I'm running vista. My laptop just won't detect the router. These is a little hazard warning that says limited connection. I tried reseting the router over 20 times and unplugging and plugging it back in. I try to go to the ip website they give you in order to be able to configure it and it wont even go there. it displays the usual offline web page. Is there anything else I could try to make this work? Anything is welcome.
Comments:
Dec 10, 2007
- I've tried a wired connection and that's when the limited connectivity warning shows up. When I try to connect wireless my laptop doesn't even detect a network.
The router should be working. All lights are working perfectly, except of course for the WLAN which is probably why my laptop doesn't pick it up.
-   im running a pc through a wireless router and cable modem as my pc doesnt have an adapter. ive now tried to connect a laptop to the wireless connection and although the laptop is picking up the connection it keeps saying it cant connect to the router.-   julie133
Assuming your laptop and router are wireless, make sure you enter your security passcode for the network correctly. A mistake on the passcode will prevent you from connecting.
Also, try to reach the router's configuration from a wired connection. Once you do so, make sure you don't have the router set to deny access to unknown computers (that is, make sure any kind of "access list" is turned off).
Was this helpful?
Yes
No
Popular Solutions for D-Link AirPlus DI-524 Wireless
DI-524 Wireless Rourter D-Link To connect my laptop wireless I have to change the port. To use it on...
(More)
DI-524 Wireless Rourter D-Link To connect my laptop wireless I have to change the port. To use it on my desktop same thing. how do i correct that?
Using D-Link wireless router unencrypted and want to encrypt with the WPA protocol that it uses. The...
(More)
Using D-Link wireless router unencrypted and want to encrypt with the WPA protocol that it uses. The original installation CD no longer will work with my newer Vista OS. How can I get this thing encrypted?
Ihave xpdesk top computor not connected, and have a laptop vista connected to wireless router how...
(More)
Ihave xpdesk top computor not connected, and have a laptop vista connected to wireless router how can I connect desktop to wireless system
DL 524 signal intermittent! The wireless connection drops when more than 1 user is trying to use the...
(More)
DL 524 signal intermittent! The wireless connection drops when more than 1 user is trying to use the internet at the same time. It also drops when I get an incoming message on my blackberry.
