Question about Dell Latitude D610 Notebook
I am getting a dst short test failed error code 1000=0146
I have receded all drives the drive is there during start up but I am still getting error.
  • 776 Answers
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Posted on Sep 10, 2009
Dst short test fail error code 1000-0146
DST stands for Drive Self Test, if it fails the test it means your drive is failing or has failed. replace hard drive
Jun 02, 2014 | Dell Latitude 100L Notebook
Short dst failed fix
Drive short test failure usually indicates what it says, which is a fault with the drive, but you state that this happened after an update (don't trust windows update!)
do you have have any error codes this could indicate further the exact problem. but usually this type of error would indicate a drive fault which would require replacing the drive
Cheers D
Mar 03, 2014 | HP Pavilion g6-2210us Notebook Laptop PC
Replaced my hard drive after knocking my laptop and receiving a DST short test fail error. Upon receiving the new hard drive all was working well until it started to slow down 2 weeks later. Now I've...
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Feb 14, 2013 | Computers & Internet
Sudden Blue screen display on my Dell Inspiron 1545 with MS XP OS-Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus...
Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
Nov 03, 2010 | Computers & Internet
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
Dell Latitude wil a DST short test fail. error
you are correct, time to replace the hard disk drive.
Jan 28, 2010 | Dell Inspiron 6000 Notebook
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
Dell latitude d600
Greetings AROD718,
This error message is telling you that your hard-drive is nearing OR has already failed.
I would contact a buddy or go somewhere local to get Data recovery ASAP or if that is not important to you start shopping for a new hard-drive.
Hard drives are not very expensive and are simple to install, if you need further assistance please reply back!
Good luck,
Shawn
Oct 31, 2008 | Dell Latitude D600 Notebook
I got the below error ... is it possible tot ake my backup from the HDD?
A 0146 error means that the hard drive has a failing sector, and the drive will need replaced. If it's operable, then back everything wanted or needed up, because it will fail completely if it hasn't already.
Aug 26, 2008 | Dell Inspiron 6000 Notebook
DST Short Status Test (Error detected)
DST stands for Drive Self Test, it means your drive is failing.
I would get a new hard drive and USB enclosure, install new drive in laptop and install windows, then take the old drive and install it in the USB enclosure so you can connect to your laptop when windows is running and restore your files, assuming the drive is not completely dead.
thanks for rating
Jan 10, 2008 | Dell Inspiron 6000 Notebook
Dell Latitude D610 Notebook Logo
1,243 people viewed this question
Alun Cox
