Question about MSI K8N Neo4-F Motherboard
It keeps popping power supply - MSI K8N Neo4-F Motherboard
  • 3,153 Answers
For a board to keep popping a power supply there is probably a fault in the installation of the board.
Make sure you only have the board stand off / risers / mounting pegs in line with the holes that are meant for them in the case.
Putting a metal post in the wrong place can blow the board and power supply or worse.
On occasion and more so in cheaper cases the holes may not be in the exact proper place.
To overcome that you can use the fibre washers that come with the screw kit for that case.
these would need to be sat on top of the posts and then the board very carefully placed back in the case without knocking thee washers off.
Super-glue works ! but don't use anything conductive !
Also make sure you use the correct screws to mount the board.
These tend to be the ones with a domed head.
If you still have problems you may have pooched the board.
Posted on Sep 11, 2009
Dell Latitude D810. I bought a new powr supply from dell. I keep getting a popup saying that it cannot determine the AC power adapter. Also, my battery is dead.
You will get this error when you get a newer power supply than what was originally design for the Latitude, also when the unit came from a 3rd party supplier not on Dell's OEM supplier list, and your battery will some what solve this upon getting a new one.
As for the pop up itself, no harm. Just a nusance. You should be able to turn this off in the Administrator file and select services. Look for power management and deselect monitor AC power.
Good Luck.
C2Solutions
Jan 24, 2011 | Dell POWER SUPPLY Power Supply
My tv made a loud pop sound then it would not turn on. the stand by light keeps blinking
The tv power supply board is the causes and the problems.That the board,that where the a/c power cord plug into it.Tries websites Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 15, 2010 | Sony KDL-40S3000 40 in. LCD HDTV
My fuses keep popping any ideas?
You have not supplied sufficient information so here is one possibility.
If you replace a fuse you must use one that is the correct amperage for the circuit.
Check your owner's manual for the correct amperage fuse for the circuit concerned and make doubly sure the correct one is installed.
If it is the correct amperage for the circuit please supply more information on the problem including which fuse keeps blowing:
1. Is the fuse popping immediately you replace it in the fuse panel and switch power to the circuit or only after a period of time of operating the vehicle? For example, if it is a lighting fuse, does the new fuse blow immediately you switch on the light concerned?
2. What is the function on the vehicle that has the power cut when the fuse blows?
3. Has there been any work carried out on any part of the electrical system or on electrical components of your vehicle prior to this problem arising? If so what was done?
Dec 05, 2009 | 1993 Mazda Protege
Tv wil not turn on just keeps making a clicking noise
ur relay keep try hard to turn tv on that u hear clicking noise.
+5VDC is leaking! open back cover,check power supply board.
1000uF or 2200uF capacitor is popped open or leaky.replace with known top quality capacitor.do it ur self repair will save u $200.
Jul 07, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
USB port malfunction
CHECK THE RATING ON YOUR POWER SUPPLY BECAUSE SOME LAPTOPS WILL REGISTER THE POWER CONNECTION PORT AS A USB PORT AND IF YOUR POWER SUPPLY VOLTAGE IS TO HIGH FOR THE COMPUTER IT WILL REGISTER IT AS SUCH, "HUB-PORT" IS SHORT FOR MAINBOARD PORT ON SOME DELLS. UNPLUG YOUR POWER SUPPLY AND CHECK THE RATING ON IT COMPARED TO THE DELLS INPUT VOLTAGE, THE INFORMATION IS NEXT TO YOUR SERIAL NUMBERS AND LABELS ON BOTH PEICES KEEP ME POSTED... JON-T
Dec 07, 2008 | Dell Inspiron 8600 Notebook
Fried something?
A half volt will not make any difference. Sounds like the power supply is malfunctioning. Start by trying a different one. Keep in mind that you may have fried the new motherboard by using a faulty power supply. Popping sounds indicate a short or loose/exposed wires, and are never good with any electrical device, especially a laptop since they are sensitive to power fluctuations to begin with.
May 14, 2008 | HP Compaq Evo Notebook N600c
Vizio Pop of Death P50 HDM
its the capacitor on the power board that pop.they over heat its like a computer power supply if you had no fan to keep it cool..replace the capacitors on the power supply and it should work.if you can think of a way to keep the board cooler it wont happen again.
Mar 14, 2008 | Televison & Video
MSI K8N Neo4-F Motherboard Logo
57 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
