Question about HP LaserJet 4 plus Printer
Add CR to LF on HP LJ 4Plus
Is there a configuration option on a HP Laserjet 4 Plus to force a carriage return for received line feeds?
Why does the roller on my commodore typewriter not roll on the ends but rolls with the handle?
We now only are used to return. There used to be a CR Carriage return and a LF line feed.
Look if your type writer does get both signals. Or is it really an old school mechanical thing, then it is working correct.
Jun 19, 2014 | Computers & Internet
Dpu 414 stacks lines
Set SWDIP switch 1, switch number 4 to ON. That switch controls whether when you get a CR (Carriage Return), you get just that carriage return or a CR-LF (carriage return + line feed). You need the latter. Setting the switch to ON will accomplish that. Have a good day.
Jul 02, 2012 | Seiko DPU 414 Matrix Printer
Does the HP 5 and the HP 4plus use the same main motor assembly?
Yes,
Part number RH7-1169-000CN - for HP LJ 4+ and HP LJ 5 are the same :)
Apr 06, 2010 | HP LaserJet 4 plus Printer
Is the HP LaserJet 4Plus compatible with Windows 7?
if it has a vista driver it is... vista drivers work on windows 7
Dec 21, 2009 | HP LaserJet 4 plus Printer
HP Laserjet 4plus chewing us paper
This is most likely cased by a dirty paper feed path so it will need cleaning and blowing out. Make sure that all the internal paper guides and separators are free of obstruction. Make sure that the fuser area is clean that the internal paper guides are ll in place and operate freely. Also clean it with a vacuum with a soft haired brush tool to avoid any damage. Also fan the paper before using it and do not overload the print paper tray. Also check that the pick up rollers are not work or contaminated with dirt / debris etc. Also make sure that the print tray is not overloaded and make sure that the paper is not to tightly held by the tray side guide.
Sep 30, 2009 | HP LaserJet 4 plus Printer
What does this key do?
LF means line feed. This was a common key on typewriters. Now we just use the "Enter" or "Return" key.
Return meant the return of the carriage (the part on the typewriter that holds the paper and moves side to side as you type).
Basically, this just starts a new line for your text.
You can see this by typing a text message then add the LF and keep typing.
You can see the above text by scrolling with your finger.
Apr 08, 2009 | LG Dare VX9700 Cell Phone
The lcd screen on our HP Laserjet 4 printer is barely readable. Is there something inside the printer that we can replace? We cannot locate a manual for this printer. Other than that, it is a virtual...
My first thought is probably what you've already considered as well...the LCD display is old and the functional elements are wearing out. My second thought was that it would probably be cheaper to replace than to repair. Nevertheless, I can try to address your question with a couple of ideas.
There are actually quite a number of "HP Laserjet 4" printers including the Laserjet 4, 4m, 4plus, 4m plus, and so on. Here's the list:
Product Search Results
Here's the webpage for the actual Laserjet 4:
Laserjet 4 Page
You should find a link to the manual for this product on that page. You can also ask a question directly on the HP support forums:
HP Laserjet Support Forums
Those options should give you your best bet on replacing the LCD if the option is reasonable or possible. Good luck.
Oct 07, 2008 | Office Equipment & Supplies
Oki microline 280
Check printer setup where you define carrige return and line feed options. Alot of times you need to set printer to do an auto CR on reciept of LF or auto LF on reciept of CR. I run into this all the time.
Aug 02, 2008 | OKI MICROLINE 280 Elite Matrix Printer
REPAIR
Yemmitty,
According to the HP LaserJet 4 plus service guide. Your error code of 57.1 indicates the following;
1) The printer's gears are siezed
2) The DC controller or main motor is defective.
Nov 10, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
Seeker5211
Seeker5211
