensor for the entire length of the page.
  • -The image processor interprets the image sensor's repeated capture of this contamination as a vertical solid line.
  • -Any ADF scan function now exhibits a vertical line.
Suggested Diagnosis and Fix
Step Action 1 Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
2 Perform a visual inspection for any of the following recurring culprits:
  • -Clear adhesive tape
  • -Glue
  • -Ink pen
  • -Paper
  • -Marker
  • -White out
  • -Staples
  • -Environmental dust or dirt
HINT: Ink marks can be especially hard to see and almost translucent at first sight. However, the image sensor (CCD) registers them as a mark. 3 Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris. 4 Inspect the underbelly or underside of the ADF for any marks or debris. 5 Perform another scan to see if cleaning the glass alleviated the issue. 6 Repeat the procedure if a vertical line still appears.
Remember! Printing and scanning from the scanner flatbed work fine.
7 This time, place an intentional mark on a blank sheet of paper and take note of its location. Now place that sheet of paper in the ADF and make a copy.
8 Evaluate the distance of the vertical line to the your mark. 9 Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities
If... Then... Vertical lines appear only when printing... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear when you lay the page on the flatbed... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear on ADF-fed printed copies, but they do not appear on scan-to-network [e-mail, FTP, folder (PC), solutions]... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
May 01, 2012 | Lexmark International LEX90T9005 Inkjet...
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Aug 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Hp scanjet 8250. I want to set my scanner to default to PDF when I am trying to email. That is the way we do most of our scanning and right now it defaults to RTF.
Have you considered simply scanning from within Adobe Acrobat or similar software that produces .pdf and then use the email feature within Acrobat?
As I look over the HP User Manual, I can't see any method to set the default output. It simply says...
Use the E-MAIL button() to scan documents or pictures and insert them in an e-mail message as an attachment. You must have an Internet connection and a supported e-mail application.
1. Place the original face down on the scanner glass or face up in the ADF. If you are scanning two-sided originals from an ADF, slide the DUPLEX switch to two-sided mode.
2.Press the E-MAIL button().A message appears asking if the original is a document or a picture.
3.Select Document or Picture, and click OK.Note:A preview image will not appear when scanning from the ADF. To change this preview setting, see the HP Photo & Imaging software Help.
4. Select the final scan area (the area inside the dotted lines) in the preview image.
5. Make adjustments to the preview image if needed.
6. Click Accept.The final scan area is scanned and your e-mail application is opened. The scanned image is added as an attachment to the e-mail message.
7. The Save As dialog box appears. Type a file name and choose a file type, and click OK.
8. Complete the e-mail as usual.
Aug 07, 2009 | HP Office Equipment & Supplies
Fujitsu fi5650 hispeed duplex scanner
Check the following items:
1 Does the document satisfy the paper specification?
2 Clean the Feed rollers and the Plastic rollers and see if the error is resolved.
3 Replace the Pick roller and the Brake roller and see if the error is resolved. Check the consumable counter in the software operation panel or in the built-in Maintenance mode. When the counter exceeds the values, replace the Pick roller or the Brake roller.
4 Are the cables between the Control PCA and the Feed motor damaged? Are the connectors connected properly?
5 Is the Optical unit ADF installed correctly?
6 Is the Belt ADF installed correctly?
7 Is the Belt ADF damaged?
8 Replace Feed motor and see if the error is resolved.
9 Replace the Optical unit ADF and see if the error is resolved.
10 Replace the ADF unit and see if the error is resolved.
Pls acknowledge of the issue is resolved.
Regards,
Tech Satya
Aug 06, 2009 | Fujitsu fi-5650C
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
Ricoh Aficio 1035 ARDF is not duplexing, why?
Call a technician, seems like the original is not making the second scan pass and thus displaying a mis-feed, cut also be a small piece of paper in the feeder bloacking a sensor, bad sensor or worn feed tires. www.mfpsolutions.blogpsot.com
Sep 30, 2008 | Ricoh Aficio 1035 Copier
Canon DR-7080C Flatbed Scanner Logo
79 people viewed this question
old marine
old marine
