No Sat signal due to thunder - Televison & Video
  • 157 Answers
Open door on sat box push reset button-let unit find signal without interupting it-if that fails call sat co.
Posted on Sep 10, 2009
What time do the thunder bolts fly on Sat?
Hey Patricia... I would guess it depends on where you live??.. I could not find any info on this?? Sorry...
Aug 16, 2017 | Cars & Trucks
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
My sat nav is not showing me in the correct location - what should I do
Hi Diane, from the symbol you described it sounds like you are not receiving the satellite signal to your sat nav! The weak satellite signal could be due to the location you are in and also within the vehicle, some vehicles reduce satellite signals and you have to fix an external aerial to improve the signal! Have you tried using it with the door/ window open to see if that helps the signal?
Jan 11, 2015 | 2006 Land Rover Range Rover Sport
Vento VThunder XL turn signal relay location
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Vento, despair not, for a mere $25 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Vento Thunder XL turn signal relay location Google Search
Vento Thunder Relays eBay
Service Repair Manual $25
Vento vthunder colt 2V49FMM
Vento Thunder XL 2013
Sep 21, 2014 | Vento VThunder XL Motorcycles
Had a lightning issue the other night and now my Vizio tv will is not able to find satellite signal. Netflix works and can pick up Wi-Fi signal .....there is a good picture but it says searching for...
If it says "searching for satellite" the problem is in your satellite receiver, not the TV. The TV is working. Its showing you the signal coming from the sat box. The sat box is the tuner and is responsible for the sat signal. The "searching for satellite" is a common problem after lightening issues. If you have multiple sat boxes, then swap this one with another that you know works. If this is your only box, call your provider as it means the dish LNB or the sat box was damaged by the lightening. Also have the wiring checked for bad grounds due to an improper install.
Dec 21, 2017 | Vizio VO420E 42 in. LCD TV
Lamp signal light is blinking after a thunder storm, no sound or picture
The projection lamp is dead,some how got shorted in the thunder storm.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp for the replacement.
Aug 03, 2010 | JVC HD-52G787 52" Projection Television
Do thunder lightning has any effect to a sony bravia lcd or a panasonic viera lcd tv?
Yes!!! When going out for extended periods of time unplug TV's from a/c outlet AND dissconnect broadcast signal from TV(cable,sat. etc)
Isolation is the only sure protection against LIGHTNING DAMAGE!!!
I advise purchasing protection from your' service provider.
May 19, 2010 | Televison & Video
LEFT TURN SIGNAL DOES NOT WORK 2007 V-THUNDER VENTO
I just won't to know where I can buy parts for rear tun lights are buy replace the whole thing
Apr 14, 2010 | 2006 Vento V Thunder XL
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
