Question about Apple iPhone 3G
I have an iphone 2G that was connected to my car charger and when I started my car it blink, then proceeded to ''cycle'' through a flash then apple logo then blank..over and over. like it was trying to boot. i've tried the home power button thing and have done everything i can...i did get itunes to recognize the phone in restore mode, but when i tried to update got an error and now it wont do anything....
How do i fix my iphone 3g thatb willm only power on and off and will only display the apple logo on a completely black screen and constantly blinks on and off when turned on
This is probably too late but I really hope this can help you or others.
1,Possible Reasons for your iPhone's Black Screen of *****
A. Hardware Damage
B. Failed Software Update
2,Common Ways to Fix the Black Screen issue in your iPhone.
A. Perform a Hard Reset on your iPhone.
B. Restore Factory Settings using iTunes
3,Best Solution: Fixing your iPhone's Black Screen issue with FoneDog
Step 1: Launch and connect.
Step 2: Detect the Affected iPhone Device.
Step 3: Proceed to the System Recovery Process.
Step 4: Download the Firmware.
Step 5: Perform Another Option for Firmware Download.
Step 6: Repair in Progress.
Step 7: Turn on the Device after Repair.
Reasons for Black Screen of ***** and How to Fix it
May 10, 2017 | Apple FOR APPLE IPHONE 3Gs PHONE CAR+HOME...
My iPhone 2g is heating up..and if i charge it its so hot and i will take me 1 day to fully charged it and if not fully charged i can used it up to 20-30 munites if fully charged 2-3 hours and the hot...
You either have a bad battery or you have a bad charger. If the phone heats up when you plug it into the USB port on a computer then you know that the battery is bad and needs to be replaced. If the phone does not heat up and you get a normal charge from the USB connection then you know that the battery is good and the charger is bad.
Mar 24, 2011 | Apple Iphone 2g 3g 3gs 8gb 16gb S
Apple iPhone 2G 3.0 unlocking link or software download free
search for free iphone unlock tutorials at youtube.com
Feb 25, 2010 | Lands Phones
Iphone 2g battery
You'll have to let the iPhone charge sufficiently for it to proceed further from the boot screen. You may want to leave the iPhone charging for atleast half an hour before unplugging it.
Jan 09, 2010 | Apple iPhone Smartphone
My iphone 2g only shows the apple for 10 seconds then shuts down
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
After this you'll need to jailbreak it too....
Sep 04, 2009 | Apple iPhone Smartphone
I have a iphone 2g 8gig that will not charge or connect to itunes
I have seen this many times, but not to this degree with so many different problems. The issue is your main flex cable which holds the Charger, Microphone, Speaker and connects to the main board. It is extremely difficult to replace. I do not know what country you are in, but you need a proffessional repair center. If you are in US you can contact me if you like. cellularcpr@aol.com. Thank you
Jun 23, 2009 | Apple iPhone Smartphone
My iphone 2g wont charge & wont turn on
Try using another cable or charger. A damaged charger or cable could cause it not to charge.
Otherwise, contact apple or apple store for repair.
May 06, 2009 | Apple iPhone Smartphone
My iphone is dead, i tried charging it for the
What you have to do is hold the power and middle button while plugging in the sync cable, it will then show the connect to itunes screen.
Mar 05, 2009 | Apple iPhone (16 GB) Smartphone
Apple iPhone 3G Logo
48 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
