Question about Xerox Phaser 6350/YDT Laser Printer
Xerox Phaser 6350 Control Panel display problem
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
If your display has a blank display, displays garbled characters, or the display is inverted or upside down, check out this video
Posted on Feb 02, 2011
3 Suggested Answers
  • 2072 Answers
SOURCE: Display on Xerox Phaser 6350
Defective Control Panel. In early 2006 a defect was found with some of the Phaser Control Panels. This has been corrected in manufacturing and new versions of the control panel placed into inventory. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Try the Engine Only test print on the rear of the machine. If the print is successful, the display is defective and needs to be replaced. Using the Centerware IS (CWIS) and using the Support Tab will connect you to Knowledgebase for any procedures on how to change this control panel. Contact Product Support, 800-835-6100 for any other questions regarding this issue.
Posted on May 01, 2008
  • 110 Answers
SOURCE: how much is it to replace the display on xerox
Brand new it can cost up to $1,800.00 but refurb it may cost less then that depending where you get it from because alot of the companies well just sell you a refurb and it will work for just a couple of days and no garenteed anything. We always buy from the company that is on my ad list. These guys can sell you a good refurbish printer. They also have good deals on anyother type of printer. anyways good luck.
Posted on Dec 23, 2009
There is no display on the screen.
if your display on your Xerox phaser 6350 is blank you should replace the control panel (part# 333-4424-00). It's a pretty easy fix, takes about 5 to 10 minutes to install. Here is a video that shows you how. Iteminc.com has this part in stock and ships same day. Hope this helps, and thanks for using FixYa!
Feb 02, 2011 | Xerox Phaser 6350/YDT Laser Printer
Just after putting all new toner cartridges, fuser and transfer roller, my Xerox Phaser 6350 now won't print, and the LCD is completely blank.
Could be the Main Formatter board....Are you still getting power?....if you are the main formatter board is most likely the problem....If everything starts up and sounds normal to ready..and you just don't see anything on the screen your control panel is bad....You can call the guys at www.getthatpart.com who have these parts. These guys know their stuff and sell everything for the 6350 from used working units....so you get the parts for half the cost of new. They also have phone number so you can talk to a real person who can help!
Oct 19, 2010 | Xerox Phaser 6350/YDT Laser Printer
Trying to install a new mpt (shootout) assembly for the xerox phaser 6350. Is there a manual/diagram somewhere that I can refer to? Thanks!
Here is a link to the complete service manual for the xerox phaser 6350 it has full diagrams and step by step detailed instructions for every part of the printer
http://www.scribd.com/doc/42787465/XEROX-Phaser-6300-6350-6360-Parts-List-Service-Manual
Hope this helps
Mar 23, 2010 | Xerox Phaser 6350DP Laser Printer
How much is it to replace the display on xerox phaser 6350 printer
The control panel is usually under $200, You can buy them here.
Also, here is a video that shows you how to replace them
Dec 22, 2009 | Xerox Phaser 6350DP Laser Printer
Xerox 6350 prints ghost page every page printed. It is printing a ghost imge of the previous document printed on every page.
If the ghost is black then you might have a bad Black Developer 116-2011-00
If the ghost is in all colors then it may be your fuser, or possibly just your paper settings. (If you are using glossy paper or card stock this needs to be fed from the MPT tray and defined correctly in the control panel)
Whit
Item, Inc.
Oct 13, 2009 | Xerox Phaser 6350/YDT Laser Printer
Xerox Phaser 6350 printer freezes up and restarts by itself.
Hi dpluu:
Try this procedure:
Engine Test Print
Isolate printer hardware problems to either the Engine Control or Image Processor
Board by running the Engine Test print. If the print is successfully printed, focus on
the Image Processor Board or its components (RAM, Hard Drive, Configuration
Card, etc.). If the print fails, refer to Section 4 for print engine troubleshooting help.
1. Press the Test Print button located on the Rear Panel.
2. The printer prints the 600 x 600 test print unless an error status from the Engine Control Board is present. The test button is in the back of the printer and say's Test Print.
Hope this helps
May 22, 2009 | Xerox Phaser 6350/YDT Laser Printer
The menu screen is blank
If your 6350 has a blank display the most common reason is a bad control panel. It takes about a minute to replace and is very easy. Hope this video helps! Enjoy ">
Sep 18, 2008 | Xerox Phaser 6350/YDT Laser Printer
Phaser 6350 dp
If it is totally blank the control panel needs replaced (LED screen)
Xerox has been replacing those for free...go to xerox.com
This is a customer replacement item. Instructions can be found at:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=254,E=0000000001178576660,K=1045,Sxi=3,Solution=obj(3229)
If you need further instructions, a video link is at the bottom of that page...
Aug 24, 2008 | Xerox Phaser 6350DP Laser Printer
Display on Xerox Phaser 6350 not working unable to network printer
May 01, 2008 | Office Equipment & Supplies
Xerox Phaser 6350/YDT Laser Printer Logo
830 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
