Question about Biostar K8M800-M7A Motherboard
Computer shut down when you are playing a game are working in microsoft office . Have replace powersupply. added 2gig mem replace cpu fan
    President:
  • 1,653 Answers
Use SiSoftSandra to diagnose your prolem.
Download free Lite product from
http://www.sisoftware.co.uk/index.html?dir=&location=downandbuy&langx=en&a=
Posted on Sep 10, 2009
  • 3 Answers
Open ur cpu and unplug all major wires and then plug them again. also try to re install ur windows
My computer shut off in the middle of a game I was playing. After some digging It was because the processor reached 180 degree.
Also where you have the computer has enough space? If this space is a "hole" in your desk the air can't circulate for cooling down.
May 23, 2017 | The Computers & Internet
CPU keeps overhreating.
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Feb 24, 2013 | ASUSTeK COMPUTER ASUS P8Z68 DELUXE/GEN3 -...
My computer keeps shutting down after a few minutes. I have replaced the powersupply as well as the cpu fan. I am being told now that it is the system/motherboard. Is that an accurate answer?
When the CPUoverheats it goes into thermal shutdown and will not boot up again until theCPU has cooled down.
The heat sink may be clogged with dust, which causes the CPU to overheat byreducing air circulation through the heat sink.When you replaced the CPU fan, did you put new thermal heatsink paste on the CPU/heatsink? If not then the CPU can overhest. Your computer fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.
Mar 21, 2012 | Computers & Internet
New Graphic card gives me a blue screen (or shuts pc down) when I go to play a game after 5 minutes or so and then recovers to reboot. Hello, I have a 2.8 gb CPU/1.5 gb mem/IBM ThinkCentre a50p...
Try reinstalling the drivers from AMD. If that doesn't help the problem, use a program like GPU-Z to monitor the temperature of the graphics card. If a graphics card overheats, it will shut the computer down giving a blue screen.
If it ends up it is overheating, try taking the side of the computer while you're playing a game or installing another fan.
Apr 05, 2011 | Computers & Internet
My computer shuts down after a few minutes
2 possible issues come to mind: 1) the computer is getting hot (CPU, memory or video card), 2) the power supply can't keep up with the demand.
Try using a program that lets your track your computer's internal temperature. System Information for Windows, http://www.gtopala.com/ , is the one I use. Depending on the cause, you may need to increase the ventilation of your case (add fans - slot cooler by the video card, front, back or side panel.). If the CPU is getting hot, make sure that the CPU cooler is working and consider removing it and reapplying a new layer of thermal paste before reattaching the cooler.
If the problem is the power supply, check the specs on your devices (memory, CPU, video card) and the power supply load rating. You may need to upgrade the power supply.
I hope this helps.
(I am not a gamer but the default power supply that came with my computer didn't have enough power for the added memory and video card. I replaced that and added a back fan (spot available), a slot cooler, a drive bay fan and cut a hole to add a side panel fan.)
May 08, 2010 | Biostar P4M900-M4 Motherboard
Computer shuts down in games, replaced Mem and PS 800W
I would check the bios and see what the shutdown temps are for the cpu as they may be set too low ( check the manuals for the cpu's as you dont want to set it too high as obviously if it does get too hot you dont want the cpu's ( processors ) to blow up or die on you.
Apr 11, 2009 | ASUS COMPUTER INTL M3A32-MVP MBD ATX...
Vista 64 shuts down while playing games
Check for overheating problems
Check all fans including power supply one
Then remove fan from heatsink and clean out all fluff and dust
Vacuum out case all vent holes ans case fans
When playing games either CPU or Video card getting hot and closing down to protect system
Oct 23, 2008 | AMD ASUS A7V8X-MX ALL IN ONE MOTHER BOARD...
Suggestions
DDR 333 memory is DDR PC2700, I believe. It might be hard to find a new MB that will work with that. You'll probably have to buy new memory. You'll also need a new CPU fan, unless you know the Socket type of your existing MB. But you should replace the fan anyway on a new CPU/MB install. You should buy as much memory as you can afford.
Try looking HERE and see if anything is in your price range.
Hope that helps...
Geno
Apr 25, 2008 | ASUS P4S800-MX Motherboard
CPU fan not working
you need to check your power supply if this is okay you need to replace the cpu fan. the cause of shutting down is the overheating of your cpu
Jan 06, 2008 | Acer Veriton 5200D PC Desktop
Unwanted Shut-off
First Charge up you battery while the computer is off. Once fully charged unplug the adapter and play the game...see if it shuts down. If not replace that ac adapter. If it still shuts down... Your unit is overheating most likely. When you play high tech games which cause the processor and fans to run harder once it gets to hot. And most times you can hear the fan running loud on your laptop. 1. check the system requirements on the game 2. Are you overclocking your processor, check your bios 3. Lower the graphics settings and features in your game.. see if it shuts down 3.Or while you are running the game do the follow hit ctrl, alt, del buttons at the same time. A task manager box will pop up. Click on the tab Performance.....what is your cpu usage? 100% if so it's running the proccessor hard. Now in the same box click on Processes, then user name, you will then see all processes that are running at that time. If you want to play the game off line...only!!! you can stop some processes from running. On the bottom right hand corner of your screen by the clock you will see icons that load up at startup. Right click the ones not in use, like virus scan, firewall, other background applications that are running by right clicking over the icon and exiting or closing the application. Now keep in mind before you go back on line you should restart your computer so your security software will reload. Other reasons would be internal cleaning, fan, heatsink replacements and so forth. Which may need to be performed by a professional repair shop. Now they do have a laptop colling pad which have worked for some people. Also these laptops can overheat quickly, do not sit them on beds, and your lap when using ventilation is important. And also you might still want to have that ac adapter checked out. If all else fail... restart you computer in safe mode...try running the game..see if it shuts down. Good luck with your games
Sep 15, 2007 | Acer Aspire 5002WLMi Notebook
Biostar K8M800-M7A Motherboard Logo
57 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
