Question about Toshiba e-Studio 161 Copier Copier
On our Toshiba e-studio 161 we have a white line that appears 3/4 of the way down the page. We have tried cleaning the glass under the spf with no results
Yes, in this technology if laser not hit the drum, white line on yield (quite oppse to analog one)
Posted on Nov 12, 2009
    President:
  • 1,187 Answers
Does the line go away if you use the flatbed, but not the spf?
Look at the glass again. On the far left, there is a glass strip. There is a "speck" of white on the glass.... clean it off & try the fedder again.
Hope this helps!
Posted on Sep 10, 2009
  • Just Gort
    Just Gort Sep 10, 2009
    oops... sorry .. that would produce a "black" stripe, not a white stripe, on the paper....
    If it is a very thin line, the it sounds like the laser is not imprinting onto the drum.
Line is coming in copy ,while taking photocopy line is coming on the photocopy page
If happens only when using doc feeder it is a spot on small glass on left below doc feeder. clean it well
Feb 10, 2014 | Toshiba e-Studio 161 Copier Copier
E studio 161 does not work with windows 7 please help I have driver of windows xp
Toshiba e-studio 161 drivers are available Toshiba Official Support
Click 'Support & Drivers' (Top Right Corner)
From the page that appear Choose B/W Copiers
then Choose e-Studio 161
Select the drivers and download for your Operating System (i.e. Windows 7)
Also, Below is the direct download link for Windows 7 Drivers
E-studio Drivers for Windows7 (32Bit)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 28, 2011 | Toshiba e-Studio 161 Copier Copier
I want drivers for toshiba zerox machine studio 161 for windows xp2
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
Jun 03, 2011 | Computers & Internet
Why is there still a line showing through middle of pages when scanning/printing via top document tray of toshiba e stuido 351c? I know who to clean glass area but not top tray.
Does this line appear when you try to print to the machine? Or when you make copies on the scan bed? If so, then you most likely have a mark on the drum unit. If not, then the **** glass that the document feeder uses is located to the left of the large glass surface, attempt to clean that and ensure that no mark or scuff marks are on the **** glass.
-David.
Nov 05, 2010 | Toshiba COPIERS E-STUDIO 3100C Copier
How can i serive estudio161
Hi how are you this is jack ... (jack_pak@hotmail.com)
Dear your copier e-studio 161
you open the upper glass(open the upper glass side cover open the all screw this cover).and clean the scanner lamp and scanner reflacters... when you clean it your copier copy quality much batter.. (BUT VERY CARE FULLY DONT DAMAGE EVERY THING)
PLEASE VOTE ME ..
Thanks .
Best Regards,
Jun 04, 2010 | Toshiba e-Studio 161 Copier Copier
A band of lines appear 3/4 down on paper through the top loader, but does not appear when we place the paper on the scanner area. how do we get of lines?
open the top loader(RADF) and clean the thin piece of glass to the left of the main scanner area,there is normally ink or tipex on there.
Feb 04, 2010 | Toshiba E-Studio 3511 Color Copier
I have a toshiba e-studio 35. When copying through the feeder a line appears on the right side of the copy. Techs dont know how to fix it.
"Normally" that is a simple problem. If it copies clean when you lay your original on the glass......but when using the Automatic Document Feeder (ADF) the copy has a black line then it is clearly something in the ADF scanner. Some machines use a strip of glass that is next to the large glass to scan originals when using the ADF. That strip of glass has to be clean top and bottom. Some models use a scanner in the actual ADF. Either way if it copies fine from the glass, the rest of the copier is eliminated from being the cause.
Is your machine under maintenence contract? Then I would keep calling them until they FIX it!
Oct 22, 2009 | Toshiba e-Studio 350 Copier
Error code c26 on my Toshiba 550 copier
C-26 code it could be your exposure lamp.. when you turn on you copier keep the document feeder open and see if the lamp turns on...if it turns on and the turn off its ok.
Now clean your white reference guide..it's located under the glass..need to take off exposure glass and clean under it..especially a white strip on the edge of the glass.. NOTE: turn of your copier first then clean after adjustment turn on.
May 22, 2008 | Toshiba E-STUDIO 550 Copier
Pages printing with streaks.
try making a copy on the glass, does it come out with the streaks or clean?
If clean then look at the strip glass on the copier there is a pen dot or white out that 's giving you the streak. clean.
Jan 24, 2008 | Toshiba e-Studio 232 Black and White...
Toshiba e-Studio 161 Copier Copier Logo
180 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
