Question about Canon Cameras
I have a cannon sureshot it won't turn on i charged the battery and put it back in model number sd750
  • 33 Answers
Unfortunately the no-power problem within the Canon SD750 line is quite common. The good news is: It can be repaired! Just check that link out which leads to a repair service that should be able to take care of you.
The no-power issue is resolved by just replacing the main PCB (printed circuit board) inside the camera.
Posted on Sep 10, 2009
I have a cannon ixus 75 can i charge it from a laptop
Probably not, USB does not provide enough current to charge this type of battery, ergo Canon does not support USB charging. You can buy a third party charger and battery set for not very much and keep this camera working.
Dec 15, 2013 | Canon PowerShot SD750 / IXUS 75 Digital...
How do I charge my Cannon Powershot S750 battery using the computer ?
You can't. This camera does not charge the battery in the camera. You need to remove the battery and put it into the battery charger.
If you no longer have the charger, a replacement can be obtained cheaply from Amazon. I like the "Universal" chargers, which have adjustable contacts and can charge any of the small lithium batteries found in cameras and phones. These are available for as little as three US dollars. Mine will plug into a wall socket or a car cigarette lighter socket.
Dec 14, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
PowerShot SD750 / IXUS 75 Digital Camera: HOW DO I CHARGE MY BATTERY...
Take the battery out of the camera, put it into the supplied charger, and plug the charger into a wall outlet.
May 17, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera won't turn on
camera must be damaged and sent back to manufacture.
Feb 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Cannon SD 750 - when i try to take a picture a black screen appe
Think that you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Jul 29, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Display not open [I X U S 70]
There is small switch under the battery lid near by the battery. Use a tooth stick to press the switch down and turn on the unit. If the unit won’t turn on you need a new main board.
Apr 05, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon powershot SD750 will not turn on.
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
Nov 21, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Locked camera?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Jul 27, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
CANNON SD750
send it to us most likey it is a blown fuse. we can repair for 85.00 worst case 125.00 depending on the issue. but 125.00 is the very worst case normally it is only 85.00 send it in for a free diagnosis.
Jun 26, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon Powershot SD750... battery or camera problem??
Try to clean the battery terminal inside the battery compartment, use barbecue stick with cotton buds with little drops of alcohol and rub the terminals. Also check the terminal spring, maybe it is loose or not pressing the battery enough.
Aug 31, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Cameras Logo
67 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
