Question about Bosch BSG71310UC Bagged Canister Vacuum
Where does the hepa filter go
There is a microsan filter in front of the motor.
my model number isbsa 210101 bosch compact plus
margaretmrozek@yahoo.com
  • 430 Answers
Look for a removeable grille at the top or back of the vac shaped similar to the filtter. The filter is an after filter so it sits beyond the bag
Posted on Sep 10, 2009
Hi , I am looking for a Vacuum bag and filter for my Rowenta Vacuum cleaner Model number:RO1767R1 Type: VC20PE3 Ref. number : RO1767R1/4QO-3312R.
Here's one source for the ZR0039 01 paper bag and microfilter for the RO1767R1 compact canister vacuum: https://www.alza.co.uk/rowenta-zr003901-d308208.htm?catid=18850976 . This is a 6 pack of the bags. This vendor also has the Wonder Bag for this model: https://www.alza.co.uk/rowenta-compact-wb305140-wonderbag-d308211.htm?catid=18850976 . I can't find a source for the HEPA filter version (ZR0041 01).
This store has other locations. You can also find the vacuum bags here: https://www.alzashop.com/rowenta-zr003901-d308208.htm?catid=18850976 .
I hope this helps.
Jun 03, 2016 | Rowenta Vacuums
I have a Eureka Contour model 2900 type A upright vacuum, the roller works fine nothing clogged, took it apart motor blade is free of debris, no suction from tube and blasts OUT air from the front HEPA...
Even with your explanation,it seems the hose is clogged.Try taking the hose off,then blow through it or pour water through it.If this doesn't do it,make sure the suction canals are going to the proper areas.
Apr 04, 2012 | Eureka 2900A / 2901A Contour Bagged...
Filter mesh holder is damaged, locking holes are broken will not lock in place - need new filter mesh
Hi Joe: The model has been discontinued and difficult to find replacement parts. I located a few online suppliers offering a HEPA Filter that fits the BUC11700UC. See here:
http://www.vacuumcleaners.net/bosch-buz200hcuc-hepa-filter-for-bagless-jet-upright.html or
http://www.allergybegone.com/boshepfilfor4.html or
http://www.wikio.com/product/vacuum-parts-accessories-compatible_with_bosch-reviews-12020-page3-sort0.html
Is this the part you are looking for? The third site above does offer other replacement parts if you are looking for a different filter piece.
Thank you for using Fixya!
Jan 14, 2012 | Bosch BUC11700UC Cyclone Jet Bagless...
What would happen if I would take out both hepa filters from my rainbow e-series? I do need extra super filtering - previous versions didn't have it and it was ok... Hepa filters are not so expensive...
It won't hurt anything if you don't have a problem with the tiny particles that will be blown into the air. The Hepa filters trap small particles that can be unhealthy to breath. Most of these particles consist of human skin and hair, pet dander, dust mites, etc.. Many people are not bothered by these tiny particles. Others, like asthmatics, can have serious complications from them and the Hepa filters really help.
Nov 24, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Do I need to replace the HEPA filter?
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Sep 08, 2010 | Bissell Healthy Home HEPA Bagless Upright...
No suction up into the canister
Try cleaning the Hepa filter and the rear filter behind the motor
May 17, 2009 | Bissell CleanView II Plus Upright Bagless...
Bosch BSA2222UC canister vacuum shuts off after 5 minutes
You have a plugged vacuum indicator port. There will be a tiny hole somewhere near the hose inlet. Just clean it with a dry toothbrush. This will allow the vacuum pressure to equalize on either side of the shut off switch.
Jan 03, 2009 | Bosch BSA2222UC Compact Plus Bagged...
Bosch Vacuum Cleaner: I changed bag. Cleaned out all suction hose and hepa filters, however, my 1450 w 12 amp upright vacuum cleaner will die after five minute run - overheating. Please advise.
Greetings from GoVacuum.com,
It sounds like you may have a bad thermal switch inside the machine. Most vacuum cleaners have a switch connected to the motor, so if the vacuum cleaner is running hot, it will shut off to prevent any damage to your motor. You did all the right things by checking the bag, making sure the hose was NOT clogged, and replacing HEPA filter.
Most of the time on canister vacuums, the reason is caused by a clog in the hose, or somewhere in the powerhead. If you're sure that there is no clog anywhere, it is going to be the thermal switch on the motor.
Here's a link to the parts schematic for the Bosch upright vacuum. I hope it helps you in determining how to access the thermal switch. A word of warning to you before you try it, this is a very tough vacuum cleaner to work on, you may want to bring it in to a vacuum repair shop, as this is not an easy repair.
Here's the link;
http://www.essco.net/Customer/SchematicFrame.asp?FileName=Turbo%20jet%20upright.pdf
Please let me know if you have any other questions,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Aug 16, 2008 | Bosch Vacuums
It just shuts off!
Some of these have the Hepa filter on the back, if so there will be a door to access it. If there is one, some had a reset button that you push, mainly for when you change the fifter, if it has one, push that reset, if it needs to be re-set, it will shut off after a seconds. Remove the Hepa filter and look see if there is a reset button. https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM, this will give you a link for a user manual. If you disconnect the hose, will it shut off or stay on. If it stays on then there is a clog either in the hose, wands, or the inlet down by the brush roll. If it goes off, and there is no reset by the Hepa filter, then there could be a problem with the motor or motor protector.
Jan 30, 2008 | Bosch BSA2200UC Compact Plus Health Guard...
Bosch BSG71310UC Bagged Canister Vacuum Logo
128 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
Billy Detlefsen
ray gallant
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
