Question about Maytag MEC5430 Electric Cooktop
My cooktop keep burning the coil element
My cooktop is burning the coil
    Novelist:
  • 222 Answers
Nid to replace the parts,but u nid an expert tecnician to replace it..
tnx gerbee
Posted on Sep 13, 2009
My electric Bosh cooktop is humming when the element heats up. Is this normal?
If the noise is emitting from the element the most likely cause is a bad connection where the element plugs into the receptacle. You are likely hearing the voltage/current sparking/arcing between the terminals of the heating element and the prongs inside the element receptacle. When this happen it will require replacing the receptacle and the element because it will burn off the contact points of where the two touches to make the connection. If you just replace the element and not the receptacle too, it can cause the terminals on the new element to burn out. Perhaps get a qualified person to have a look at it - it just may need a service...
May 07, 2017 | Cooktops
Front left burner will not heat up, all the rest are working fine
You either have a bad element or infinite switch. If you are handy you can do a few checks to determine which part is needed or if both parts are needed. On a failed element most of the time you can see a burn/break in the coil windings. You can check for continuity. On the infinite switch you can do a continuity check as well. If you are unsure of the repair I recommend change out both. The parts are affordable and you will have your cooktop up and running sooner.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/W0811053-00001.png
Please rate me "4 thumbs" if I was helpful.
Have a super day!
Dec 15, 2010 | Whirlpool RCC3024 Electric Cooktop
Coil element on kitchen aid model ker1201 slow to
some of the coiled eyes have two coils(elements). one of the coils can burn into at any point around the element rendering it useless while the other can still work. when you lift the glass top you will see the elements are shaped like springs. the elements metal is very britlle.it is you have to replace the entire eye to fix it. the coil most likely had a very gap in the break and acted like a short making and breaking connection until the gap was too wide then nothing. easy fix. just replace the entire eye (power UNPLUGGED!!!) match the old wires with the new part as you take the old part off. I mark them even with a sharpie. it has 3 to 5 wires on that plug into the eye unit. estimated cost for the part online is about 40 to 65 bucks.
Jun 07, 2009 | KitchenAid 30 in. KECC506R Electric...
GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Jul 13, 2008 | GE Profile JP930 Electric Cooktop
Heating element will not come on
The best to test that is to remove the top and take the outer coil and use it on any of the other burners to see if it heats up, then youll know for sure is the element or the switch.
Eddie Rentas
Tupper Lake NY
May 14, 2008 | Jenn-Air JED8430 Electric Cooktop
Solid cooktop elements not heating,tripping breaker switch in panel box,w&w/o cartridges
By cartriges do you mean the sockets that the element plug into? If so when one of these burn out it will cause these type of problems.
Jan 15, 2008 | Cooktops
Electric Cooktop Heating Elements Get Hot, Turn Off, Get Hot, Turn Off
no they are made to cycle that way they are halagen and cycle with a sensor dont work like the old coil ones do enegey efficent and hotter than old coils dont use them without a pan on them to reflect heat back to the sensor to prolong their life
Dec 29, 2007 | Viking 31 in. VGSU101 Gas Cooktop
New Whirlpool Cooktop Problem...Maybe.
The function 3 element are normal / depend to the intensity adjustment / the small 4th element are set for pre heating w/out burning , try to sdjust in lower adjusment or ann switch for pre heating.
Dec 04, 2007 | Cooktops
Maytag MEC5430 Electric Cooktop Logo
110 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
