How do i clean the tv screen? and do you know were to get a replacement protective screen?
  • 4,234 Answers
FIrst of all, the screen (if available) could cost in excess of $100 depending upon the make and model of your set. Please supply this information and I should be able to provide the part number(s) and cost. These screens can be cleaned with cloth dampened with a non-amonia based window cleaner. There is no need to unplug the TV as long as the cloth is just dampened. I would, however, turn it off.
Dan
Posted on Sep 10, 2009
  • 294 Answers
Its a simple Job 1. Buy anti-static wipes from nearby grocery.( 3M Scotch Brite High Performance Cloth is an excellent choice for screen cleaning 2. Turn off TV and disconnect it. 3. Now wipe off the dust without much pressure on screen. 4.Use a water dampened, non-abrasive or cotton cloth to wipe across the TV screen's surface to remove pet hair, dust and fingerprints. Dry the surface of the TV screen immediately after damp wiping the screen. also you can Buy the screen from different sources as per your convinience. which should not cost You more than $ 10.00 i guess
Cheers!! Gizokieth
S.N RS051DL103300. I just want to know if you sell a protective screen that is anti glare?
Anon. Protective screen that is anti glare, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
NuShield Anti glare Films In TV Room Design
FAQ Answers for Questions on our TV Screen Protectors
TV Screen Covers ScreenProtek
How to rid your HDTV of reflections
May 26, 2016 | Televison & Video
The screen on our 52 inch TV needs cleaning-inside and out
The outer screen is a protective screen. it is just glorified plexiglass. just use a soft cloth slightly damp.
Apr 09, 2009 | RCA D52W19 52" Rear Projection Television
Removing the protective screen to clean
The speaker grill pulls off, you will find the screws under there
Sep 06, 2008 | RCA D52130 52" Rear Projection Television
57H93 Toshiba
Protect screen Part # 23311038.......117.30
Fresnel screen ( inside ) # 23311014 ...65.47
Lenticular screen ( middle) # 23311128....81.96
You should only need the protector screen......T.
Nov 28, 2007 | Toshiba 57H93 57" Rear Projection HDTV
Panasonic tv 27"
I not familiar with this model but, If the video select button is below the screen. I would suspect "windex damage"! Cleaning screen by spraying directly on crt causes this is some sets. The button gets corroded or part of this circuit. If this is the case, replace/ inspect/clean around switches.
Protection diode(s),capacitor across switch, faulty switch or bad processor input are other causes.
Oct 26, 2007 | Sanyo DS27800 27" TV
Projection tv
Yes you can safely clean tv, just remove front speaker panel and you should see screws holding up front prot. screen. Becareful not to snap screws. You can take screen out and there is a mirror that you can clean and 3 lenses.
Apr 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
Mitsubishi VS-60607 TV bottom of the screen has dark areas
take the front bottom black panel off. it pulls off. unscrew the little panel in the middle. reach up and pull the wires down gently. unplug the 2 conectors gonig to the big metal frame holding the screen in. unscrew the 2-4 screws holding the big metal frame. pull up put screen on sheet to protect it. unscrew the screws holding both of the screens in. Pull apart and clean
Jan 23, 2007 | Mitsubishi VS-60607 TV
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
