Do you have a software to connect a UBS cable of a casio model #Casio WK-3800 76 key, Smart Media #MSRP
  • 1138 Answers
SOURCE: Want to connect to my Vista PC but...
Have you tried signing on to your computer as the administrator? I looked at the support pages at Casio and saw how confusing they are. Look at page: http://support.casio.com/information.php?rgn=5&cid=008&pid=114 and page: http://support.casio.com/information.php?rgn=5&cid=009&pid=115. Pay attention to the red lettering. The computer might be considered as the midi out device and the keyboard as the midi in device or the other way around, I'm not sure. Pretend its a telephone conversation with one person talking and the other person replying. I don't know if this helps but you can also try tech support at Sweetwater Sound (800)222-4700.
Posted on May 26, 2009
SOURCE: I purchased the Casio Wk-1800 in 2000. Moved
no but can't afford to join any plan
Posted on Jun 25, 2009
  • 5603 Answers
SOURCE: My WK- 3700 Casio keyboard is malfunctioning.
One portion of the key scanning matrix has gone bad. First thing is to clean the contacts with 99% isoprophyl alcohol. These USUALLY consist of traces on a circuit board that conductive rubber "pills" under silicone rubber domes are pressed down. Each note usually has two contacts, one closes before the other. This creates "velocity" measurement for the key. IF ONE of the contacts for a key doesn't work, the velocity can detect that the note has actuated, but no release occurs.
This would be on the "STROBE" line for either the first or second contact for THE OCTAVE you have problem with. There are disconnect diodes that prevent sneak paths.
You could have one bad diode, a crack in the circuit board, or a bad connection to the keyswitch board.
Posted on Nov 27, 2009
  • 30 Answers
SOURCE: Casio WK 200 keyboard, USB doesn't work
You may need to install the drivers to give the computer to fully recognize the keyboard. The computer may see the keyboard, but isn't recogning it fully due to the lack of drivers.
Posted on Jan 02, 2010
peeface
  • 180 Answers
SOURCE: need a casio wk-110 manual
http://support.casio.com/pdf/008/wk_110_01_e.pdf
Posted on Apr 28, 2010
Testimonial: "Talk 'bout fast !! Within minutes of posting the problem, I had the solution. WOW! THANKS SO MUCH. BOBBYRAY"
How to reset factory defaults for a Casio WK-8000 keyboard
1. Press the Transpose/Function button
2. Cursor down 3 times to "Init Mix"
3. Cursor right to "Init Sys"
4. Press Yes twice
5. When it says "Please Wait", don't press any keys
6. After that, press Exit once and it's ready to go
http://www.sweetwater.com/sweetcare/articles/reset-casio-wk3000-factory-defaults-hard-reset
Please rate my answer, Thank you.
Aug 05, 2014 | Casio KEYBOARD WK-8000
When I plug in stereo headphones in the casio wk 210, the sound only comes out of one ear. I didn't really care about that before, but now when I connect a line out from the piano to my computer to...
The output of the casio may only be mono, you can buy splitters to create a 2x channel output. Is there any other outputs from the casio other than headphones, usually there are red/white RCA outputs (Phono's) which would be better for connecting to your soundcard.
Hope I was of use to you, good luck.
Aug 04, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Re: Casio WK-210. Audacity, Jet Audio and Ctrl Pnl allow me to choose a USB PnP "record from" option, however, no sound is being recorded from the Casio to the PC. What am I doing wrong. Many...
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
Feb 23, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
I need a USB cord for my Casio WK-210. Does it come with one? If not, where could I buy one?
Are you referring to the Casio WK-210 Keyboard.?
A User Guide can be found here:
http://support.casio.com/pdf/008/WK210E1A_web.pdf
Beginning of page 59 of the PDF file is a description of how to connect to your computer.
You are to use a commercially available A-B Type USB cable; meaning one end has a Type A connector for connecting to your computer and the other end a Type B connector for connecting to the keyboard.
The USB cable is not provided.
The cable is commonly available and could be purchased from any company that sells computer parts and cables.
Trust this is helpful. Please vote.
Dec 27, 2010 | Office Equipment & Supplies
Dec 29, 2009 | Computers & Internet
May 24, 2009 | Casio 76 Key Smartmedia Keyboard
SMF converter for wk-500, Does it exist?
No.
I have a Wk-8000 & a CDP-200R, the later is the same as wk-500 but with 88 weighted hammer keys.
Since wk-500 can play SMF (Midi 0 & 1) format directly from a SD card and there is enough polyphony to play anything, I don't find any real reason to convert SMF to any "Casio Format". Just get a 2GB SD card and put your SMF files in the MUSDAT folder for the SD CARD using your PC/MAC.
Dec 31, 2008 | Casio Lighted Keyboard LK90STADMC
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
