Question about NorStar T7406 Cordless Phone
I have two newly refurbed units that keep scanning, but won't pair to the base. I have done everything the installaton manual says but I must be missing something or the base unit is defective.
  • contact901 Sep 10, 2009
    This is a Norstar T7406 base with 2 cordless handsets. I have tried connected and disconnected from the KSU, also tried pairing only one handset at a time with the battery removed from one or the other handset. I can change the password but the S.S. code setup always comes back " send error !"
  • 192 Answers
Depending on the base station that you have, the base station may only accommodate from 1 to 4 - (T)7406(e) sets.
Is there more than one link to the base station, meaning have you programmed new sets, and have these new ports from the norstar been attached to the base station.
1 port = 1 phone. You can see on top of the base station if there are more jacks that you can plug your ports into.
The T7406 sets are digital sets, meaning that they require their own extension numbers, but afterwards you can program Answer DN's to the sets, making each set capable to answer any other phone.
Posted on Sep 10, 2009
Won't hold a dial tone go new batteries still a problem
Maybe trying to pair the handset with the base station will solve your problem. Look in the manual how the pairing procedure is done for your phone.
If the pairing procedure is done, and the handset finds the base station and there's stil no dial tone, check if the cable from the telephone line is plugged in the base station of the phone and check if the other side of the cable is plugged in the wall phone outlet.
I hope this will solve your problem.
Feb 13, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
Motorola baby monitor won't link
I would say try disconnecting the battery and waiting fifteen seconds, then reconnecting the battery.. If you can't disable the batteries...
I would recommend seeing if there is anything interfering with the wifi between the monitors.
Oct 22, 2012 | Motorola Mobility Mbp16 Digital Audio...
Just bought used pair of wharfedale 28637WH headphones dont know how to connect them to av unit. i cant download manual as using ps3 to do this. can u help with this? thanks craig
The base station for these headphones will have to be plugged into your AV unit. This is done with either a 1/8" jack or a 1/4" jack. Once the base station is plugged in, you will be able to use your wireless headphones.
Mar 15, 2011 | Audio Players & Recorders
Can I connect a CL82409 handset to a CL82409 base system
Yes, and no.
When you buy the new corded base station (CL84109) with 1 handset, that base unit by default is "paired" with only the 1 cordless handset that came with it.
While you can plug both base stations into the landline wall plugs (RJ-11), and when the line rings, both base unit phones will ring and will each operate as independent corded phones would.
But, in this scenario, the cordless phones communicate only through the base unit they are Paired with. The cordless phone paired with the CL84109 corded base unit will not be able to transfer or Intercom between the cordless phones paired with the CL82409 base unit.
However, if you want to transfer the cordless phones that originally came with the CL82409 base unit to work directly with the CL84109 corded base unit, you can likely "Pair" them to work directly with the CL84109 corded base unit for a total of 5 cordless phones to be paired to the CL84109 base unit.
Consult the User Guide that came with the CL84109 base unit for instructions on how to Pair additional cordless phoned to this base unit.
The CL84109 can be expanded and paired with up to 12 cordless phones. So, this should be do-able.
Keeping in mind that the CL82409 will no longer have any phones paired to it and will thus be useless from that point on. (unless you pair more expansion cordless phones to it again)
Mar 13, 2011 | AT&T CL82409 Cordless Phone
I can not use the handset. I can use the speakerphone. I put new batteries in the handset and the bottom of the phone. When I pick up the handset I do not get a dial tone, it squeakes or beeps.
You need to pair the handset to the base unit, hopefully you still have the manual. Because you didn't give a brand/model I can not give directions on how to pair the handset to the base unit.
There should be a menu button located on the base unit, just push it until pairing (or something like this) shows and you should be able to complete the pairing operation.
Hopefully this will head you in the right direction.
Mar 06, 2011 | Cell Phones
Base unit appears to be working, but neither of the charged handsets will work. Both are showing red and beeping, but will occasionally go green for a second before going back to red and beeping.
The units aren't paired. Call Graco at 800-345-4109 to have them walk you through pairing it. I'll try to explain what they just walked me through:
-Turn off all units. Make sure nursery and 1st parent unit is plugged directly into wall.
-Hold negative volume down on 1st parent unit. Keep holding it down.
-Press on button on 1st parent unit and let go.
-When you hear a beep, let go of negative volume button on 1st parent unit and then press it again.
-When you hear the second beep, let go of the negative volume button.
-If you have done it correctly, the 1st parent unit should have one red light at the bottom and the rest of the lights should be green.
-Turn on nursery unit and the 1st parent unit should pair with it.
-Repeat the above with the 2nd parent unit.
Nov 18, 2009 | Graco Imonitor Digital Baby Monitor
Symbol Scanner LS4071-I1us
transltor and data comparison failed?
Jul 27, 2009 | Symbol LS 4071 Handheld
I have the panasonic kxtc1175bxb cordless phone pair the handset
sorry, it seems that they have no manual for this model online yet. however, the procedure to reset handsets might work if you go to page 35 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf") good luck!
Feb 04, 2009 | Panasonic KX-TG1033S Cordless Phone
Pairing my headset to the PS3
Ok people, here is how it is done- Turn off your bluetooth. When it is off, press and hold the main button (power button) until it flashes(keep holding even after it flashes). The light on the device should turn solid blue (instead of flashing) now you can let go of the power button. My device was picked up immediately... after 2 hours of trying to figure it out of course, lol. Hope it works for y'all!
~Live long and prosper ;)
Jan 06, 2009 | Radio Communications
ELBT595 Handset Not Turning On
Check the handset battery -- if there is a slight "bulge" on one side (ie: not COMPLETELY flat) then the problem is with the battery. I had that problem and had to order a new one. That said, I just installed the new battery, and while it now charges, the handset won't connect to the base unit. The base unit works (tried the speakerphone), but there is not connection between base and handset.
Feb 18, 2008 | Uniden ELBT595 Cordless Phone
NorStar T7406 Cordless Phone Logo
214 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
