Question about Philips Televison & Video
How to upgrade new software for dvp32661_94.bin to which software?
Need the latest upgrade software
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF5321D/37&slg=en&scy=US&mid=Link_Software
Under firmware upgrade software.
Just follow the instructions and you'll be good to go :D
please rate if this helps!
Mar 08, 2011 | Philips 42PF5321 42 in. EDTV-Ready Plasma...
I have a Philips Home Theater model HTS3051BV/F7 C and I need to change for DVD region free or for DVD region 4, but I have not get procedure for this model. Can you help me please?
try actualize the firmware..go to http://www.p4c.philips.com/cgi-bin/dcbint/eula.pl?slg=ESP&ctn=HTS3051BV/F7&dct=FUS&link=http://download.p4c.philips.com/files/h/hts3051bv_f7/hts3051bv_f7_fus_aen.zip ....
1. Extract the .bin file from the zip file downloaded from this site.
2. Burn the *.bin file to the root directory of a blank CD. Make sure the CD burner is set to
finalize the CD.
3. To select Disc upgrade, press the menu button on the remote. Select Settings\Advanced
Setup\Others\Software Upgrade\Disc upgrade.
4. Use the cursor up/down button to select "Yes", and then press OK. The Disc tray will open
automatically.
5. Insert the Disc. Close the Disc tray.
6. After the disc has loaded, a confirmation message will appear. Select "Yes" and press OK to
start uploading.
7. After the disc update is finished, the unit will shutoff and eject the disc. Do not unplug or
turn the unit off while the software upgrade is in progress.
SW Version Problem resolved
1.005 - The Dolby Pro Logic feature does not function when
Dolby digital two channel audio is the source using
SPDIF (Digital Audio In) input.
1.006 - Unit shuts off after 30 minutes. Do not use the
Network upgrade to this fix this problem.
source philips.com
Feb 14, 2011 | Philips HTS3051B/F7 Theater System
WRT120N no .bin or .img file in firmware update download
Hi Friend
in order to upgrade the firmware please follow the steps:
1. Click the link (http://homesupport.cisco.com/en-us/wireless/linksys/)
2. Enter the model number of the router and hit enter.
3.Click Download Tab
4.Now enter the hardware version of the router (which you can find by turning the router upside down)
5.Now you can download the firmware which is a .bin file and save it to the desktop.
6.Open the router page and click Administration and click Firmware upgrade.
7.Select the file from the desktop by clicking Browse and start upgrade.
8.Turn off the router for 30 seconds after upgradation and turn it on..
i hope this will resolve the issue.
Regards
Chiranjeet
May 21, 2010 | Linksys WRT120N Router
I got files from internet to update 2009 map for my gps, but I don't know how to get them into the gps.
1. Download the SONYNAVU_U73T_3.2.CN.BIN file to a temporary or download directory.
2. Connect your nav-u personal navigation device to the computer using the supplied USB cable.
3. Power on your nav-u personal navigation device and wait until the "Connect to PC" message is displayed on the nav-u screen.
4. Start the nav-u Tool software on the computer.
5. At the "nav-u tool" window, click "Upgrade System".
6. On the right side of the Upgrade Screen, verify that the target version is 3.00.
7. On the left side of the Upgrade Screen, click the "Browse" button, and go to the directory where the SONYNAVU_U73T_3.2.CN.BIN file was downloaded and then click "OK".
8. In the "Name" box, click to select "3.02 cn NV-U73T" update, and then click the button.
9. After the update file is transferred to the nav-u device a "Transferring Upgrade file completed." message is displayed on the computer.
10. After the system software update is complete, the nav-u device will automatically shut down and restart.
Mar 18, 2010 | Sony NV-U73T GPS Receiver
Magnavox 37MF331D/37 keep asking for software upgrade
Your set either has a bad SSB (small signal board) or needs a software upgrade. Try the upgrade first by going to http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=FLAT_TV_CA&sct=LCD_LARGE_30_40_SU&grp=TV_GR&session=20090830171041_4.131.87.247&ctn=37MF331D/37&mid=Link_Software&hlt=Link_Software
Download the latest software release for your set then follow install instructions that are contained in the user manual for your set.
Jul 22, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Asrock p4i65g motherboard
Your current motherboard is an mATX form factor. I recommend staying with that form factor for your new motherboard if staying with your current case. When upgrading to the new board you choose don't forget that you may need to upgrade the power supply unit also. You should upgrade to either a socket AM2+ board with dual core amd cpu or socket 775 board with Intel Duo Core2 cpu.
May 02, 2008 | Intel Motherboard
1140E phone upgrade
C1B is ancient UNIStim firmware. You cannot downgrade to it. Try converting to a more recent UNIStim version. You can download firmware from www.nortel.com/support.
Mar 17, 2008 | Nortel 1140E
Upgrade firmware on a cisco ASA 5500 firewall
This is for the pixes, I haven't upgraded an asa yet...should be close or the same
* find latest version of code, these are usually *.bin files located on http://www.cisco.com/cgi-bin/tablebuild.pl/pix
* confirm the flash and RAM requirements of the PIX OS software versus what the PIX has (”sho ver”)
* make sure you have a backup of the old PIX OS and PDM to the tftp server (or at least confirm the software is there)
Note: You cannot back them up from the PIX, so you will need to download them and put them on the tftp server * put in a change control form
* once change controls confirms date/time do the upgrade:
wri mem*** only if you save your configs via tftp wri net conf t ca save all copy tftp://your tftp server ip/pix635.bin flash:imageskip this if you don't use pdm copy tftp://your tftp server ip/pdm-304.bin flash:pdm *** if this is a failover pair, upgrade the other pair reboot
Sep 06, 2007 | Cisco ASA 5500 Firewall
Televison & Video Logo
106 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
