Question about Microsoft Xbox 360 Console
My Xbox 360 plug is on standby and my Xbox 360 won't turn on.
    Problem Solver:
  • 6 Answers
There is a grounding issue preventing the unit from powering on. Take the console apart and remove the board screws and see if the problem still exists
Posted on Sep 11, 2009
Xbox 360 controller won't stay on
just buy a plug in and play it cost about 10pound or 10 euro
Jun 21, 2012 | Microsoft Xbox 360 Controller
When i connect my battery pack outlet for my xbox it goes to red light and my xbox 360 won't turn on
Hello
1 unlpug power to x box,remove hard drive.
Plug x box back in and reinstall hard drive. Try x box.
2 remove memory cards.Try x box.if it works the memory card was bad.
3 Remove any accesories. Try x box.plug one acc back in at a time.
Sep 19, 2011 | Microsoft Xbox 360 Console
My x box is on stand by
Like all consoles, the Xbox 360 isn't really off when it's off. Instead, it goes into a 'standby' mode that maintains a network connection and keeps looking for a nearby controller to activate it.
Are you having some kind of problem where you can't turn it on?
If you want to fully shut off your Xbox 360 to save electricity then you will need to unplug the system from the outlet. (or plug it into an outlet that has a switch you can manually turn off)
Jul 16, 2011 | Microsoft Xbox 360 Console
An update won't go through
This is a common problem with some xbox 360 users and relates to internet connection, It can be down to ports or firewalls blocking connections or just that the update server is really busy and refusing connections however there is a solution. If you go to
http://support.xbox.com/en-us/pages/xbox-360/how-to/update-xbox-360/system-updates.aspx
You can download the update and burn it to a cd or put it on a usb drive/pen and then plug it into your xbox and apply the update.
Jun 16, 2011 | Microsoft Xbox 360 Console
Xbox 360 elite has suddenly stopped working and doesnt light up
check you have a light on the power Brick. Usually Orange On Standby.
Push power On Button, should turn green.
No Light At All Check Plugs Fuse.
Orange light On, but not turning on, or going to Green, power Up.
Suspect Faulty Power Supply Unit, Or Motherboard Fault.
Mike @ Compurepair.
Mar 25, 2010 | Microsoft Xbox 360 Console
No light in the ring around xbox 360 power button
Might be in standby mode or something. because i know when i turb it off the rings disapper try to plugin a controller or something if nothing happens try to plug in a wired controller
Oct 14, 2009 | Microsoft Xbox 360 Console
Power brick colour
Alright, lets fix this!
 Xbox 360 power supply light is orange or yellow.
Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all.
If it's still doing the same it will be definitely a fault with the Xbox 360 power supply.
So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
Xbox 360 power supply light is red.
There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
If it's still red that would be for sure a fault with the Xbox 360 power supply .
So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply .
You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord.
Hope this helps you out! Please don't forget to rate :)
Apr 10, 2009 | Microsoft Xbox 360 Console
360 powerblock works when not pluged but dosnt when is plugged
It is the power brick. If you are under warranty you can have microsoft send you a new one for free, otherwise a new powerbrick is around 80 dollars.
Feb 06, 2009 | Microsoft Xbox 360 Console
Wont turn on...
You have to Call 1-800-4my-xbox.
Then tell them what happened, you will have to mail it out with the Console, and the plugs.
Dont mail out the hardrive or disc.
They will send u a brand new console.
Hope this Helped.
Jul 12, 2008 | Microsoft Xbox 360 Console
Xbox 360
If your xbox is stuck in standby, you've got some issue. Unless you pressed the "standby" button on your router while playing Halo 3 at a weak attempt to try and cheat other players, and then your xbox 360 became stuck in "standby"mode, I have no idea what you are talking about. Elaborate. And if this occurred after prressing standby while playing Halo 3, you probably deserve having a broken xbox 360 since you were probably trying to cheat against me! As for the guy who's life revolves around Call of Duty, you have to stop playing sometime. Either when the console actually breaks from all the cheezy poofs and mountain dew you place on it or M$ poorly designs the xbox 360's to do this intentionally.
Apr 26, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
136 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
