Question about Wise Solutions Wise Installation System 9 Professional Edition for PC
Install luan over concretehow to secure plywood screws or glue?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
The Home Depot does sell a Laminate flooring glue, I can't think of the exact name of the product, but, it is a Roberts brand product and comes in a brown labeled plastic bucket in several sizes. It comes in pint, quart, gallon, and 4 gallon size buckets. A quart size bucket will cover approximatly 85-100 sq. ft. area with a 1/16 inch trowel. You can use up to a 1/4 notched trowel. The best application would be to measure out where the 4x8 sheets, or whatever size you are using, and apply the adhesive in each area and apply the wood. That would allow optimal working time. As a side note, I would place a piece of plastic, such as saran wrap, taped around the edges to seal the plastic to the floor overnight to see how much moisture is in the floor. This will have a big impact on the adhesive if the floor sweats, causing moisture to mix with the adhesive during dry time. The moisture may even prevent the adhesive from curing all together. In that case you may need to prep the floor before beginning work with a sealer that will not react with the laminate adhesive or whichever adhesive you decide to go with. I hope this information helps.
Posted on Sep 30, 2009
  • 55 Answers
You are much better off using an adhesive rather than screws. Home depot sells several good flooring adhesives, usually in aisle 8 that will do the trick just fine
Posted on Sep 16, 2009
What do i need to know about installing wood floor
What type of wood flooring is it, is it glue down or nail down, engineered ( like plywood) or solid? Is the subfloor wood or concrete ect.
Always follow manufactures specs as far as acclimation, type of adhesive and expansion joints.
Feb 26, 2016 | Building Materials
Hi i am not sure on how to adjust the hand brake on 1993 ford telstar
RENAULT MASTER DCI 120
Registreringsnummer
AE 19053
Understellsnummer
VF1FDC1HH39195287
Registrerings?r
2008
8200633634T
X043 Security I am Luan Bytyci I nyd code Luan · Sep 13 2015, 02:13 PM
Hei ka dere sende radio kode for Renault Master 2008 .8200633634TX043
Pr
Sep 14, 2015 | Ford Cars & Trucks
How to remove glue
Use a power sander. Sand it smooth. The new adhesive should stick just as well to the glue areas.
Jun 02, 2014 | Adhesives, Coatings & Sealants
Bosch Exxcel Vario Perfect washer
What You Do is go and get Yourself a Sheet Of Thick Plywood, At Least 3/4", Get Marine Grade because the Glue Will stand up to Water. If you are installing this on a wood floor, you might want to put a few Screws Where you can Screw into a Joist Having the wood Wider than the Washer is a Good Thing, Washers Inherently want to Jump Around, Sounds like your floor is acting a a springboard, you can double up on the Plywood too.....~~*BB
Jan 03, 2018 | Washing Machines
What kind of glue can i use to glue .030 4 ft by 8 ft aluminum sheets to plywood for exterior use ie camper
You can use Loctite PL Premium 10 fl. oz. Advanced Polyurethane Construction Adhesive or liquid nails adhesive. The PL may be available in a pail. It will permanently glue aluminum and plywood together.
Jan 31, 2014 | Adhesives, Coatings & Sealants
HOW CAN I INSTAL A TOILET ON A MOBILE HOME FLOOR
I live in a mobile home park. I do all the electrical and plumbing and everything else. You can put an ordinary toilet in. So long as there is a flange. If there is not one you can put one in anywhere you choose. Then underneath you can run the 3 inch line to the main trunk going to the sewer. Don't worry about it freezing being below the insulation. Keep the angle so that it empties fast so there is nothing inside to build up and freeze. If where the toilet used to be has some bad plywood cut out a square to put in a square of new plywood. Measure where the old one was beforehand and mark where you want to put the new 3 1/2 inch hole (usually 12 inches from the framing to center), cut your hole using screws with large heads (maybe even stainless steel) screw down the flange. Using solvent glue the new section to the old section etc.
Oct 19, 2013 | Home
When do I need moisture control for wood flooring?
You need moisture control if laying below ground level or on concrete anywhere as concrete is porous
Jan 03, 2010 | Crafts & Hobbies
APPLY WEATHERSTRIPPING TO CONCRETE
You could try contact cement.
If it's attached to a metal strip I would use screws on it though. Not sure of what kind/brand of weather stripping you are using.
Oct 09, 2009 | Crafts & Hobbies
Wood Lining to Folding camper is wet
the best solution is to remove the spongy wood and replace with marine plywood
one possible fix is to glue(liquid nails) 4x8 vinyl sheets(used for bathroom walls and ceilings) over the spongy wood you should also determine where the support ribs are located and use rust proof exterior ( like deck screws) and put a washer through the screw and screw through the vinyl and sponge wood into the rib/stud to secure the vinyl do this about every 10 inches on the supports
finally caulk the edges and seams and put a lattice type of slat(1inch wide by 3/8 thick by 8 ft long on all exposed seams
tools needed small gig saw variable speed drill
caulking gun
I
Sep 09, 2008 | Sport & Outdoor - Others
Wise Solutions Wise Installation System 9 Professional Edition for PC Logo
853 people viewed this question
Top Wise Solutions Computers & Internet Experts
David Payne
David Payne
Are you a Wise Solutions Computer and Internet Expert? Answer questions, earn points and help others
