Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
Freezer works well, but not the refrigerator.
My Kenmore refrigerator just passed one year warrant. The problem started with a lot of ice showing in the freezer, then there are no cool air in refrigerator part. thanks for your help.
  • gary_wang1 Sep 14, 2009
    thanks for your information.
    Can I replace the defrost timer by myself or need a professional?
  • 308 Answers
You most likely have a bad defrost timer, which would account for the ice, and lack of cooling. Hope this helps
Posted on Sep 11, 2009
Testimonial: "thanks!"
  • Keith Fournier Sep 14, 2009
    Usually replacing the defrost timer takes a little bit of time, but is not generally difficult to do. Just remember to do all connections one wire at a time to avoid having to trace the wires back later.
The ice maker overflows the ice tray, so water runs down the side of my freezer.
if it has worked for 3 years then I would guess just a new tray
Feb 18, 2015 | Kenmore Refrigerators
Water dispenser not working on kenmore trio refrigerator
The tubing inside the door is most likely frozen. Mine did that a year ago. I had to remove gasket and loosen screws around edge and allow to defrost inside door. There was a lot of ice around dispenser and tubing.
Sep 16, 2012 | Kenmore TRIO® 77553 Stainless Steel Bottom...
Kenmore refrigerator,bottom stoped cooling.freezer works just a little bit.8 years old.bought new.
More than likely your freezer has a ice block in it it will have a lot of frost on the inside of the freezer. This ice block is usually caused by a bad timer or a bad heating element in the freezer. The timer kicks in a timed cycle to turn on the heating element and a hi heat limit keeps it from getting to hot just hot enough to melt any frost and ice. (thats how we have frost free fridges now)
Aug 12, 2010 | Kenmore Refrigerators
Cannot adjust refrigerator temp (warm) and freezer will not produce ice
There is an ice dam in the freezer port which is preventing cold air from passing into the refrigerator. Remove the bottom panel and melt the ice. Make sure the passageway in the very back of the freezer is completely clear of ice.
Oct 03, 2009 | Kenmore Refrigerators
I have a Kenmore refrigerator with a bottom freezer. The unit has worked well about 6 years. Now, The freezer is working well and the refrigerator is not working at all. Any suggestions where to start?...
Sounds like a freezer fan problem . Not a thermostat problem . Could also be a defrost problem , if so , then look for frost on the rear wall of the freezer inside to determine .
Jul 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer is too cold, ice crystals. Refriderator
I'm not sure which one you have, but try this: Look for the area where the air passes from the freezer to the refrigerator side, in the wall somewhere between them. Make sure that there isn't something blocking the passage. This is a good place to start.
Regards,--W/D
Jul 10, 2009 | Kenmore Refrigerators
Frost on back of bottom freezer of a 3 year old kenmore
how long did you leave it unplugged? it's possible all the frost didn't defrost .you need to leave it unplugged and the doors open for at least 12 hrs.
May 20, 2009 | Kenmore 76283 Bottom Freezer Refrigerator
3 year old kenmore top freezer, won t defrost ''no ice'' buildup behind the freezer panel I removed. no clicks on the defrost test, same result for method #2. The ice maker works ok when freezer is at...
your freezer had a heater and a bi metal behind its pannel. if they won't work properly than you would face problem like this.......contact your service authority. it cannot be solved by your own
May 14, 2009 | Kenmore Refrigerators
Water leaking out freezer door--unit is still making ice
There is a shroud at the back of the freeezer. (Mine was a GE) but under the shroud is the evaporator coils and also a heating element to defrost the coils during the defrost cycles. Mine had the gutter underneath misaligned and the water went into the freezer and froze instead of going down the drain. I thought it was a ice maker leak until we found that. The weird thing is we had the refrigerator for about 6 years before it started leaking like that.
It has worked fine for about a year since that "fix"
Jan 05, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
225 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
